better sharpness on p100-400mm over 100-300mm mk2?
Started Jul 24, 2018 | Discussions
633 squadron
633 squadron Regular Member • Posts: 307
7
Hello everyone,l just finished sorting through and editing my photos from RIAT. i was using the Panasonic G7 along with the 100-300mm mk2. I was very happy with the results i was getting but... i wasn't exactly blown away by the sharpness that i was getting. I admit some of the times it may have been down to user error e.g shooting a 1/640 when i should have really been at 1/1000 and there was also a lot of heat haze. but when i had a look at some of the photos that other people had taken theirs were better. My question is, should i upgrade the body to something that has more megapixels and no aa filter such as the g85 or gx8, or should i look at the 100-400mm or both? I hope you enjoy looking at my photos and thanks for any advice in advance.
In life, as in chess, forethought wins.
 633 squadron's gear list:633 squadron's gear list
Fujifilm X-Pro3 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR
Panasonic G85 Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX8
glassoholic
glassoholic Veteran Member • Posts: 7,641
Re: better sharpness on p100-400mm over 100-300mm mk2?
Lovely shots!
I had the Oly 75-300 and the general chit chat from others is that the Pana 100-300 is much the same.
I found a big step up in IQ with my PL 100-400  but it is not just optically... the AF is much superior in speed and accuracy. When my Oly 75-300 nailed focus it was good but it often was a touch out. I tried it for birding and motorcycling and here and there got a great shot. Now I get many more sharp shots than bad ones so yes... it should benefit you too. However the PL 100-400 has not suited some people as has been often repeated here. Use the search feature.
So I find the PL zoom great and indeed some others have owned it and the glorious Oly 300 Pro and settled on the zoom by choice. YMMV.
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me. Make the best you can of every day!
TheDream168
TheDream168 Regular Member • Posts: 155
I understand the Mk 2 is optically the same as the Mk 1, and if so, then the sweet spot for this lens is f/7.1.
No AA filter does help, and I think the difference in IQ between my PL 100-400 and 100-300 is night and day.
Loved your pics. Thanks.
633 squadron
OP 633 squadron Regular Member • Posts: 307
thanks glassholic and thedream168 for your comments. i will try using this lens at f7.1 and see if i can get sharper results.
Wu Jiaqiu
Wu Jiaqiu Forum Pro • Posts: 29,319
are you cropping much on these?
 Wu Jiaqiu's gear list:Wu Jiaqiu's gear list
Fujifilm FinePix X100 Nikon D2Xs Nikon 1 V1 Nikon 1 J3 Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
633 squadron
yes most off them are, even at 600mm i still had to crop to fill the frame. even though we were so close to the airshow
633 squadron
Does anyone else have any other tips on using this camera/lens setup? other than the standard stuff such as double your length of the lens in mm to get the shutter speed or use a tripod.:-D
MarkDavo
MarkDavo Senior Member • Posts: 2,458
Dear Squadron Leader,
I use an E-M1 MkII with Oly 300mm f/4 with 1.4TC as my primary combination for bird photography. I also have the PL 100-300 II, like you, which I bought last year before going on a bird photography camp where I felt I would need a lens for closer work. I didn't have to use it as the target species were always at the right distance for the 300 f/4.
Now I've been in Europe for 6 weeks and decided to travel light with the E-M1 MkII and PL 100-300 II, which I regret.  Unless I've been able to get really close, say 3-6m, the image is not as sharp as with the 300mm f/4.  I'm now considering changing the 100-300 for a 100-400 which I should have done originally based on the generally good experience of users on this forum.
Lets see what Trevor Carpenter and other 100-400 users say.
Cheers, Mark
Wouldn't be dead for quids
 MarkDavo's gear list:MarkDavo's gear list
Olympus OM-D E-M1X Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM +1 more
Wu Jiaqiu
i thought so, the crops might be degrading the image quality a little too much, which means the 100-400mm would be better suited for this
633 squadron
Thanks for the title Markdavo!...
ok, i understand what you are saying, in my situation, when the planes came closer it was better but when i cropped in to look to see how sharp the details were i just found that it wasn't as good as i had hoped. My only problem is that the pl 100-400mm is quite a lot of cash.
633 squadron
yes, see what you are saying, but even when i manged to fill the frame if you look in a bit the image quickly looses its clarity.
jalywol
jalywol Forum Pro • Posts: 12,302
Yes, the 100-400mm has much better sharpness, and MUCH less CA, especially at the long end. (I used a 100-300mm MK I for years, and when I switched to the 100-400mm, the difference was not even remotely subtle).
