Gave in to temptation - got the 100-300.
Started Jul 23, 2018 | Discussions
brentbrent Veteran Member • Posts: 5,766
Re: Gave in to temptation - got the 100-300.
I recently shot with a used 100-300 Mk.I.  A lot of missed focus shots, but that could have been my error.  Some were quite sharp and nice, though.  But the manual focus ring was stiff as molasses!  I tried AF +MF, and it was simply impossible to fine tune focus with that focus ring.  How are the zoom and focus rings on your Mk. II?
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Kato777 Regular Member • Posts: 134
Yes I got the same impression, thought he meant it was better with single rather than dual IS.  Makes more sense now that he somewhat snarkily clarified.
 Kato777's gear list:Kato777's gear list
Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic 12-60mm F3.5-5.6 OIS Panasonic 100-300mm F4-5.6 II
Good info, thanks!
offtheback
offtheback Senior Member • Posts: 1,100
Mark9473 wrote:
opiecat wrote:
Mark9473 wrote:
opiecat wrote:
you got better results with no IS?
Where on Earth did you get that idea?
i guess you need to clarify what you meant when you said the difference was staggering.
"Initial impression was that at 300 mm the Dual IS2 wasn't giving me the stability I was expecting, but when I switched the IS off the difference was staggering. "
i thought it was better. i guess not
You are aware that with IS switched off, there is no stabilization, right? Do I really have to spell out that the stability is much better with IS switched on?
Your statement was ambiguous so there's no need to jump on the the gentleman.If something is amiss stabilization could certainly make it worse.Lighten up.
OP Mark9473 Veteran Member • Posts: 6,428
It feels excellent, just the right amount of resistance for my taste.
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
There is no single IS with lenses that are Dual IS compatible. It's all or nothing.
Mark
Jrsilva00
Jrsilva00 Regular Member • Posts: 229
I own the Mark I version of this lens and it is a very decent tele zoom.
Just be sure to not stick a cheap filter, or even a Hoya filter in front of it.
I've recently discover that the Hoya HMC (c)  filter I've been using for about 4 years was causing an ugly bokeh on the out of focus areas and causing image degradation.
Since I'd toke of the filter it was like getting a new lens.
Even wide open at 300mm if the subject fill most of the frame there will be plenty of detail and no need to stop down.
Only if you shoot small subjects (like birds) at a far distance you may need to stop it down a bit.
 Jrsilva00's gear list:Jrsilva00's gear list
Panasonic Lumix DMC-GX1 Olympus E-PL7 Olympus E-M5 II Olympus OM-D E-M10 II Sigma 30mm F1.4 for Micro Four Thirds +1 more
Thanks for the tip. I have given up on filters and rely on caution and lens hoods to keep the lenses safe.
Mark
