I am as dull as whoever wrote the EOS M100 Manual
Started Jul 19, 2018 | Discussions
mangurian Senior Member • Posts: 1,187
In the menus I go Custom Function II and select AF/AF lock, no AE lock (#2).
I press SET.  Now when I shoot in non-auto mode, should pressing * lock my focus or what ?
Basically, I am not sure how I use the custom buttons.
Would a  kind M100 owner please reply with a "Custom Buttons For Dummies" please ?
When I wrote up procedures for  operating submarine electronics, producing something like the custom button part of the manual would have been a career-ender.  The M100 is an entry level camera and therefore, some of the users are also entry level.
Canon EOS M100
tamaraw35 Contributing Member • Posts: 784
Re: I am as dull as whoever wrote the EOS M100 Manual
I don't have an M100, but I believe the same menu option is available on all of the m series cameras. Essentially, that option changes the button that initiates af. By default, af is engaged with a half press of the shutter button, while this option changes it to pressing the * key. Doing this allows one to use the back button focus technique. Holding down the * key will activate af, while releasing it will lock focus. For stationary subjects or subjects that maintain a constant distance, you could focus once and then take several pictures without needing to refocus in between each one. If you have servo AF on, holding the * key will continuously focus on objects, which could be useful for timing shots while tracking moving subjects. If you don't like this, just change it back to the default setting.
Custom functions just change some behaviors and button keybindings, depending upon how you like to use the camera. Hope this helps!
J Peters Contributing Member • Posts: 759
+1 from me. I have the M5 but the manual still sucks. I know exactly where you're coming from on this.
I also have mild dyslexia so AE and AF look similar on the page and I really have to stare hard at it. Otherwise I read "AF/AF lock no AF lock"
OP mangurian Senior Member • Posts: 1,187
Dareshooter Veteran Member • Posts: 5,842
Same here .I got the M50 and thought the manual was written by someone who writes instructions for flat pack furniture.
I started writing a full response to the original question, and found I couldn't. The first two options are fairly simple to grasp, but the latter two (AF/AF Lock, no AE Lock and AE/AF, no AE Lock) are completely barmy in the way they are labelled and described. The M5 manual even says the latter combination "enables exposure compensation by pressing the shutter halfway". The M5 has a separate exposure compensation dial, so I have no clue what it's talking about. I assume this is a typo.
All these modes also behave differently depending on:
  • One-shot or Servo focussing engaged
  • Evaluative metering versus one of the other metering modes
so you really need a table of outcomes for the various scenarios.
I did find an internet search brought up this page which was helpful (although it's for the Rebel, the principles are the same)
https://www.dummies.com/photography/cameras/canon-camera/canon-rebel-t3-series-cameras-customizing-exposure-and-focus-lock-options/
Thanks for the "dumm100ies" link.
Bejersey
Bejersey Forum Pro • Posts: 15,383
It's so bad...should be written by a photographer. Look up b/w and all you see is the grainy and they should mention picture style...which there they choose monochrome.
Rick
telefunk
telefunk Senior Member • Posts: 2,652
I sure appreciate an excellent thread title!
 telefunk's gear list:telefunk's gear list
Casio Exilim EX-ZR800 Casio EX-ZR5000 Fujifilm X-A5 +5 more