You also should think about getting a body with one of the 20MP sensors, as, since you are cropping, every MP makes a difference. The GX95 would be the least expensive way to get into one of the 20MP sensors, btw; the GX85 and the G85 are both 16MP, not 20MP, so I wouldn't bother changing to either one of those. I love my GX8, but it does have an AA filter, so it wouldn't necessarily be the best option for your purposes, even though it is a 20MP sensored body, unfortunately.
GX95 and 100-400mm would definitely up your game rather a lot for what you are shooting.
-J
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
I think you are doing OK.  Much of any problems you can see are down to atmospheric conditions which of course are amplified by cropping.
Moving from G7 to G80 I was struck immediately by the improvement in IQ presumably from the removal of the AA filter.  Cropping ability is noticeably improved.  I had gone, G5 - G6 - G7 and G80 and this was by far the biggest improvement.
The 100-400 is in a different league to the 75-300 and 100-300, only beware that you may find it not as good at first as the extra length increases stability difficulty and those atmospheric conditions.
100-400 is much better focusing than 100-300 mk 1, I can't comment on mk2.
Overall the combination in improvements gives you a big step up.
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
terp02andrew Junior Member • Posts: 40
It's actually interesting that you say this because I had similar disappointments at a shorter focal length (75 f1.8 cropped vs. 45-150 or 45-175). I realize this isn't quite the same as your situation, but I feel getting accustomed to our primes makes it difficult to really love our zooms as much lol.
The 100-400 in particular is such a huge jump in weight (985g vs 520g for the 100-300), that I feel there's a pretty big commitment to this. Handling and shooting technique seem even more paramount.
(Then again, if you're coming from a 300 f4, then the 985g of the 100-400 is still a big reduction in weight hrmmm.)
 terp02andrew's gear list:terp02andrew's gear list
Olympus OM-D E-M10 II Panasonic GX850 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic 12-35mm F2.8 +3 more
Astrotripper Veteran Member • Posts: 8,676
Analysis and tips
5
633 squadron wrote:
Hello everyone,l just finished sorting through and editing my photos from RIAT. i was using the Panasonic G7 along with the 100-300mm mk2. I was very happy with the results i was getting but... i wasn't exactly blown away by the sharpness that i was getting. [...] I hope you enjoy looking at my photos and thanks for any advice in advance.
This is a bit long, but hopefully you'll find it useful.
This looks pretty good. There's some noise that I'll discuss later.
This one is simply destroyed by noise reduction. Hard to judge how the lens performed here.
This one looks pretty good. A bit too much sharpening, which made noise look like grain and created unpleasant halos along the edges and accentuated chromatic aberration as a bonus.
Same as above, basically. For scenes when subjects are at significantly different focal planes (distance from you), make sure you have enough depth of field. Looks fine on this one.
Another one destroyed by noise reduction, which makes it look as if there was some sort of art filter applied to it. Hard to tell how the lens did on this, but I suspect it's not bad.
Looks like a pretty considerable crop, which always makes things harder. A bit too much noise reduction, but not bad for a crop, I'd say.
Much better processing on this one. Seems a bit soft, but not sure if motion blur or something else.
Too much local contrast boosting (clarity or whatever it's called in the software you use), which creates those darker outlines around the white smoke trails and lighter outlines around the planes. This shows one of the weaknesses of that lens, which is purple fringing on strongly lit (or back-lit) subjects.
Summary: apart from the ones with some excessive processing, the rest looks good full screen on my 15" retina screen. In short, they would look perfectly fine on a A4 print. I think better processing can still improve things, and you could also improve some things on the capture end. Overall, I'd say not bad at all. You definitely got some nice keepers there and I'm sure you will get more and better next time.
Now on to general tips.
If you have enough light and shooting at 300mm, stop down to at least f/6.3 or preferably to f/7.1. While at 300mm it never really gets super sharp, there is a noticeable improvement from f/5.6. Not a world of a difference, but enough to see in a real photo. Also, try to keep the subject in the center of the frame, or at least make sure it doesn't drift too close to the edges. Basically the softness at the edges and corners does not go away with stopping down and CA is pretty massive there, which is especially problematic for high contrast scenes.
For most of those shots, you should have had exposure compensation set to +1 or even more. Basically, when you are photographing a greyish plane on a grayish sky/clouds, your camera's metering system will most likely cause the camera to underexpose the scene. Pay attention to the histogram. In some of the shots above you could have significantly reduced noise in the shadows (which was basically most of the plane) by overexposing, thus reducing the need for NR that destroys detail.
