Fuji S5 Pro in 2018... Madness?
Started Jul 12, 2018 | Discussions
PaulSnowcat
PaulSnowcat Senior Member • Posts: 1,379
9
Hi, guys!
Maybe I am mad, but today I've bought an S5 Pro. Long ago I looked at pictures made by it and was jealous for it's DR and Colors... That was back in 2006, 2007... I was using Pentax and Olympuis back then. And now In 2018 I saw one for a good price and could not resist. I am shooting Nikon now and have all the lenses, so I wanted to see "those beautiful colors" by myself, to use this legendary camera...
Am I mad ?
And... Any hints about settings? Any tips about using S5 Pro? Thank you!
 PaulSnowcat's gear list:PaulSnowcat's gear list
Panasonic Lumix DC-S1R Tamron 100-400mm F4.5-6.3 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6
Fujifilm FinePix S5 Pro
John Motts Veteran Member • Posts: 5,854
Re: Fuji S5 Pro in 2018... Madness?
You can get very good quality from that sensor but it's impossible to say whether it's right for you because you don't say what you want to use it for.
Low light? No way!
Large prints? There are much better modern sensors with higher resolution.
Beautiful skin tones in good unchallenging light? Yes, that's here it comes in.
Batdude
Batdude Veteran Member • Posts: 6,544
6
Low light? No way!
Good unchallenging light??  You mean artificial indoor light?  What do you mean?  The S5 Pro is one of THE best cameras for challenging light when it comes to highlight recovery.  Perfect for wedding and stuff like that.  You blow up the highlights and it will be fixed easily.  No other camera can do that.
 Batdude's gear list:Batdude's gear list
Fujifilm X10 Nikon D4 Fujifilm X-E1 Fujifilm X-T1 Fujifilm GFX 50S +12 more
Serge 07
Serge 07 Regular Member • Posts: 447
Congrats! I think you will have lots of fun with the S5. Picked up the S5 four year back and it can certainly produce beautiful photos.
I use the following settings most of the time & others may offer additional suggestions.
Film simulation: Std
Matrix metering: +.67 exposure comp
Colors: Medium H
Tone: Std
Sharpness: Std
D-Range: Auto
Noise reduction: ORG, lowest setting
Nikkor 28/2.8 AIs
 Serge 07's gear list:Serge 07's gear list
Fujifilm FinePix S5 Pro Nikon D40 Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8
Sjak
Sjak Veteran Member • Posts: 7,318
PaulSnowcat wrote:
Am I mad ?
Well, I've been considering it too for a while, it's just that I didn't like to get married to the Nikon-mount in the process, so eventually decided against it.
The mere fact that there's other camera's on the market with more pixels and some other useless features does not suddenly invalidate an older cam. Old camera's can make the same quality of pics as when they were released.
For most of us, the user is the limiting factor anyway
Have fun!
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
PaulSnowcat
OP PaulSnowcat Senior Member • Posts: 1,379
S5 will not be my only camera, I have Nikon D7500 and I am quite happy with it. I picked S5 more out of curiosity then out of need. I want to see how this legend works, can it compete in color reproduction with modern cameras or not... As for low light, I have D7500 which allows usage of ISO 10000 - that's more then enough for me.
PaulSnowcat
Thanks for sharing the setup!
One more question... The body of S5 is the same as Nikon D200? Can i buy ribbers for Nikon D200 and use it on S5?
bobogdan78 Forum Member • Posts: 60
7
I bought this camera 1 year ago. The first thing is to check the firmware - it must be 1.12 or at least 1.09 otherwise the camera might not work properly. A very good source of information is the Flickr Fuji S5 pro group https://www.flickr.com/groups/fujis5/ I have read the discussions there to set up my camera. I may be subjective but this camera takes the most beautiful pictures (sooc ) I've seen and the highlight retention, not only recovery, is amazing. As a result, instead of checking daily rumors about future upcoming cameras and what bells and whistles they might have, I'm looking for another S5 (just in case, it's an old camera) or even S3.
 bobogdan78's gear list:bobogdan78's gear list
Fujifilm FinePix S5 Pro Olympus PEN E-PL3 Olympus E-PL7 Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 50mm f/1.8D +2 more
PaulSnowcat
In fact, My main camera is a Nikon D7500 and I think it's colors are very good, better then most cameras out there. I tested it side by side with Fuji T1 and found that D7500 gives more pleasant colors most of the times!
