EOS M5 Mode Dial Fell Off
Started Jul 13, 2018 | Discussions
David Hull
David Hull Veteran Member • Posts: 6,831
Has anyone had this happen?  It appears to be just a little metal cap that apparently is affixed with three little dots of adhesive.
The camera is still under warrantee, but I will be making a trip in a couple weeks where I want to use the camera so there is not enough time to ship it to Virginia get it fixed and get it back.
It appears that I can just put the mode dial cap away and turn the plastic part underneath since the settings show up on the camera display anyway. I can send it in when I get back. It seems reasonable, anyone done this?
Great camera but I think they need to get some better glue
 David Hull's gear list:David Hull's gear list
Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +1 more
casey1823
casey1823 Senior Member • Posts: 1,856
Re: EOS M5 Mode Dial Fell Off
I had the same thing happen on my 7D II. I hope it does not happen on my M5. I think it's fairly common, but a pain. Yes they need more or better glue.
Casey
 casey1823's gear list:casey1823's gear list
Fujifilm XF 200mm F2 Fujifilm X-T4 Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm XF 16mm F1.4 R WR +6 more
Nismode New Member • Posts: 8
Happened to me as well. Shame because I was looking to sell the camera but buyers think the camera was abused
Can't even find a replacement to purchase separately anywhere...
justmeMN Forum Pro • Posts: 10,706
Have you asked Canon if they will fix it for free? Even when a warrantee has expired, companies sometimes do that, for things that "shouldn't happen".
David Hull
OP David Hull Veteran Member • Posts: 6,831
They fixed mine for free, even though it was a month out of warrantee when I finally sent it in.  I suspect you could glue it back on yourself if you were careful. I think that is how it is affixed normally.
Rock and Rollei Senior Member • Posts: 2,899
Happened to me with an EOS 6D long out of warranty. I kept trying to glue it on, it kept falling off. Eventually, I ordered one from an approved repairer, and it's still going strong.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
fstopx2 Senior Member • Posts: 1,088
S2000 glue by the people that make Goop. I have attached things with it that you normally cant get glue to hold. Its just fine and the stuff is tough.
Try it.
I'm at least a year out of warranty I think... I'd have to get someone on the phone to ask if they could allow me just to purchase the mode dial, or if they could send it to me for free.
Dan Hudson
Dan Hudson Senior Member • Posts: 1,383
You might try a tiny drop of well mixed epoxy. Might never get it off again. (Tiny bit though). Good luck
Christian Amateur Photographer
Choose life's involvements carefully with an eye toward eternity.
 Dan Hudson's gear list:Dan Hudson's gear list
Canon PowerShot SX120 IS Canon EOS M50 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM
mvkuilen Forum Member • Posts: 85
Somewhere during a recent trip, my M5 mode dial also fell off. By the time I noticed, it was long gone. The camera modes can still be selected but there is no visual feedback from the dial. Is this a normal repair issue? Any idea what it might cost to repair?
Considering the ergonomic flaw where I keep activating the Menu button with the base of my thumb when I hold the camera with my right hand, I wonder if it would be worthwhile to repair or consider another backup camera body.
 mvkuilen's gear list:mvkuilen's gear list
Canon EOS 80D Canon EOS M5 Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Canon EF-S 18-135mm F3.5-5.6 IS STM +2 more
David Hull
My repair was free since the M5 was still under warrantee. It is worth noting that while they claim warrantee is 12 months, they told me that they will often give a couple more months of grace. I would call them and ask. M5's need to go to Virginia, though not Irvine.
They glue it on so it probably isn't too bad -- but then again, it's Canon so who knows.
