Sony 24-105 f4 soft right corners?
Started Jul 26, 2018 | Discussions
mohxinn Regular Member • Posts: 134
Hi,
I recently moved to Sony camp I bougth a Sony A7 III together with a Sony Zeiss 24-70 f4 and a Sony 85mm 1.8 G lens.
Yesterday I decided to try a Sony 24-105 f4 since I read about the raving reviews and how it trumps the Zeiss 24-70 f4 despite having a longer zoom range.
I did a quick test between the 2 lenses to check how much better the 24-105 was.
Below are center and corner crops (left and right) from the 2 lenses. The test target was a bench of matte magazines pages fastened to a wall. The test was done 24mm at F4.
Tripod was used and SteadyShot was disabled for both lenses.
Center Crop
Sony
Zeiss
Right Corner Crop
Sony
Zeiss
Left Corner Crop
Sony
Zeiss
Full Image
Sony
Zeiss
As expected Sony 24-105 is sharper in the center and a lot sharper in the left corner. However, it seems to be less sharp in the corners on the right comparerd to the Zeiss. Does this means it is decentered? Or is this a testing error?
I very much look forward to your valuable comments and suggestions!
Mohsin
Flickr: https://www.flickr.com/photos/90692793@N03/
 mohxinn's gear list:mohxinn's gear list
Fujifilm X-T30 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F1.4 R
Sony a7 III Sony FE 24-105mm F4 Sony FE 24-70mm F4 OSS
C47 Contributing Member • Posts: 634
Re: Sony 24-105 f4 soft right corners?
This is really hard to say on the basis of theses photos. Can you post some photos you shot of a symmetric test chart and some real life photos of subjects that are farther away?
https://www.google.com/search?q=lens+test+chart&tbm=isch
https://phillipreeve.net/blog/how-to-check-how-decentered-your-lens-is/
 C47's gear list:C47's gear list
Panasonic Lumix DC-G9 Olympus E-M1 II Nikon Z6 Olympus 25mm F1.2 Olympus 12-100mm F4.0 +5 more
OP mohxinn Regular Member • Posts: 134
Is this any better? Printed one of freely available lens test chart.
Sony 24-105,105mm at F4
Thanks for helping out
I can hardly see any differences when zooming in on the edges and comparing them side by side. The lower left and upper right edges seem minimally softer.
Is that normal?
Do you own a 24-105 lens? I was hoping if you do then perhaps you can tell if this lens is a keeper or should I get another copy?
Again I appreciate your time and help!
Costas L Regular Member • Posts: 166
There is a fairly simple test for decentering described by Fred Miranda at the link below. Should be quick to try but need bright conditions so you can use a high shutter speed
http://www.fredmiranda.com/forum/topic/1534737
daran
daran Regular Member • Posts: 298
Seems rather soft. Might be field curvature, though. Have you tried focusing on the corner or increasing the distance?
For comparison, I shot something similar with the 25-105 on an A7r2: Full Res Test It took me some fiddling to get the camera fully perpendicular to the floor and I believe I focused manually.
 daran's gear list:daran's gear list
Sony a7R II Sony FE 55mm F1.8 Zeiss Batis 18mm F2.8 Sony FE 70-300mm F4.5-5.6 G OSS Sony FE 24-105mm F4 +5 more
JimKasson
JimKasson Forum Pro • Posts: 25,537
An offer
If you run this test three times:
https://blog.kasson.com/lens-screening-testing/
and send me three sets of the raw files -- 27 images in all -- I'll analyze them and report back to you.
Here's what a good copy of that lens looks like at 24 mm:
https://blog.kasson.com/lens-screening-testing/examples/good-zoom-at-24-mm/
Jim
 JimKasson's gear list:JimKasson's gear list
Fujifilm GFX 50S Sony a9 Nikon D5 Sony a7R III Sony a7 III +5 more
ArtAlt
ArtAlt Senior Member • Posts: 1,976
mohxinn wrote:
Hi,
Mohsin
Is there a reliable way to assure that the plane of the test chart and plane of the sensor are parallel?
 ArtAlt's gear list:ArtAlt's gear list
Nikon D750 Nikon D810 Sony a7 III Nikon 85mm F1.8G Sigma 24-105mm F4 DG OS HSM +4 more
Nick46
Nick46 Regular Member • Posts: 130
That's a good question. In my view one would need some pretty sophisticated laboratory equipment to set the sensor & target up.
These DIY test on these forums tell us nothing.
 Nick46's gear list:Nick46's gear list
Sony RX100 VI Sony a7R II Sony a7R III Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro +4 more
jiulin Regular Member • Posts: 199
Having read this thread, I also did some tests on my 24-105.
I think mine is also a little decentered. The results are consistent (several tests @ 20m and 2m): Lower R > Top R > Lower L > Top L (while the center is in good focus).
I advise everyone not to waste time with this test unless you can return it. I've taken 9k photos with mine and never noticed any issue until today's test. Not only have I wasted my time but also been feeling sub-par.
Btw, I did the test on FM forum & this one: https://phillipreeve.net/blog/how-to-check-how-decentered-your-lens-is/
I prefer the second one because flipping the camera means not using a tripod.
Maybe having the subject further away is easier on the lens?
Anyway, if I bought one of the lenses infamous for decentering, I'll do this again.
HP1999 Senior Member • Posts: 4,316
Not sure it matters. Corners of frames are filled with things that is not the main point of interest.
Further, no one looks at photos like this.
If you have a 70 inch 4K whatever TV do you watch from 5 inches away?
I dont hold a photo that close to my eyes in real life.
Have you ever purchased a new suit and as soon as the sales guy puts on the jacket to try do you raise your hands in the air?  I have seen this and no one walks around like this, cracks me up....
Make your decision by taking a normal photo. Do you like it or not?
This is assuming you have it in focus and exposure is good.
If yes great if not return it.
Shadowfixer Senior Member • Posts: 1,512
If you have to take a picture of a gnats rear end and zoom to 500% to see a difference, I doubt there is a real world issue.
 Shadowfixer's gear list:Shadowfixer's gear list
Olympus E-M1 II Olympus 9mm F8 Fish-Eye Body Cap Lens Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro +1 more
Re: An offer
Jim
I will try to do this over the weekend. Just confirming my understanding. My camera is Sony A7 III which 24 MP FF camera. I plan to test at 24mm and F5.6 that way, if I understood correctly from the info on the link you sent, I can have a shorter distance to target and a smaller test target.
Based on above info can I print on an A3 paper?
Everytime should use the same FL and aperture, right?
Thanks for the link. I will try this
Thanks for sharing your test shots. Gives me something to compare to. I think I need better lighting to judge the performance reliably.
Fenwayfan77 Forum Member • Posts: 76
https://www.youtube.com/watch?v=QVD2Q-3HbVo
This is a simple yet effective and accurate way to test for decentered issues.
JimKasson
Re: An offer
Yes, stopping down shortens the distance
That should work.
Yes. Focus once, make 9 shots. Refocus, and do it again. Refocus a final time and make the last 9 shots.
Jim
Re: An offer
That should work.
Jim
One more question, my printer is of Ricoh brand and as far as I can tell from the printer options, I supports either 600 x 600 dpi or 1200 x 1200 dpi. Which targets should I use? Epson ones or the Canon ones?
Also do I need to print only one target or all three targets (60, 80 and 100 spoke)? If yes, how should the targets be placed?
JimKasson
Re: An offer
That should work.
Canon ones, if you crop. Or just pick any one and resize using nearest neighbor.
Just pick one.
Jim
