What are the uses of a high quality 50mm lens?
Started Jul 23, 2018 | Discussions
Barry Pearson
Barry Pearson Veteran Member • Posts: 9,625
I'm examining the question "what use could I make of the D FA* 50mm f/1.4 lens?"
I'm seeking the experiences of others who use 50mm prime lenses, and who think they will benefit further from the extra quality of this particular lens. (I'm aware of the reduced depth of field from a wide aperture, and the resulting separation of foreground and background).
Over the decades, I've evolved my photography, as a result of new interests, new opportunities, and new equipment. Often this has been a result of discussions and demonstrations from others. What I do in future is likely to be different from what I've done in the past.
I don't think I have ever done so much analysis for a single lens. I bought all the other FF lenses released by Pentax since the start of 2015, because I knew I needed them as I switched to FF. (I would have preferred a smaller, lighter, cheaper lens than the D FA 15-30mm f/2.8, but that was what was available).
This is the first time I've had doubts. The comment for this lens in my (comprehensive) gear list is: "I don't NEED this. But I do fancy it!" I'm very concerned with image quality in my results, and i'm sure the image quality of this lens is far better than all the others I've bought. But I'm not convinced I would want to be shooting at 50mm for long enough periods to make it worth having with me.
The field of view is about the same as a 35mm lens on APS-C. So I've looked back over much of the last decade to see how much I've used 35mm on APS-C, and how much I've used 50mm on FF. Not a lot, and typically not for long periods.
My eventual answer to "what would I use this for?" is mainly "people, not things, and outside, not in the studio". I'm not seeing much experience from others posting here to challenge that view. That means at most a few days a year over the last decade!
Here are the focal lengths I've used in 2018 on K-1-series cameras for the two zooms I have that include 50mm:
D FA 24-70mm f/2.8
D FA 28-105mm
(Using the Pentax 1.4x Converter with a 105mm lens gives 147mm).
 Barry Pearson's gear list:Barry Pearson's gear list
Ricoh GR III Canon EOS R5 Canon EOS R7 Venus Laowa 12mm F2.8 Zero-D Canon RF 70-200mm F2.8L IS USM +28 more
Dana F Regular Member • Posts: 163
Re: What are the uses of a high quality 50mm lens?
Looking at your numbers it appears  you like it a little wide to normal range.Little wide more so. On film a 35mm lens was my 'Normal'. I liked the wider perspective. This has followed me into APS-C and M 4/3, with a 28mm on APS-C and 19mm on M4/3. IMHO, I'd put those lens on 50mm and see if it works for you. You can also zoom and widen with your feet
 Dana F's gear list:Dana F's gear list
Olympus PEN E-PL6 Pentax *ist D Pentax KP Sigma sd Quattro Olympus OM-D E-M10 III +3 more
flektogon
flektogon Veteran Member • Posts: 6,226
I personally preferred 35mm lenses on my cameras. Especially if you had another lens in the range around 90mm. Leica/Minolta even came with a combo 40/90 (if I remember correctly) as the optimal lens selection.
Peter
zakaria
zakaria Veteran Member • Posts: 6,556
I prefer the head shots. 50mm to 100mm is the range to my daily use.
pentaxian .
 zakaria's gear list:zakaria's gear list
Pentax K-1 II Fujifilm X-H1 Nikon D780 Fujifilm X-T3 HD Pentax DA 15mm F4 ED AL Limited +8 more
BobORama
BobORama Senior Member • Posts: 2,842
The D FA 24-70mm f/2.8 is fairly sharp @50mm.   So I would see a 50/1.4 as superfluous if you don't find yourself shooting wide open.   you may want to look at the aperture used with this lens, if you are always shooting at 2.8, you may benefit from a faster lens.
I have a smc-Pentax A 50/1.4 ( manual focus ) which I still use on both K-5 and K-1 usually in close quarters.  It is a fraction of the size and weight.   At 2.8 is is very sharp.   At 1.4 its, well, not.   So I would like to see what the new 50/1.4 can do.  However it is a great portrait lens, though I tend to use the Takumar 85/1.8 ( which is similar DoF wise ) for portraiture, especially on the K-1.
