Cheap light diffusing material needed - ideas/suggestions?
Started Jul 12, 2018 | Discussions
WuWuZilla New Member • Posts: 13
Hello all,
first off, I'm sorry if I don't use the proper technical/English terms in my descriptions.
If you have questions regarding certain terms, just ask.
To the topic:
For a DIY project, I need a cheap light diffusing material. The setup is several lines of RGB LED strips next to each other. To avoid that the light of each single LED is seen in the lit area, I'd like to diffuse the LEDs light so that it appears to be (more or less) a single uniform light source. So, I'd be looking for a good light diffusing material, e.g. a film/foil or similar. It should be lightweight, flexible (bendable), and cheap. The diffusion material needs to cover an approximately 10x50cm (4"x20") field of LEDs.
Any ideas or suggestions on what material this could be? Either directly available in a store or easily producible by myself. Thanks in advance!
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: Cheap light diffusing material needed - ideas/suggestions?
WuWuZilla wrote:
Hello all,
To the topic:
I used to use large-format (E) plastic printer "paper" as a rear-projection screen -- it gives no hotspot whatsoever, which means it's a great diffuser material. I've also found some high-end art papers to be pretty good as diffusers, but they tend to give slight hotspots (and let a lot more light through).
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
mlackey Regular Member • Posts: 488
http://extreme-macro.co.uk/macro-diffusers/
OP WuWuZilla New Member • Posts: 13
Thanks. Can you maybe post a sample link to this "plastic printer paper" you've mentioned?!
Thanks. But I need a larger diffuser area, not just flash light. And about the also mentioned polysterene: I'm not sure this will let through enough light... But I'll check this out as a starting point.
Gato Amarillo Veteran Member • Posts: 9,340
Cheap plastic shower curtains are one possibility. It is a bit trial and error to find what works best for you (and you may need to do a custom white balance) but it can work well.
Gato
OpticsEngineer Veteran Member • Posts: 7,828
At www.bandhphoto.com do a search on Rosco Diffuser and you will turn up some cheap materials I use professionally when I need parts acceptable to our supply chain.   But in the lab I sometimes just use the liner that contains the cereal in my box of Cheerios.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +27 more
Thank you!!
Just what I needed for a project today and I had an empty Cheerios box sitting next to the kitchen trash.
Gato
BobORama
BobORama Senior Member • Posts: 2,842
Next time you see an old backlit LCD monitor or TV in the trash heap, tear it down and you will find the backlight diffuser consists of several layers of thin plastic designed for this exact purpose.  So you have a thick piece of acrylic, a super bright piece of white plastic, and several layers of various diffuser materials.   Its an inexhaustible font of stuff to play with, plus tearing stuff apart is fun.  The opaque, rear plastic makes a great bounce flash, the front layers are ideal as diffusers.
And you are keeping these dangerous plastics from clogging some dolphin's blow hole.
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
BobORama
Oops, just noticed the need for a LOT of material.    a really big TV?
I am glad you found the Cheerios liner tip handy. I got it some years ago from a Zeiss optical scientist in Jena
E Dinkla Senior Member • Posts: 2,613
WuWuZilla wrote:
Hello all,
To the topic:
No idea where you are located but some time ago I ordered a PMMA 5mm thick diffusion sheet 82% transmission from
https://www.pyrasied.nl/en/product/cast-acrylic-opal-sheets/
for a DIY 4x5 digital slide copier. Creating a good diffused light source behind a slide is more demanding on evenness than creating a light source for object photography etc.
If the LED RGB strips do not sufficiently mix that way I think you should go for a kind of Ulbright mixing box behind it. Lined internally with white polystyrene high density foam or BaSO4 paint or a paper without optical brighteners + a high white reflectance. Check
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm for paper spectral reflectance.
Be aware that multiple thin opal sheets should be quite parallel to one another and better not touching one another at some point. Unevenness in monitor light can be related to that aspect.
Met vriendelijke groet, Ernst
No photographer's gear list is complete without the printer mentioned !
(unknown member) Regular Member • Posts: 484
The gearheads want to know: Regular or Honey Nut?
NancyP Veteran Member • Posts: 6,608
Vellum paper, 2 layers - ideas/suggestions?
The holder is up to you.
NancyP
 NancyP's gear list:NancyP's gear list
Sigma DP3 Merrill
Snapshott Senior Member • Posts: 2,309
WuWuZilla wrote:
Hello all,
To the topic:
I've also used while plastic folders and cut out the two pockets. The white ones are sometimes hard to find.
 Snapshott's gear list:Snapshott's gear list
Nikon D80 Nikon D7000 Nikon D750 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Nikkor 50mm f/1.4D +19 more
Turbguy1
Turbguy1 Senior Member • Posts: 1,467
Cheesecloth...(really, try it!).
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
