Went to get a G80 and ended up with an A7..tips from M4/3 and FF users?
Started Jul 19, 2018 | Discussions
Treadurownpath Regular Member • Posts: 184
Firstly, this is not a M4/3 bashing thread. I have been using M4/3 since 2013 now. I have a GX80 and several moderate lenses including 20mm, 14mm 12-32mm and 45-175mm. I travel a lot and love the size and features of my GX80.
However, I have just become sick of the GX80 viewfinder and was a little bit disheartened to find that they have used the same model, complained about since the GX7 days, in the GX9. It is not even the colour tearing that bothers me, it is the ratio and size, like peering through a tunnel. I use the viewfinder for essentially all of my compositions.
So I set off to get a new camera. The GX8's flawed shutter and IBIS system ruled that out so I looked at the G80.  It's great, but the Sony A7 came up on a prime deal for £570 (including cashback) with kit lens. I just couldn't resist.
I have not had a big chance to try it out but am instantly noticing the bigger viewfinder. The menus are not as complicated as people make out and overall it seems fine to use. A big miss if the lack of touchscreen AF. All in all, the GX80 is quicker in every respect and more fully featured, but then I think well most of my shots are landscapes or general travel photos like portraits, do I really need any more speed than the A7.
Moreover, although I love the functions of the GX80 like 4k and its various 4k photo modes, in practice I barely ever use these. I'm a pretty traditional photographer from that point of view.
So currently I'm assessing the image quality difference, especially in relation to my needs and weighing up whether an A7 with the 28 F2 and 50 F1.8 would actually meet 99% of my photography needs. I may yet still run M4/3 parallel to this though with a couple of zooms for video and wildlife....or I may just get a cheapy FZ1000.
In any case, I was just pondering what other people's thoughts were on running both systems and if any M4/3 users can help me with tips to adjust to FF. I really am a noob in this area!
Who knows, perhaps the FF IQ won't capture me and I'll merely keep my GX80!
Panasonic FZ1000 Panasonic G85 Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85 Sony a7
jalywol
jalywol Forum Pro • Posts: 12,301
GAS is a terrible thing....
12
First of all, the IQ of the A7 will blow the GX80 out of the water. Having owned an A7 system as well as M43 for ages, I will tell you that the files from the A7 are a joy to work with, especially if you use low light or higher ISO. (However, the difference between the A7 and the GX8 is quite a bit smaller than the difference between the A7 and the GX80...keep that in mind when you make your decision.)
That being said....After 2 years with my A7, I sold it and returned to M43, with yes, that "flawed" camera you refuse to consider, the GX8. I actually prefer the GX8 in almost every way to the A7. Yes, you get the better sensor with the A7, for sure. But you also get wonky white balance and inconsistent color rendition, SLOW AF (not so much in daylight, but the A7 is awful in low light, which is a royal pain, especially when you have been used to Panasonic's excellent low light AF capabilities); expensive, and not great, lens selection, and no stabilization at all unless the lens has it. Add to that the refusal of Sony to activate sensor based PDAF in that camera for non-native lenses, and it means you have to use the expensive and touchy LAEA4 adapter for A-mount lenses, and it won't AF with adapted Canon lenses (unless you want to wait a week while it gets around to it).
Now, on the plus side, working with FF will give you a very different perspective on DOF effects and it's a great learning experience. I learned a lot about subject isolation and composition while working with it, and that was very valuable. As a matter of fact, I would add in another FF to my system again, if anyone other than Sony comes out with a mirrorless FF system (and I can afford it at some point), for wide to normal work in lower light, which is where M43 is at its weakest. However, since I spend most of my time out at long tele ranges, M43 (GX8 and 100-400mm) is a more versatile system for me at this point overall, so it's what I have and enjoy now.
So, moral of the story?  The A7 is a pain in the butt to use.  Later models rectified many of the flaws in that particular camera (although not the color rendition), and you would be far better served by buying one of them instead of the A7.  I personally would recommend the GX8 over the A7 that you are considering, actually....Much better camera, and the world's best EVF. By the way, I bought my GX8 after almost being totally put off by the hysteria about SS and the stabilization, and I realized that the entire issue was hugely overblown.  I use e-shutter about 90% of the time, and when I switch to the mechanical shutter, I don't have the problems with it that I thought I was going to, either, so it's a non-issue for me.  The stabilization is mediocre, but, to use that as an excuse when you are going to be buying a camera that has NO IBIS at all, is kind of an odd argument....