But other than the slowness, the 24-70 is a fine lens.
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Pentax smc DA 18-55mm F3.5-5.6 AL WR Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Samyang 14mm F2.8 ED AS IF UMC +9 more
DougOB
DougOB Veteran Member • Posts: 3,176
f1.4 does help with AF in low light if that is important.
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax KP Pentax K-70 +36 more
Gary Martin
Gary Martin Veteran Member • Posts: 5,301
It's for those who want:
1. High quality at maximum aperture;
2. The best quality attainable from the camera sensor;
It will probably make a great studio, event and wedding lens alongside the upcoming 85mm. I know a few wedding photographers who use the 50mm focal length extensively. A similar quality 35mm and 24mm would compete a very nice set, and looking at the lens roadmap that just might be their plan.
 Gary Martin's gear list:Gary Martin's gear list
Ricoh GR III Pentax K-1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F2 R WR +9 more
(unknown member) Veteran Member • Posts: 6,680
What are the uses of any high quality lens?
Barry Pearson
OP Barry Pearson Veteran Member • Posts: 9,625
I think this metadata may be relevant. It takes into account all lenses I've used in 2018, not just those which include 50mm in their range.
The vast majority of my photos are taken at long focal lengths, for example 450mm.
It appears that, whatever zoom lens I'm using, I tend to use it more at the extremes than at the middle. Hence the peaks at 15mm, (24mm a little), 28mm, 105mm, 150mm, and especially 450mm.
(450mm in combination with the Pentax 1.4x Converter = 630mm).
I'm not sure what message I'm getting from this!
Barry Pearson
Good thinking!
I just examined the metadata for the D FA 24-70mm f/2.8 for 2018.
It appears that I am not a "shoot at wide aperture" person.
I appear to follow the prescription, (perhaps from Weegee):
f/8 and be there
DougOB
Every zoom I own shows this pattern of use.  I would call it a "universal truth"
Doug
mxx
mxx Senior Member • Posts: 1,250
I think this lens is not as much about focal length and max aperture as it is about rendition. If the rendition is superior, I think you will find many uses for it that you probably would not have thought of beforehand.
 mxx's gear list:mxx's gear list
Sigma DP3 Merrill Canon PowerShot SX50 HS Sony Cyber-shot DSC-V1 Pentax K-5 Pentax K100D +11 more
brett nz
brett nz Contributing Member • Posts: 597
I agree - and to date the sample images from the new 50mm are making me wish I could afford it and I dont shoot 50mm. C'mon guys - do you not "see" the IQ of this lens - I cant wait to see more images from it
cheers
Brett
 brett nz's gear list:brett nz's gear list
Pentax K-1 Pentax smc FA 77mm 1.8 Limited Pentax smc FA 31mm F1.8 AL Limited Pentax FA 15-30mm F2.8 Pentax FA 70-200 F2.8 +2 more
Barry Pearson
Interesting!
I suspect there is another "universal truth", which is particularly relevant to this thread:
"When you have a prime lens on the camera, you seek subjects that exploit that lens".
That is why I intend to hire the D FA* 50mm f/1.4 lens for a few days. My guess is that I'll end up with photos that I may not have seen or even thought about when I have a zoom lens on the camera.
I've started to look afresh at the photos around 50mm that people post in this forum, wondering "is that something I should try?"
Barry Pearson
So far, I think "bokeh" and related rendition aspects may turn out to be the deciding factor for whether I buy this lens. It is probably the hardest result to achieve by other means.
It is one thing I'll pay particular attention to when I hire it for a few days.
Holger Bargen Veteran Member • Posts: 4,911
This guy has some reasons for the 50 mm lens:
https://www.youtube.com/watch?v=rgLDxAF2GI4
You can't compare a zoom based gear with a primes based gear - and if you look at primes the 50 mm lens is a centre point in your equipment - the most versatile focal length.
