Sensor-triggered photography
Started Jul 26, 2018 | Discussions
Piranha215
Piranha215 Forum Member • Posts: 70
Hello fellow photographers,
I have built an arduino-based trigger unit, with sound, light, motion and range detectors. These can be used individually or cascaded sequentially. There is also an intervalometer and a water solenoid controller.
I would like to start a discussion regarding the possible uses to which this unit can be put. I've done the usual balloon popping, with spectacular results, and water drop collisions, and now I'm looking to expand my horizons. There is also an auxiliary input and, since I am an electrical engineer, I can devise any type of sensing device to trigger the unit.
Please take a moment to offer your thoughts on what can be done to take even more satisfying images with this device.
Thank you in advance
 Piranha215's gear list:Piranha215's gear list
Sony a6000 Sigma 70-300mm F4-5.6 APO DG Macro
craig66 Senior Member • Posts: 1,484
Re: Sensor-triggered photography
Lightning trigger - should be fairly easy.
Trigger to capture insects in flight. The idea is to use two crossed lasers, prefocus on the point where they cross and fire the shutter when both beams are broken. The mechanical setup may be more trouble than the electronics and software. A camera with very fast shutter response may help too. If flash is used, flash response time may be an issue.
 craig66's gear list:craig66's gear list
Sony a77 II Sony DT 55-300mm F4.5-5.6 SAM Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 150mm F2.8 EX DG OS Macro HSM Sigma 500mm F4.5 EX DG HSM +10 more
Piranha215
OP Piranha215 Forum Member • Posts: 70
Thank you for those suggestions Craig66. For the lasers I will have to use the auxiliary input, however that should not be a problem. The lightning strike should be straightforward.
Turbguy1
Turbguy1 Senior Member • Posts: 1,467
You are aware of CHDK, no?
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
Piranha215
Nope. What is CHDK?
Piranha215
I read up on it and now I am aware of it, but don’t see the relevance, to be honest.
Holger Bargen Veteran Member • Posts: 4,906
The most professional solution I have ever seen is this one:
https://petapixel.com/2010/02/05/photo-grandpa-shoots-with-laser-rigs/
https://www.flickr.com/photos/fotoopa_hs/5312347017
https://www.flickr.com/photos/fotoopa_hs/sets/72157604620957208/
https://www.flickr.com/photos/fotoopa_hs/albums
Have fun with those construction and the results!
Best regards
Holger
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
Piranha215
Thank you for that contribution Holger. What I had in mind is a lot simpler, but probably won't be as effective. I will keep you updated with how it goes.
Turbguy1
You can write a script (or download a re-written one from the CHDK Wiki site) to use the camera's own image sensor to trigger photography...think lightning strikes, movement, or other parameters...
CHDK is of no use if you don't have a Canon camera or if your Canon camera is a DSLR. There is Magic Lantern for Canon DSLRs. I have every respect for what these developers have done, but there are advantages in using external devices for triggering - easily adapted to just about any camera with probably no more than a different cable. You also have a wider range of triggering sensors at your disposal.
Piranha215
Thank you for that information; it is most useful. One of the beauties of my system is that the sensor responses can be cascaded sequentially, in any number.
Mark H U Regular Member • Posts: 495
Thx, for reference only.  Bookmark not working?
-- Regards, Mark
 Mark H U's gear list:Mark H U's gear list
Nikon D50 Nikon 1 J2 Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Sigma 10-20mm F4-5.6 EX DC HSM Sigma 70-300mm F4-5.6 DG Macro +4 more
J Peters Contributing Member • Posts: 759
Hello all, I was about to create a post asking a very similar question, until I saw this thread.
I bought a VersaTrigger set (I probably do have the skills to build my own trigger system, but I'm too busy and lazy). It will trigger either a camera or flash, though the latter gives you more precise results as cameras are laggy. The inputs are either laser beam being broken, or sound.
I am also on the lookout for applications. I belong to a photographic club, and I'd like to take the setup in and do a demonstration evening. Because this takes place in a hired hall, anything messy or dangerous is out! So unfortunately smashing plates or glass for example is too messy and risky. I have a big box of balloons, and also some party poppers, but I'd welcome any other ideas.
Incidentally, the suggested way to catch lightning with this setup is to use sound triggering, and plug in an AM radio tuned to inter-station hiss. It will fire the camera when there's a burst of static noise which will coincide with the lightning strike. Clever!
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Not to be cute, but that's worked with CHDK for nearly a decade. I have fleets of PowerShots that I use that way, from $70 20MP ELPH180 to $130 16MP 50x Zoom SX530HS, with various internal/external triggering. Of course, I'm a computer engineering professor, so perhaps it's not shocking that I and my group are pretty good at this stuff.
Anyway, there is still value in having a good external controller, and an Arduino nano makes a nice sub-$2 plaform.
The key issue I'd be concerned with is release timing. Most digital cameras have significant delays from shutter trigger to shutter fire -- often between 1/100s and 1/10s. Using USB-power-sense triggering with CHDK, you can easily sync to within 1/1000s (which is the internal OS scheduling jiffy in the cameras), and with some work can usually hit within 1/30000s for trigger of the mechanical leaf shutter (which, incidentally, can do shutter speeds up to 1/10000s or faster on some cameras under CHDK). BTW, the CHDK motion detect code module examines the rear LCD live feed, so it has a max of around 1/24s latency to grab a frame from the live feed, but triggers almost instantaneously when it has the frame. Overall, this makes CHDK PowerShots excellent cameras for use with external triggers too; in fact, you could also have the camera OUTPUT a trigger to an external device using USB, camera LEDs, etc.
What detect-to-trigger latencies do you measure on the cameras you're using?  Which cameras?
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
