How did SquareTrade reset Canon Rebel T6i shutter counter after shutter replacement?
Started Jul 21, 2018 | Discussions
KierstenCDG Junior Member • Posts: 30
My father bought a Canon Rebel T6i from Amazon.com(camera sold and shipped directly from Amazon itself, not 3rd party seller) a few years ago.   I urged him to buy the SquareTrade 4-year protection from Amazon a few day later, for just $110.   He begrudgingly did, but said it was just money down the toilet.
Well... it turns out that I was right... because the camera needed to have the shutter replaced.  The hinge(or whatever the thing with the metal spring was called) had cracked and the shutter was stuck hafway.
He dropped it off using SquareTrade's shipping label and 9 days later, it was delivered back at his front door.   The shutter was apparently replaced.   They also replaced the hot shoe(which had become a cold dead shoe because it wasn't sending anything to the external flash).
I was playing with it this morning and it worked perfectly. The new shutter mechanism has a slightly brighter color than the one that had cracked, perhaps it's an updated part?   My father never cleans his camera gear, so they are usually kind of nasty. The tech apparently also cleaned up the camera and it looked cleaner than when it was new.
Anyway, I started poking around and one thing that I noticed was the shutter counter had been reset. It is now at 27.   When it was sent back, the counter was a little over 14,000.  Is this something that camera repair companies(such as SquareTrade) is allowed to do?
Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
Dareshooter Veteran Member • Posts: 5,842
Re: How did SquareTrade reset Canon Rebel T6i shutter counter after shutter replacement?
If the camera has had a shutter replacement then the shutter count should reflect that.  You didn't expect the repaired camera to report the old shutter count did you ?
justmeMN Forum Pro • Posts: 10,718
That sounds appropriate to me. When you get new tires, you don't count the miles that were on the old/previous ones.
Greg OH Regular Member • Posts: 456
Are you sure they didn't just replace the whole camera?
 Greg OH's gear list:Greg OH's gear list
Panasonic Lumix DC-S5 Samyang 14mm F2.8 ED AS IF UMC Samyang 24mm F1.4 Samyang 35mm F1.4 Panasonic S 24-105mm F4 Macro OIS +4 more
pixseal
pixseal Veteran Member • Posts: 4,061
I understand you (and agree), but the OP's question was how did the shutter count get reset.   Canon has made difficult to even read the shutter count.
 pixseal's gear list:pixseal's gear list
Canon EOS R7 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 500mm f/4.0L IS II USM Canon EF 100-400mm F4.5-5.6L IS II +14 more
(unknown member) Senior Member • Posts: 1,388
With software ?
https://www.spt.info/index.php/service-adjustment-software
pixseal
stevedavidsonphotography wrote:
With software ?
Thanks for that.
The OP also asked if resetting the shutter count was something  that square trade was allowed to do and I responded accordingly.