Best regards
Holger
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Sigma 105mm F2.8 EX DG Macro Sigma 17-70mm F2.8-4 DC Macro OS HSM +7 more
James O'Neill Veteran Member • Posts: 6,117
"High quality" is a always a dangerous term because it is a euphemism for expensive and various other things. Early in my working career I was  a company which had embraced Japanese-style quality philosophy and we got taught that "Quality is meeting the customers needs".  The product which the customer can't afford doesn't meet their needs.
Some customers need a lens which is robustly manufactured and endure the pounding the professionals give their equipment and not fail. Some need to extend that to working in extremes of temperature, moisture, dust etc.
Some prefer small and beautifully engineered (like the 3 amigos) to large lenses even if it means accepting compromises in image characteristics. [I'm in this camp]
Wide aperture is not "quality" of itself but if you work in low light conditions and or you shoot a lot of portraits where you want to separate the sitter from the background, an extra 3 stops makes the big difference in whether it meets your needs or not.
The same is true of AF, speed and noise may be irrelevant or may make the difference between meeting your needs and not meeting them.
There a plenty of people who like the way old lenses render, though the colour accuracy and sharpness leave something to desired. Others want the ultimate in detail. I bought and returned the 15-30 because I couldn't live with its mass; the arguments on here of late show that I can't think in the mindset of those who would carry a lot more bulk to get the last tiny bit of detail / sharpness (what is the delta between my mid-range tripod and one which weights another 25lb / 10KG ?) and they can't see why someone would compromise on image quality to save a bit of weight. If we're going to get along we'll need to accept the validity of p.o.v we don't share or even understand. Initial sales reports of D-FA * 50 suggest there are a lot more people who prioritize that extra quality than I first thought.
Then you have the question of what focal length; and what I have come to think of as the zoom fallacy. A prime is lighter than a zoom (doh!) and only an expensive , heavy zoom gives a wide aperture. (I've never seen a zoom wider than f/2, you can get an f/2.8 which is equivalent to 28mm f/2.8 prime or a 135mm f/2.8 prime). A prime might well offer better image characteristics.  But a zoom saves having to change lenses in adverse conditions, and might save carrying half a dozen primes so gives a lighter camera bag.
But here's a question  a 28-105 is a 28 , a 29, a 30 ... a 104 and a 105 all in one, you can always you the optimal focal length. But your 28-105 stats (and mine) show more than half the pictures are taken at the two extreme focal lengths (you'd use longer or wider if you had them) So a 28, a 135 and a 43 or 50 or 77 might be a better solution
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-1 Pentax K-5 IIs Pentax smc FA 77mm 1.8 Limited Pentax smc FA 43mm F1.9 Limited Pentax smc DA 18-250mm F3.5-6.3 +3 more
Raghu R Senior Member • Posts: 1,362
Perhaps the results from another 50mm brand which is also a fast lens could possibly inspire you .
50mm fast lens
The possibility of usage is always endless when you have an artistic imagination and execute that into reality in such a way others appreciate your work.
Bye,
R.Raghu
'The Photographer reveals the light;the light reveals the picture'--C.Rajagopal.
A picture should communicate with our heart.
Efzee-50 & Foojee F 31fd---Polaroid X-530
http://farm2.static.flickr.com/1314/963380256_5f4284b2ce_o.gif
 Raghu R's gear list:Raghu R's gear list
Pentax K-x Canon EOS 6D Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited HD Pentax DA 21mm F3.2 AL Limited +11 more
Barry Pearson
When I first used Pentax SLRs, I started with an 85mm f/1.9 lens. (I didn't find 50mm useful). Then I added a 35mm lens.
(I had a 50mm lens on my non-interchangeable-lens camera before that. I think that experience is what put me off 50mm).
Barry Pearson
The first line of my original post was:
So I'm specifically interested in the special attributes of that lens.
I worked for a company (ICL) that adopted Crosby's principles. That is number 1.
There's often not enough time to change lenses.
