better sharpness on p100-400mm over 100-300mm mk2?
Started Jul 24, 2018 | Discussions
rashid7
rashid7 Veteran Member • Posts: 7,011
Re: better sharpness on p100-400mm over 100-300mm mk2?
your can be very proud of those photos.  It is usually a matter of diminishing returns when upgrading gear, no?
I had Nikon D750 & D7100 which I used with the Sigma 150-600C.  Although I didn't allow myself to 'grow' into airshow shoots, having only done once at Dubai (w/ D7100),     I was not blown away by my results.
I had somewhat better results at the Red Bull Air Races w/ D750 and tamron 70-300VC.  That lens even worked pretty well w/ an old sigma 1.4 TC.
So u never know... there are so many variables that affect outcome, and gear is not the biggest one!
Keep it fun!
larsbc Forum Pro • Posts: 18,282
FriskyMoose wrote:
I am surprised no one has looked at the new PL 50-200 with a 1.4 TC. I read a review side by side with the 100-400 and it looked pretty good. The 2.0 TC didn’t result in sharper images but that combo might be also not a bad alternative? I am on the fence at the moment to which combo I take to Kenya. Apart from the extra cost I am really torn overall.
Great pictures from the 100-400 I have seen online especially with the G9 which I have. The 50-200 would compliment the 12-60 and 8-18 nicely but I might need more reach on safari hence torn about it.
I already have a 35-100/2.8 so when I was looking for a long zoom for wildlife photography, the lens would only be for that purpose.  For general travel use, I'll keep using my 35-100 for its f/2.8 but more importantly, for its small size.  So for me, the 100-400 made more sense because I'd be using it at its long end a lot.
633 squadron
OP 633 squadron Regular Member • Posts: 307
Thanks for that jaywol, will look into that
In life, as in chess, forethought wins.
 633 squadron's gear list:633 squadron's gear list
Fujifilm X-Pro3 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR
633 squadron
Re: Analysis and tips
Tanks for the detailed response Astrotriper. I t=think some of the editing is down to my personal preference, i quite like the over saturated colours or making the photo look dramatic. but i will admit my pp skills definitely have a long way to go! i have only recently able to get access to photoshop.
As to your thoughts on the camera equipment that is very enlightening. maybe i should consider something from the apsc line of cameras? but the whole reason i went mirrorless in the first place bis because are there very good video capability, 2x crop factor therefore meaning that i can get a 600mm f5.6 lens at £379.
Robiro Veteran Member • Posts: 6,813
Simple advice - f7.1 or f8 @ 300mm
When using 100-300mm at the long end, use f7.1 or f8 to get maximum sharpness and resolution.
Your shots are at f5.6 despite the fact that you had enough light to go f7.1 or f8 without getting motion blur.
So, next time try f7.1 or f8. Anything above f8 is overkill and counterproductive.
And yes, 100-400 is sharper a little. Not in a different league, however. Just a little sharper.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
633 squadron
I like what you say rashid7! its no how big it is its how you use it....some might say!. its absolutely true what you say though,you may have a nikon d850 with a 300 f2.8 but you technique might be crap which ends up in you getting rubbish photos!!
633 squadron
Re: Simple advice - f7.1 or f8 @ 300mm
thanks for that Robiro wish i had known this before the airshow!
633 squadron
Some more photos
Hello everyone, just processed as load more of my photos from the airshow. I think the display team photos look a lot better because i wasn't zoomed all the way into 300mm tips and tricks for pp would be helpful :). Pleas note that i haven't actually edited all of these photos, just converted them from raw to jpeg.