BUT. Even a quick comparison shows that S5 Pro is even better. I took 6 different pictures with different lighting conditions. On one of them Nikon D7500 colors were on par with S5 Colors. On 5 pictures out of 6 S5 gave clearly more pleasant colors then D7500. That's a camera made 12 years ago!!! I am shocked.
Of course, only 2FPS, rather primitive AF (which, as I already managed to see makes some mistakes), ISO usable only up to 800, all those signs of age are there. But Color reproduction is fantastic!
Why, why they killed SUPER-CCD development!?
JdKen Regular Member • Posts: 193
I have to agree. Quite astonishing colors, dimensionality, and skin tones - even in the more mundane shots. And foliage that looks real too.
New Fuji ought to talk to old Fuji about how to do all that again.
 JdKen's gear list:JdKen's gear list
Fujifilm FinePix X100 Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro Nikon AF Nikkor 35mm f/2D Nikon AF Nikkor 85mm f/1.4D +3 more
TomC601 Veteran Member • Posts: 3,094
10
Always great to see a S5 thread. I don't log on very often since the S5 was my last Fuji camera (and also because before the X cameras came out this forum was more about photography than hardware) and I did not move to the X system. Too much invested in Nikon glass so I now mostly shoot with a D800. Nothing against Fuji, I worked for them for almost 30 years and left during the intro of the S3. Still love the company and their products. I still own a S5 but do not use it often. In fact my S5 probably has less than 5000 actuations and is in like new condition. (Maybe I should take it out more often.)
That all being said I find the RAF files from the S series cameras to be the most malleable files I've ever worked on. It's amazing how much detail, dynamic range and color realism you can achieve with these files. The fact that the sensor is only 6MP and almost 20 years old make it all the more remarkable. While I am blown away by what the D800 (and that's getting old now, but then, so am I) accomplishes there's something (what I call) nostalgic about the images I produce from the S5 files. I find that as processing software improves and new plug-ins and products appear I revisit some of my favorite files and coax even more out of them. One of the posters in this thread lamented the demise of the Super CCD. I, too, was sad to see it's development cease. Now the only differentiation of files comes from the firmware that camera manufacturers apply to the Sony chips. The Super CCD was different from its core and impossible to duplicate. There were many reasons for development to cease, cost and difficulty achieving adequate yield as Fuji tried to make a larger sensor being the main culprits. I'm sure I'll feel the same way when Fuji discontinues Velvia.
So, I think it's a great idea to acquire a S5 as a second camera. It will take some getting used to (I hated the D800 when I first got it; love it now) but once you do you'll be amazed at what that piece of equipment will do. Attached is a S5 image printed to 16x20 hanging in my bedroom. Reminds me of a great 30 years every morning.
Tom
It's that higher ISO performance that let the CCD down. As CMOS almost caught up with it at lower ISOs, the CCD's days were numbered.
You're right though, CCD was always the boss and remains unbeaten where higher ISOs were not required (which is what I meant about unchallenging light in my answer above).
gwynngee Contributing Member • Posts: 548
Hi Paul, If you are shooting raw you really need to be using the Fuji HU software to see the intended Fuji colors. I have just bought a 2009 Mac pro , loaded a copy of Snow Leopard ,added Rosetta , then reloaded my old Fuji Soft ware. Well , talk about chalk & cheese. ACR does not give anything like the Fuji Software. The tone curve and color response is very different and the image is no longer interpolated to a 12.1 m/px image as the chip was intended to be. I am in the process of writing a set of presets for ACR. What I have noticed so far .
Blue response. In ACR it will always be a compromise , ACR will not reproduce the blue swatch without destroying the mid and light blue swatches . So to adjust the blue response you have to work on the mid blue swatch and live with what you get in the darker blues.
Magenta response, in a couple of the film response settings the magenta hue is pushed as far as it will go towards the red in the HSL tab and it just makes it.
Cyan is another tricky one.
Skin Tone. The problem here seems to be the response of the darker skin tone color in respect to the lighter skin tone. If you get the light skin tone color right the darker tone looses red( looks greyish) . If you get the darker tone right , the light one gets really bad.
Are you mad to get an S5 , no way. A 6 m/p image with a 25 meg raw file describing it, it has so much information describing it. They are so pliable.
Since the S5 I have used 4 or 5 Nikon cameras and still use the S5 for certain jobs. I don't know how many times i look at the files from my different Nikons and think " why didn't I use the S5". I guess it is because (even though most of what I shoot these days ends up on a web page) I know the client will get them up on their screen blow them up to 100% and think they aren't sharp enough ??? To hell with color , tonality , HIGHLIGHT color response & roll off.
