How much better are newer Panasonic bodies without AA filter for windeangle lenses?
Started Jul 24, 2018 | Discussions
KirillQPR Regular Member • Posts: 140
I got a good deal on the Panasonic G7 and decided to get it mainly for use with the Panasonic 7-14mm which I had previously used on the Olympus M10 II and very pleased with the edge/corner sharpness at 7mm but displeased with the occasional purple blobs. The latter are not an issue on the G7 but the former is now an issue indeed, and I surmise it is due to the AA filter (which the Olympus model does not have)? So I am wondering if the newer Panasonic bodies with no AA filter would give me the same good edges and corners at 7mm as this Olympus has done, anyone with firsthand experience here?
 KirillQPR's gear list:KirillQPR's gear list
Sigma dp3 Quattro Sony Xperia 5
Leica M10 Panasonic Lumix DMC-G7
Danielvr Veteran Member • Posts: 6,863
Re: How much better are newer Panasonic bodies without AA filter for windeangle lenses?
[..]  and I surmise it is due to the AA filter (which the Olympus model does not have)?
I'd think that center sharpness would also suffer if it was the AA filter. If only the edges/corners are affected, maybe it's a matter of lens corrections applied in processing?
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
larsbc Forum Pro • Posts: 18,282
I have a GX7 with AA filter and G85 without.  I haven't done side-by-side comparisons but I haven't really noticed any sharpness differences that jumped out at me.
tt321
tt321 Forum Pro • Posts: 13,854
Systematic testing
Your G7, if it is a used unit, might have some mount/sensor relative tilt. This sort of thing shows up more clearly with wide angles.
You can do comparisons against the Olympus by focusing on centre, corner, etc.
The four-corners test and infinity horizon test (kenw used to describe them quite well with example images) are good ways.
The infinity horizon test: Find a horizon with say trees or a fence that is sufficiently far away (infinity across the horizon, usually a football field is plenty large enough for a wide angle lens) with details across the entire horizon. Set up the camera so that the horizon is diagonal between two opposite corners going through the centre. Shoot focused at the centre and both corners. Set up the camera with the horizon going through the other two corners and repeat.
Compare across both cameras. You should be able to deduce whether it is a general lack of sharpness in all corners or some kind of tilt, i.e. the lens mount not parallel with the sensor. Typically, tilt will cause corner 3 to be unsharp when focused at corner 1, and vice versa. If this happens with one camera and not the other ...
The four corners test: Find something with detail far away - road sign with different sized lettering is a good candidate. Focus on the sign at the centre. Keep focus unchanged and shoot with that object in the centre and in every corner via re-framing. Then focus on the object with it in one of the corners and repeat the five shots. Compare across both cameras.
The key thing about these two tests is that the tester does not need to worry about keeping the sensor parallel with the target, such as in the case of a brick wall test. This is because for the horizon test, everything is at close enough to infinity that even large non-parallelism does not matter - you don't care, for a wide angle lens, whether one side of the horizon is 70 metres and the other 100 metres away. 70 and 100 metres are essentially the same distance. And the four corners test is on a small target filling less than 1/10 of the image height and there is nothing to keep parallel to anything else in the test at all.
Pure electronic shutters and raw for all tests. A tripod would make things easy.
OP KirillQPR Regular Member • Posts: 140
Re: Systematic testing
No, it is a new unit and the sensor is aligned just fine, I tested it first thing.
As for different lens correction algorithms, I doubt it is the case as I have also tried both bodies with the Samyang 7.5mm fisheye that sends zero information to the camera, and again the edges/corners are slightly worse on the G7 in the same shooting conditions. It has got to be the AA filter, perhaps such wide angle lenses are just not telecentric enough and an extra glass layer makes things worse. Oh well, live and learn.
saudidave Senior Member • Posts: 2,659
I had a G7 and I now have a G85.
The IQ is noticeably better, much sharper
Dave
 saudidave's gear list:saudidave's gear list
Panasonic Lumix DMC-FZ300 Panasonic ZS200 Apple iPhone 12 Pro
alcelc
alcelc Forum Pro • Posts: 19,006
A sample?
Pls ignore this one as I had mis read OP
brentbrent Veteran Member • Posts: 5,768
Those tests sound well-designed.  Question:  Manually focus each camera on the targets, or use AF?  It seems that either way introduces a potential variable.  I'm thinking that magnified manual focus would be best.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
davidedric Veteran Member • Posts: 7,339
Do you know anyone with DxO's PhotoLab?  I wonder how their lab developed profiles would cope with your system?
Dave
 davidedric's gear list:davidedric's gear list
Sony RX100 VII Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic 12-35mm F2.8 +3 more
tt321
I agree with magnified manual focus. This would remove a variable when shooting multiple frames with re-framing whilst keeping focus unchanged.
In most cases, we are trying to find differences between the centre and corners and between different corners. So a slight misfocus is not life and death if it is the same across the compared shots.
The truly obsessive would then move on to shimming lenses
