Does anyone have a fix for "Check Status of a Lens" on Oly 14-42 II R?
Started Jul 22, 2018 | Discussions
Humansvillian
Humansvillian Veteran Member • Posts: 3,013
Today my PM1's 14-42 II R kit lens started showing "Check Status of a Lens" like the one that came on my PL1 I bought two years ago.
It costs $75 plus postage to have Oly rebuild them.  You can buy one attached to a camera for hardly any more than that.
Both my crippled lenses are still usable, and it must be something internal in the zoom, because they'll work wide open and only if screwed down past 25mm do they start throwing the error code.
Has anybody messed with trying to fix one at home?
Any help would be much appreciated.
Humansville is a town in the Missouri Ozarks
 Humansvillian's gear list:Humansvillian's gear list
Olympus TG-5 Olympus PEN E-PL1 Olympus PEN E-P5 Olympus E-M5 II Olympus 12-40mm F2.8 Pro +22 more
shinndigg Veteran Member • Posts: 4,690
Re: Does anyone have a fix for "Check Status of a Lens" on Oly 14-42 II R?
The electronics ribbon is going bad. I have bad ones two also. One I bounced on a concrete gym floor, the other I bought used and it worked fine for two years. So, I decided to upgrade to the 12-50 instead of paying for a repair that will likely go bad again in a few years, though $75 isn't that bad
shinndigg
www.pbase.com/shinndigg
 shinndigg's gear list:shinndigg's gear list
Panasonic Lumix DMC-FZ35 Olympus E-510 Olympus PEN E-PL1 Olympus E-M1 Olympus OM-D E-M10 +9 more
hindesite Veteran Member • Posts: 4,893
Personally, I wouldn't bother replacing the lens with the same one, or repairing, we have better choices now.
One of mine has failed and I think these early collapsible lenses were a bad idea. The ribbon cable fails with even minimal use.
The Lumix 14-42II is a much better lens in all respects, and the 12-32 is so much smaller.
Sun Ra New Member • Posts: 2
The Oly 14-42 II kit lens is a mess. From the IQ point of view, it is a pretty good one. But after doing some research, it's a lens manufacturing design's fault. The flex cable of zoom mechanism will always have to be stretched and folded during use. So after a while, any Oly 14-42 II will more llikely gives the "Lens Error".
I tried to open the lens to see where the problem is. But ended up having unusable lens at all. All parts were so tiny. The screws were all within around 2mm small.
What I'd do is just get a Panasonic 14-42 II or 12-32. Or if you want to step up, just get 12-35 / 12-40 F/2.8.
Humansvillian
OP Humansvillian Veteran Member • Posts: 3,013
I'm down to one good one, and I just dropped it
I got a Panasonic Lumix 20mm f1.7 in the mail today, and took the one good 14-42 II R lens I had off my PM2 and shot some pictures with my new lens.
I came home with the old kit lens in the Lumix sack, and dropped it on the concrete floor of my garage.
It bounced, and it still works, but it's days are numbered.
The best solution, is to upgrade to a pancake prime, and leave those old crippled lenses as beater lenses to shoot from 14 mm to 25mm on old cameras
Once you've had a sharp prime like the Panny 20mm f1.7, your thrill of little kit lenses, is gone.
I have a 12-50mm Oly if I don't care how big my lens sticks out.
Thanks for all your help.
Sometimes you just need to give up cheap stuff and move forward.
yanisha Senior Member • Posts: 2,630
Kit lenses can make some great photos
I have the Olympus 25mm f1.8, Olympus 45mm f1.8, Panasonic 20mm f1.7, and Panasonic 14mm f2.5.  Also, various other zooms including the Olympus 14-42mm EZ, Olympus 14-150mm II, and Panasonic 14-42mm.  I sure like the primes, but I sure like the zooms too, including the 14-42mm and 14-150mm.  I don't notice all that much difference in the quality of photos with the various lenses.  I guess I have been doing this for a long time so have progressed way beyond getting all wound up about lenses and so on.
I have never had the Olympus 14-42mm R though so I can't speak about it.
Humansvillian
Re: Kit lenses can make some great photos
I have six Olympus bodies to play with, and outside in good light the 14-42 II R is a sharp lens, but it's not flat.  The 12-50 Oly is just a better all around lens than the 14-42, because it has a usable macro setting, is wider and longer, has electric zoom for remote shooting, it's weatherproof, and it's the difference between a $500 and a $100 lens.
The fast primes are best used for sneaking around with a smaller body like the PM1 or PM2 and have faster apertures.
I'm learning all this as I go along, and when I want a zoom, forget  stealth.
The little cameras get the 17mm Oly f2.8 for the PM1 and the 20mm Panny stays on the PM2.
The M10's and the M5 II, can use the zooms.
A better purchase would be the 12-40 f2.8 pro, for about $600, and put that on the M 5 II and leave it.