The more you learn to handle the files from the S5 the more you will be amazed by that chip. It brought a whole new bent on expose to the right.
When the presets are finished I am happy to share. 8-9 years ago we made some available for the old ACR.( I say we because I emailed them to someone and he hosted a down load link) .
The reason I am going through this again is I am trying to fix up my Nikon DF. For those instances when I say " why didn't I use the Fuji".
Tony G-J.
The Davinator
The Davinator Forum Pro • Posts: 24,707
5
Batdude wrote:
Low light? No way!
All modern camera can do that.  Just meter for the scene.  Current Fuji cameras have a larger DR.
PaulSnowcat
I've had a modern Fuji, the T1. And it did not impress me in any way - not in colors, nor in DR. DR is slightly less then Nikon D7500 gives, colors are, in most cases, even slightly worse then Nikon D7500 gives.
While DR of S5 is also somewhat lower then I am getting from D7500m it colors I enjoy more. Clearly SUPER CCD Technology is superior to cmos where it comes to ISO 100 color reproduction comparing. While X-Trans is the same CMOS with the same strengths and weaknesses of every CMOS sensor.
The Davinator
6
The issue of DR is not open to debate.  Both the XT1 and D7500 are far superior to the S5 in dynamic range.  If you aren't impressed by the DR of the XT1, then you'll hate the S5.  So you reasoning falls apart.
As to color, with the latest Fuji cameras receiving some of the most glowing color reviews of any brand, I'm not sure why you find fault.  The color was actually very inaccurate with the CFA on the S5.
In term of DR though, every brand beats it now.  You don't seem to have a very good grasp of sensor tech.
Sjak
I think this is more a subjective matter, nothing wrong with that btw!
For colours (in good light) my favorite is my Sigma DP2, which also only works well at ISO 100; it's CMOS, but without the CFA. Another camera I like for colour work is the K100D, also an oldie by now
Too bad of the Nikon-mount of the S-series Fuji DSLR, otherwise I would be really tempted. I like the colour character of images made with these cams.
JoaCHIP
JoaCHIP Junior Member • Posts: 38
I have a D600 which certainly has a higher resolution and less noise at super high ISO values. But getting the same kind of lush colors out of the D600 is hard work, and under some conditions the D600 just misbehaves wildly, whereas the S5 Pro would do it perfectly even in jpeg mode.
I think one of the differences is that the red color channel of the Fuji goes further towards the infrared, whereas Nikon probably doesn't go far enough in that direction. As a result, the colors around sunset are very different between the Fuji and the Nikon. And it takes a lot of post processing of the raw files to get the same kind of warmth from Nikon that the Fuji is capable of doing even in jpeg mode.
The thing that made me switch was that the S5 is cropped. A fullframe S5 Pro would have been the ultimate thing.
JoaCHIP
Re: Yup, I agree!
And the difference in resolution you get from ACR vs. Fuji's raw converter is, in my experience, bigger than dpreview's review states. It's like going from 4 to 8 megapixels. And sharpening the Adobe RAW output simply doesn't get you there. I think it's not interpreting those Fuji raw files correctly, and neither is dcraw, RawTherapee, or any other raw conversion software I've tried.
fPrime
fPrime Veteran Member • Posts: 3,727
Re: Yup, I agree!
Thanks JoaCHIP and Tony,
Your enthusiasm for Fuji's Hyper-Utility HS-V3 drove me to finally download and install it this weekend. I now have v1.1b running successfully on my Win 7 x64 desktop. Previously I had been using Adobe Lightroom with the S5 Pro.
As you say the HS-V3 user interface is slow and outdated, but the colors and sharpness are much better than those I got with Adobe Lightroom. Also missing in Hyper-Utility are modern conveniences like hot pixel suppression, lens corrections, and CA removal but I can automate all of these functions in Photoshop. In my opinion the optimized SuperCCD demosaic and manufacturer’s camera profile make Hyper-Utility the highest quality RAW converter for the S5 Pro, bar none. I wish I had tried it earlier.
fPrime
Half of my heart is a shotgun wedding to a bride with a paper ring,
And half of my heart is the part of a man who's never truly loved anything.
 fPrime's gear list:fPrime's gear list
Canon EOS 5D Fujifilm FinePix S5 Pro Leica M8 Nikon D60 Nikon D1X +3 more