Anyway, my advice?  If you want to dabble in FF, then go for the A7.  It's a great learning experience.  Just keep in mind you are getting a body that has some major flaws, and it may not be all you want it to be.....
-J
ahaslett
ahaslett Forum Pro • Posts: 12,654
Re: Went to get a G80 and ended up with an A7..tips from M4/3 and FF users?
Missing IBIS, OSPDAF that only works with Sony lenses, unreliable weathersealing, sensor reflections and a kit lens that's not very good.  My first gen Sony is an A7R, so I'm not familiar with A7 functions.  However I suspect that they are pretty clunky.
I'd get a used 28mm quickly, if you want to discover why people still use this camera.
I agree with Janet that the increase in your shooting envelope will be educational.  Shoot RAW and use the free C1 Pro for Sony.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Fwestivus Regular Member • Posts: 118
Watching the thread with interest.
I've got an A7ii and Samyang 14mm f2.8 and 35mm f1.4 on the way to me thanks to the prime 20% off warehouse stuff. It'll be interesting comparing the 35mm with my Sigma 16mm handling-wise etc.
Not sure if I'll keep it, though - I'd definitely miss weather sealing, silent shutter and being able to hand hold at silly speeds with the 100-400mm.
 Fwestivus's gear list:Fwestivus's gear list
Panasonic Lumix DC-G9 Panasonic G90 Olympus 12-100mm F4.0 Sigma 30mm F1.4 for Micro Four Thirds Sigma 16mm F1.4 DC DN (MFT) +2 more
john isaacs Veteran Member • Posts: 8,442
I was following you till the end, where you were willing to use an FZ1000 for anything the A7 and a wide + normal prime lens couldn't do.
Personally, I get most of what I need from m4/3.  I shoot Nikon (D750/D500) when I need the extra that it gives, but the sacrifice in cost and weight is only worth it for extreme conditions.  I have as much (or more) invested in my Nikon gear as my m4/3 gear; full complement of lenses, flashes, remote triggers, larger camera bags, etc.
If you want to dabble in FF, then that's good.  But I just don't see going to FF for IQ and then using something else because you don't have enough gear to cover your needs.  Of course, if all you need is a 28 and 50 mm lens, then that's great.
(unknown member) Forum Pro • Posts: 11,837
Why just Sony
I am a bit mystified why Sony is always seen as the FF alternative to M43.
I am testing the FF waters myself at the moment. It all started when I bought a 28PC lens and found my Nikon D300 did not get the most out of this lens due to the restricted angle of view.
I found an incredibly cheep hardly used D700 to sit behind the lens. Playing around I was quite shocked at the image quality that even this elderly camera gave me. A SH 24-120 F4 was quickly added. The whole lot cost me less than the planned 12-100 was going to cost.
I think it is also worth considering the traditional DSLR if you want to dabble in FF, a used D750, D800 or D610 for example a fine camera. Nikon has a certain pedigree that Sony does not have and it probably shows in some practical areas like menus and white balance.
The files from my D700 are much easier to work with than those from my EM5 and they have a certain creamy quality that I like. M5 EM5 files seem to be a bit more “gritty”.
For some strange reason that I cannot understand, I have enjoyed the return to a good optical viewfinder.
BTW, the D700 24-120 is not as evilly heavy as a carry around camera as FF is sometimes made out.
jalywol
Re: Why just Sony
Mirrorless, mirrorless....if you prefer an EVF, and want to use adapted lenses, mirrorless makes more sense.
I bought a D750 last year, and liked it, but the particular one I got ultimately got returned as it had a focusing issue. Even though the D750 is a very nice camera, I still prefer working with mirrorless, personally, but won't touch another Sony.
It's bulkier, and not terrible, but the D750 24-120mm was enough to give me significant wrist pain, unfortunately. I'm hoping the Nikon mirrorless FF that is rumored will be a little more svelte overall (not that I can afford it at the moment)....
