GX7 Exposure comp?
Started Jul 12, 2018 | Questions
a100ps
a100ps Regular Member • Posts: 191
GX7 Exposure comp?
So I've been migrating to micro 4/3s and have acquired two GX7's, on one of them I can control my flash compensation by pressing in the rear dial and turning, but not on the other one, it does nothing. I was searching through the menu but can't find where to set this up, can someone out in Lumix land help me out? Thanks in advance; Ron from Pickering
 a100ps's gear list:a100ps's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Fujifilm FinePix X100 Fujifilm X30 Sony a77 II +18 more
tt321
tt321 Forum Pro • Posts: 13,854
Re: GX7 Exposure comp?
Have you downloaded this:
ftp://ftp.panasonic.com/camera/om/dmc-gx7_en_adv_om.pdf
Might be worth going through carefully given that you've got two.
Helen
Helen Veteran Member • Posts: 7,606
Off the top of my head (going back several years to when I had just bought a new GX7) I seem to recall that an early firmware upgrade added an easier way to get at flash exposure compensation, so do check the firmware versions on your two examples - if the firmware of the one that allows this is a higher number, that may well be a factor as the other one might not yet have the ability to set the feature this way.  You can upgrade the firmware yourself pretty straightforwardly by searching for Lumix Joint Update on the web, amongst other terms.
