Gave in to temptation - got the 100-300.
Started Jul 23, 2018 | Discussions
Mark9473 Veteran Member • Posts: 6,428
The Panasonic 100-300 Mk.II had been tempting me for a while, but at €499 new with a 5 year warranty I ran out of excuses not to get one. My first native long lens.
It balances and handles well on my G80. Initial impression was that at 300 mm the Dual IS2 wasn't giving me the stability I was expecting, but when I switched the IS off the difference was staggering. I also didn't feel the AF was very fast - smallest square 1-area center focus - but perhaps for such a large lens that is to be expected.
We're in the middle of a heatwave here, so I didn't really feel like going out. Took just a quick snap from the front door to make sure it is working properly. I read about f/7.1 at the long end being the sweet spot, so that's what I used. Very happy with this for a quick first snap.
slightly cropped for composition
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
Panasonic 100-300mm F4-5.6 II Panasonic G85
Kato777 Regular Member • Posts: 134
Re: Gave in to temptation - got the 100-300.
I have this lens/camera combo as well.  Are you saying you get better results when you switch off the lens IS and use only the in-camera IBIS?  I.e., disable Dual IS2?
 Kato777's gear list:Kato777's gear list
Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic 12-60mm F3.5-5.6 OIS Panasonic 100-300mm F4-5.6 II
OP Mark9473 Veteran Member • Posts: 6,428
No, I get no IS at all when I switch off the lens IS.
Mark
FrankS009
FrankS009 Veteran Member • Posts: 6,557
Enjoy the 100-300mm II lens! I got one a week or so ago. I like the colours. Hand held shots are better than I expected.
F.
"We shoot the things that move us in ways that will move others." David duChemin
"What's the use of having a great depth of field if there is not an adequate depth of feeling?" - W. Eugene Smith
 FrankS009's gear list:FrankS009's gear list
Panasonic Lumix DMC-GF1
opiecat Senior Member • Posts: 2,410
you got better results with no IS?  what shutter speed(s) were you using?
i have this same combo and always wanting to know how to more keepers
'when 900 years you reach, look as good you will not' -- master yoda
http://opienc.wordpress.com
Mark Kaprielian
Mark Kaprielian Regular Member • Posts: 400
Hi
I have this lens and body but haven't used this lens much yet.
Were you doing hand-held or tripod when you tried IS on and off on the Lens?
I've often seen it written that if on a tripod you should turn off IS but I'm not sure if they mean lens, body or both. Also, on the G85 it doesn't appear you can turn off IS.
I just tried four test shots indoors with the subject being the fine print on a small bottle from 15 feet away
My results, worst to best
  • Hand Held - Lens IS disabled - Worst, clearly not a good idea
  • Hand Held - Lens IS enabled - Looks pretty good but next bullet is better
  • Tripod - Lens IS disabled - Can't tell the difference from the next
  • Tripod - Lens IS enabled - Can't tell the difference from the previous
Mark
 Mark Kaprielian's gear list:Mark Kaprielian's gear list
Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-GH6 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +9 more
Where on Earth did you get that idea?
Mark
i guess you need to clarify what you meant when you said the difference was staggering.
"Initial impression was that at 300 mm the Dual IS2 wasn't giving me the stability I was expecting, but when I switched the IS off the difference was staggering. "
i thought it was better. i guess not
You are aware that with IS switched off, there is no stabilization, right? Do I really have to spell out that the stability is much better with IS switched on?
Mark
yes, with IS switched off the is no stablization.  but maybe i thought you had some setting where you got better results hence the question. and as you can see some other folks also interpreted it as you got better results when IS was off.
so it was my misinterpretation. sorry, dude!
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
Enjoy the new lens.  I've not used mine lately, as I got the 100-400, but nevertheless it is a fine lens.  Your temptation is less costly than mine.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
Cagey75
Cagey75 Senior Member • Posts: 1,347
I'm not sure why anyone struggles with this lens in any way.  I have the mk1, which uses lens OIS only, and I can get sharp images at 1/20th without any fuss.  Also, ignore people who say this lens need stopping down, I shoot mine at 300mm 5.6 a lot, and find it plenty sharp enough.
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Fujifilm XC 35mm F2 Venus Laowa 65mm F2.8 Macro +1 more
The coatings look excellent, perhaps that's got something to do with it. I'm liking what I see too.
Mark
Hand held.
AFAIK either the lens switch can be used or the camera; it switches between Dual IS2 or IS off completely.
Mark
Thanks. I wanted a longish lens for an upcoming trip to Scotland. Little interest in something as big and expensive as the 100-400.
Mark
I have a feeling that for me, this will require some training and experience. Time will tell.
Thanks, good to know. I'll give mine some testing.
Mark
biggles266 Senior Member • Posts: 1,305
"Sweet spot"
All lenses are slightly different, don't just use it at f7.1 because you read that is its sweet spot. Do the testing yourself with your lens. My v1 of the lens is just as good wide open at f5.6 as at any other aperture.
 biggles266's gear list:biggles266's gear list
Canon EOS 6D Canon EOS M50 Canon EF 85mm F1.8 USM Sigma 50mm F1.4 EX DG HSM Canon EF 70-300mm f/4-5.6 IS USM +7 more
HRC2016 Veteran Member • Posts: 6,874
Re: "Sweet spot"
This and the Oly 75-300 II are the best m43 telezooms. I can't wait for Oly to come out with it's 200-450 next year!  Forget BIF, we'll be able to read their minds!
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
dinoSnake Veteran Member • Posts: 3,570
I'm really glad to hear that you like it! I for one feel that the Panasonic 100-300's do get not enough respect here, yes even the mk1 versions. At the long end they are 600mm equivalents, and how many 600mm lenses are precisely and accurately 100% pin-sharp? Some allowance need to be realistically made and the Panasonics are excellent performers for the length, doubly-so once you factor in their convenient size and modest costs.
Re: "Sweet spot"
I hesitated between the two but there wasn't that much price difference between the two so I chose the Panasonic. Thought that Dual IS2 and DFD focusing would make the difference.
Mark