Panasonic 100-300 II is prone to shutter shock. Not sure how the situation looks like with G7, but on both my Olympus cameras I can see clear blurring in certain shutter speeds. I have not verified if it affects really fast shutter speeds or how that would play out during continuous shooting (I use EFCS or electronic shutter on my E-M1 II, which seems to completely eliminate the problem). You might want to do some tests to verify if this is an issue for you or not.
Make sure that stabilisation does not work against you.
And of course processing. You can both make things a lot better or ruin them. It takes experience and some serious learning to master the tool you are using to process your photos. But in the end, you should aim for something that is pleasing to you, not necessarily what others tell you.
And sometimes there's not much you can do. Hot shimmering air, smoke that limits contrast and visibility, shooting against the sun or simply the plane being too far away.
As for the gear.
Yes, the 100-400 would improve the quality. First of all, it would be better at 300mm. But more importantly, it would allow you to zoom in further, so much less cropping, which has clear negative consequences on image quality.
I'd say camera is less critical in your case. Sure, a newer model would eliminate the possibility of shutter-shock happening. But if you get to know how your camera behaves in this regards, this is probably not going to be an issue. More pixels sounds great as well, but 20mp vs 16mp isn't such a big deal as to make a world of a difference when cropping. Also, with this lens at 300mm, AA filter or lack thereof makes little to no difference. I think you'd need a lot sharper lens to see the effect of AA filter on photos.
Would G9 increase your success rate and offer better image quality? Yes. But I doubt it would be such a big step up as to immediately make all your photos better. That's unlikely. So might not be worth the cost, at least until other aspects are sorted out.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Badwater Senior Member • Posts: 2,095
Nice pics. I've seen a lot of reviews and comparisons between these lenses. And you are not alone. What you describe is what the reviews and comparisons indicate. The 100-400 is a hefty piece of glass with a lot of range. Crazy 800mm full frame equivalent range hand held is insane. Nevertheless, the 100-300 II is no slouch on the couch. It too can deliver amazing pics hand held.
With that lens, I would go for the LUMIX G9, the Dual IS2 and AF is amazing with that lens.  Although the G9 is heavier, it will balance well with the 100-400.  See the reviews on line.
C Sean Veteran Member • Posts: 3,423
I haven't tried the 100-300 mk II and therefor I can't compare it to the experience I had with the 100-400. However, unless you planning to use the extra 100mm to get tighter shots of nearby subjects, you maybe throwing money away.
Between the two lenses, there are improvements everywhere but they aren't big improvements. However, these improvements do up and I would say the 100-400 is a pro lens.
Stejo
Stejo Senior Member • Posts: 1,461
Contrary to popular belief, I don't find the PL100-400 a significant optical improvement over the P100-300ii. It's a tiny bit more contrasty at 250-300mm but that's about it. It's also not faster. Basically you're getting an extra 100mm worth of reach for twice the weight. Which is a reasonable tradeoff in the telephoto world, don't get me wrong. Better build quality too.
AF and stabilization I think are identical between it and the second version of the 100-300. I don't own the 100-400 but I've used it on numerous ocassions and couldn't find any observable difference in their electronics.
I think in your case a body upgrade would be more beneficial. The 20MP no-AA sensor on the G9 is a pretty big improvement and the AF performance is much, much better. It can't perform miracles but it improves on the G7 in every aspect for a moderate weight increase.
The PL100-400 is so much bigger and heavier and will only yield measurable improvements if you're regularly shooting at 300mm wishing for more zoom range.
 Stejo's gear list:Stejo's gear list
Panasonic Lumix DMC-G7 Panasonic GH5 Samyang 85mm F1.4 Aspherical IF Samyang 7.5mm F3.5 Fisheye Sigma 18-35mm F1.8 DC HSM Art +7 more
FriskyMoose New Member • Posts: 8
I am surprised no one has looked at the new PL 50-200 with a 1.4 TC. I read a review side by side with the 100-400 and it looked pretty good. The 2.0 TC didn’t result in sharper images but that combo might be also not a bad alternative? I am on the fence at the moment to which combo I take to Kenya. Apart from the extra cost I am really torn overall.
Great pictures from the 100-400 I have seen online especially with the G9 which I have. The 50-200 would compliment the 12-60 and 8-18 nicely but I might need more reach on safari hence torn about it.
 FriskyMoose's gear list:FriskyMoose's gear list
Sony RX100 Nikon D800 Nikon AF-S Nikkor 24-70mm f/2.8G ED Panasonic Lumix DMC-LX5 Nikon D70 +9 more
glassoholic
Re: Analysis and tips
As for the gear.
A thoughtful and well summed up post!
You pays your money and gets what you paid for... or so the saying goes. If you appreciate the slight improvement then the cost pain goes away quickly. If you see no improvement... that will hurt!
