S5 Strange behavior while turned off...
Started Jul 15, 2018 | Discussions
PaulSnowcat
PaulSnowcat Senior Member • Posts: 1,379
I've bought an S5 Pro recently. It shoots well, everything seems to work fine, but it behaves strangely when turned off.
After I turn it off with a CF card inside, it begins flashing it CF activity LED. One short flash in 2 seconds... It does so for some time (I am not sure how much exactly, but more then 20 mins and less then 3 hours). Then this strange behavior stops.
While this led flashing does on, camera drains it's battery. Yesterday I've gave it a fully charged one and turned it off and today it has 3 of 5 marks of charge.
Anyone knows what is it all about?
Camera firmware - 1.09 and 1.12 (same happens with both), batteries are original NP-150 from Fuji, not new but nod dead, like 20% usage.
 PaulSnowcat's gear list:PaulSnowcat's gear list
Panasonic Lumix DC-S1R Tamron 100-400mm F4.5-6.3 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6
Fujifilm FinePix S5 Pro
JdKen Regular Member • Posts: 193
Re: S5 Strange behavior while turned off...
Strange, have you tried a different CF card?
Also, was the card formatted in the camera, and then again after you've put it in another device to get the photos off? I seem to recall that Macs, for example, write additional data to the card which might cause problems. I use an app on my MacBook to wipe those files and eject the SD cards I use with my cameras.
 JdKen's gear list:JdKen's gear list
Fujifilm FinePix X100 Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro Nikon AF Nikkor 35mm f/2D Nikon AF Nikkor 85mm f/1.4D +3 more
PaulSnowcat
OP PaulSnowcat Senior Member • Posts: 1,379
Yep I've tried 2 different cards. One from the time of S5, a 45x 1GB card and one I've bought yesterday - 133x 16Gb Transcend.
Bith Cards were formatted in camera or course. I don;t have any other devices that use CF cards. Lucky me I have a cardreader for that ancient format lol.
Maybe try a full reset of the camera if you haven't already. I have no idea if that's something that is good to do with the S5 when you've upgraded or downgraded firmware but it's worth a shot.
Returning to the point about extraneous data written by some computers - did you format the card again in the camera after you had used the card reader?
PaulSnowcat
I will try all that, thanks!
robert1955 Veteran Member • Posts: 7,302
This is a weird problem, so I only have some weird questions:
- is anything written to the card after shutdown (you'd have to know at what time by the camera clock the last image file was written)
- maybe try to find if there are hidden files
- does his camera have an auto-turn off after x time? does that change behavior?
- is there some sort of write protection, physical on the card or in camera settings?