-J
Sranang Boi Senior Member • Posts: 2,860
8
So you were so concerned about the IBIS of the GX8 that you bought a camera without IBIS instead. I am a GX8 owner, and find your explanation difficult to digest.
 Sranang Boi's gear list:Sranang Boi's gear list
Panasonic Lumix DC-FZ1000 II Panasonic Lumix DMC-GX8 Panasonic G90 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +1 more
ahaslett
Re: Why just Sony
Sony sensor, Canon lenses, EVF MF.
Andrew
OP Treadurownpath Regular Member • Posts: 184
Ok, I've been completely called out on the concept of complaining about the IBIS in the GX8 whilst buying a camera and considering lenses without any IBIS at all. Completely fair point on that one haha. I guess what I mean is, is that it is hard to swallow swapping a GX80 for the GX8 in some ways, knowing that the shutter and IBIS has been improved, whilst testing out FF seems like something entirely different altogether.
Guys, the GX8 is a fantastic camera no doubt and the staunch defense of it clearly indicates that. In fact, it is convincing me almost to get one (maybe when they get even cheaper second hand) for use with a longer zoom (100-300 perhaps) for wildlife.
Someone also questioned my use of an FZ1000. Again, this is just for wildlife when I'm travelling (safari/rainforest etc). I am not interested in BIF etc. However, these trips are not extremely frequent so I don't want to spend a fortune on this setup. However, the GX8 setup above could be great.
Honestly, I think I was getting to the point where the only lens I really thought that the IQ was special was the 20mm. The others don't quite have that pop. The 14 is unimpressive etc etc. So I was looking at getting something like the 15mm but its fairly costly so I thought hey, lets try an A7 with a 28mm which is only working out a couple of hundred quid more expensive including the camera body.
So an A7 system (upgraded infrequently) with a 28 and 50 for landscapes and travel (the vast majority of my shooting) and a GX8 with a 100-300 (I dont think I can afford the 100-400) and maybe even a 12-35 for video etc somewhere down the line in the future might be my future setup.
3dwag
3dwag Veteran Member • Posts: 4,674
Re: Why just Sony
In my case, it would be the combination of mirrorless and video which would lead me to consider only Sony if looking for a measurable jump in IQ.  If video were not important, I would also consider Fujifilm’s MF, albeit at an even higher entry cost.
This is all fictional for me as, unless I develop some commercial requirement for >IQ and lenses not available in μ4/3, I have no real need.  If such a need ever develops, I would be adding a second system, not replacing my current one.
-Dennis W.
Austin, Texas
¯\_|’_’|_/¯
http://www.pbase.com/3dwag/image/97156660.jpg
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
New Day Rising
New Day Rising Veteran Member • Posts: 6,635
I have a set of m4/3 gear and a Sony A7ii. The Sony is better for wide angle (I have two native lenses, going out to 16mm) and for low or difficult light. By the latter I mean things like sunny conditions with deep shadows - it can pull a lot of detail out of those. I find the Sony has a bit more detail and a kind of indefinable quality to the images.
The m4/3 gear lets me go more compact, gives me a bit more versatility with its more affordable lens selection and lets me carry up to 600mm equivalent in a tiny package.
Interestingly, my EM1.1 body is the same size as the A7ii body; the size of the lenses is where the difference comes in.
Happiness lies in thinking or doing that which one considers beautiful - HIK
 New Day Rising's gear list:New Day Rising's gear list
Nikon D7200 Sony a7R II Olympus OM-D E-M10 II Fujifilm X-T2 Sony RX100 +15 more
I use the GX8 and G80. IBIS and shutter on the GX8 are of an older generation, but I don't notice it. Once you get the hang of that camera it is easy to find solutions for the shortcomings. The advantages however can only be replicated with the use of several cameras. But the G9 would have been the better option in your case. It's worth looking at in the future.
richj20 Forum Pro • Posts: 10,181
Say what? Each to her/his own, I suppose, but I don't encounter a "flawed shutter and IBIS system" at all.
I use both Panasonic MFT and Sony FF. As far as tips, well, you have to have a reason for wanting more than one system. Adjusting is a matter of gaining experience through practice in the situations where you want FF.
Everyone's needs are different. 35mm and 50mm meet 90%+ of my needs with my Sony.
