Backup Safari Body
Started Jul 23, 2018 | Questions
ElQuijote617 New Member • Posts: 17
Backup Safari Body
Hello, Canon shooters! I’m seeking backup camera recs for the purpose of having a wide-angle option on safari without changing lenses. My main body is an 80D. So: SL1? T6i? Rent a T6i, SL1 or 80D? Or not needed? Specifically interested in the opinions of 1) those who have used the SL1 and Rebels and/or 2) those who have been on safari or other wildlife expeditions and have thoughts on the utility or not of backup cameras
 ElQuijote617's gear list:ElQuijote617's gear list
Canon EOS 80D Canon EF 50mm F1.8 II Canon EF-S 17-55mm f/2.8 IS USM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF-S 24mm F2.8 STM +1 more
Canon EOS 80D Canon EOS Rebel SL1 (EOS 100D) Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
stratobill Senior Member • Posts: 2,081
Re: Backup Safari Body
I would think that the SL2 would be a good choice. I just got one for travel and it's really nice to have the small size. The sensor is the same as the 80D. Having said that if wide angle is what you are after a 6D might be worth looking at. Similar controls to the 80D as well, but then you might need a FF lens.
As to whether or not a second camera is a good idea, I would say yes on a once in a lifetime trip.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
bmoag Veteran Member • Posts: 3,387
Been there, done that. Wanna do it again.
As you are in the middle of nowhere, techwise anyway, a second body or second camera (like a bridge camera) is a really good idea. Along with batteries, charger, lens cleaner and more storage cards than you think if given to shooting video (you will be).
With common sense precautions you should be easily able to protect your gear from the elements.
I personally favor the travel zoom because I kind of think you will see that changing lenses is not the best idea, there is a lot of dust, and you don't really need uber long lenses. Particularly in Tanzania/Kenya you are more up close and personal with the animals then you might think. In most safaris you are up close and personal with your tour companions too who might assume they are entitled to their space in the Land Rover.
Mostly it is important to be in the moment rather than worry about taking pictures that in the long run will mostly be of interest only to you.
 bmoag's gear list:bmoag's gear list
Nikon D70 Nikon D3300 Panasonic Lumix DMC-GX8 Nikon Z6