I also use an FZ1000 for certain things: outdoor picnics, and the like, where 25-400mm is quite handy! It's a 1" sensor, of course, so how the final image is used is a consideration.
- Richard
darg Contributing Member • Posts: 504
Are you sure that the A7 is the right camera when you are complaining about the evf in a M43 camera?!
I"m splitting between M43 and FF (A7ii) and the mentioned differences and pros/cons in regard to image quality are what I also see. The better low light/higher ISO quality of the A7 is worth the try and you can pull much more out of the shadows than with M43 RAWs.
I'm using mine also mostly for the wide angle application via adapted lenses but the evf is far behind what Olympus was doing with the VF-2 and the evf in the EM10ii. It's much darker than the ones I mention here so i had to get a larger eye cup which shades the eye better against light from the side. Also the distortion in the diopter glass at neutral requires getting used to. Something that I don't have with any of the Oly cams.
Also the sensor cleaning/dust on sensor will be a pain since you are used to what Panasonic is doing. Oly and Pana are so much better in keeping dust off the sensor than what Sony is doing.
let us know how it's going for you.
When in doubt, C4
KJ6EPH
 darg's gear list:darg's gear list
Canon PowerShot A80 Olympus E-500 Olympus PEN E-P3 Panasonic Lumix DMC-GM1 Sony a7 II +12 more
jalywol
Well, the only lens you have that IS special is the 20mm. If you want pop, you need to look at some of the PL lenses, or the higher end non-PL zooms (12-35mm f2.8, 35-100mm f2.8, for example), or some of the better Oly lenses. There is a big difference in output between any of those level lenses and the ones you have.
Be forewarned; the 28mm e-mount Sony is very sharp, but has really murky color rendition. I did not buy one because of that. Instead, I used a 28mm adapted Minolta AF (A-mount), which was just lovely. Remember; lenses each have their own unique qualities, and a basic lens in M43 that does not give you the punch you want is going to be paralleled by the basic lenses in pretty much any other system. To get better output costs more $ in the lens department, no matter what the brand system you use.....Sensors cannot compensate for mediocre glass, no matter how good they are.
-J
These two were from the A7 and the 28mm Minolta AF lens:
Rens
Rens Senior Member • Posts: 1,987
Re: Why just Sony
I hated that 'gritty' look on EM5 files (especially after my D700 files).
I quickly changed the EM5 for a GH4, which I much preferred, and now have the better still 'grit free' G9.
Rens
There are optimists and there are realists
 Rens's gear list:Rens's gear list
Panasonic Lumix DC-G100 Panasonic Lumix DC-S5
FrankS009
FrankS009 Veteran Member • Posts: 6,557
I am another GX8 fan. Perhaps the most under-rated and most unjustly maligned m4/3rds camera, and extremely satisfying to use in real life.
F.
"We shoot the things that move us in ways that will move others." David duChemin
"What's the use of having a great depth of field if there is not an adequate depth of feeling?" - W. Eugene Smith
 FrankS009's gear list:FrankS009's gear list
Panasonic Lumix DMC-GF1
ntsan Senior Member • Posts: 1,029
I got Sony 28 f2 and Zeiss 55 f1.8 for A7III, and zoom lens on my GH5S.
Zoom lens for a7 is much bigger than m43 in general, and bokeh on wide angle is harder to achieve on M43, so I got both for their strengths accordingly.
I used to have FZ1000 but got TZ110 for travel instead, much more compact but still have 1inch sensor. For daylight shooting having slower lens doesnt matter too much to me.
 ntsan's gear list:ntsan's gear list
Nikon Coolpix 5400 Canon EOS R5 Canon EOS R7 Sigma 18-35mm F1.8 DC HSM Art Canon RF 50mm F1.8 STM +4 more
eques Veteran Member • Posts: 4,115
Good choice.
I think Sony FF (A7 or better A7ii) with superior DR and res is a great choice for landscapes, I am toying with the same idea; add a few small lenses like the 2/28 and Samyang 2,8/24 and a longer lens, you get an excellent lightweight gear. Keep M43 for tele. It is always good to have 2 cameras ready in the bag. At the momentfor me this is the Ricog GR for wide angle and the GX7 with 60 macro or 40-150R.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
