G9 Wide Angle Lens
Started Jul 10, 2018 | Discussions
elentkdd
elentkdd New Member • Posts: 4
G9 Wide Angle Lens
Hi,
I currently have two lenses: Lumix 25mm (50mm equiv) and Lumix 45-150mm (90-300mm) equiv.
I'm looking for a wide angle lens under 400$, I'm considering one of the following:
  1. Lumix 14mm F/2.5 II
  2. Lumix 12-32mm F/3.5-5.6
  3. Samyang 12mm F/2.0 (dpreview page)
  4. Rokinon 12mm F/2.0 (dpreview page)
The purpose of this lens would be mostly for indoor shots were the 50mm (equiv) isn't wide enough.
My current thoughts are:
  • From photos I managed to find on flickr it seems that the Samyang and Rokinon could give me better quality (better low light performance, better bokeh, sharper)
  • In general I prefer prime lenses
  • I think the 14mm won't be wide enough
  • The Lumix 14mm seems a bit hard to find and I'm not sure if it was discontinued or not
  • The Lumix lenses are really small and lightweight
  • If I understand correctly the Samyang and Rokinon lenses are MF, not sure how problematic that is
I think my top priority is the image quality.
I would appreciate any help to decide on a lens (or if there are any other options that I missed).
Thanks in advance,
David.
 elentkdd's gear list:elentkdd's gear list
Panasonic FZ1000 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 25mm F1.7 ASPH
Stejo
Stejo Senior Member • Posts: 1,461
Re: G9 Wide Angle Lens
Samyang and Rokinon are the same thing.
Panny 14/2.5 is discontinued but you can still find a few copies here and there.
Sounds like what you need is a standard zoom though really. You can probably find used copies of the Panny 12-35 mark I for your top end price. Or you could get a dekitted 12-60 which is pretty good at the wide end for $250 or so.
 Stejo's gear list:Stejo's gear list
Panasonic Lumix DMC-G7 Panasonic GH5 Samyang 85mm F1.4 Aspherical IF Samyang 7.5mm F3.5 Fisheye Sigma 18-35mm F1.8 DC HSM Art +7 more
Toni Genes
Toni Genes Regular Member • Posts: 323
There is an Laowa 7.5mm F/2.0 which is very good acording to the reviews.
It costs arround 500$.
It worth to consider it because is very wide.
Manual focus is not problematic for an wide lens. Is very easy...
 Toni Genes's gear list:Toni Genes's gear list
OM-1 Olympus M.Zuiko 300mm F4 IS Pro
epozar
epozar Senior Member • Posts: 1,969
Samyang = Rokinon
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
hindesite Veteran Member • Posts: 4,893
The 12-32 would be wasted on your camera.
It is a great budget, small and pocketable lens but doesn't have manual focus and would be a crazy choice to pair with the G9.
whumber
whumber Veteran Member • Posts: 4,371
Like someone else suggested, a Panasonic 12-60mm f/3.5-5.6 is the obvious choice although the Pana-Leica version is even better if your budget allows.
 whumber's gear list:whumber's gear list
Fujifilm X-T1 Olympus OM-D E-M1X Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
the 14 is the easiest to use of this lot
you should be able to find this lens.
it is the classic 28mm fov
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
brentbrent Veteran Member • Posts: 5,766
Consider the Panasonic Leica 15mm
If you were able to afford the G9, I'd say save up the extra $150 over your stated budget to buy the Panasonic 15mm f/1.7, now selling for $547 at B&H.  It is a much better lens than the 14mm, fast enough for indoor use, IMO wide enough for most indoor use, it has DFD Autofocus with your camera, and it is much smaller and lighter than the Samyang/Rokinon 12mm.
There's a reason why pretty much everyone who owns the 15 raves about it.  It's a great little lens.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
alcelc
alcelc Forum Pro • Posts: 19,003
If you look into 12 (28mm eq AOV of FF), I might suggest the 12~35 f/2.8 be better. I found 12~32 is good (especially for its cost and size) uber good lighting, it lightweights under non ideal lighting condition.
14 prime is good on cost and size, IQ not bad, but more restrictive. Its IQ is not outstanding among other consumer grade zooms (because most of them are so good).
For the ultimate wide angle solution, look for 7~14 f/4, small, cost comes down a lot nowadays, sharp across the frame wide open, not too large and heavy as its f/2.8 not brothers...
Albert
daleeight Veteran Member • Posts: 3,199
Laowa 7.5 f/2... it is worth the extra 100
https://www.venuslens.net/product/laowa-7-5mm-f2/
Dale
 daleeight's gear list:daleeight's gear list
Olympus E-M1 III Nikon Z7 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +6 more
Cagey75
Cagey75 Senior Member • Posts: 1,347
The Samy/Rok 12mm F2 is a cracking lens, very sharp, even at F2 - It is also very easy to use, don't be put off by the manual focus, clearly many on here are way too pampered with fast AF as a crutch.  Once you have your focus nailed for a scenario [which takes merely seconds!] every shot from there on in similar situation will be in focus, it's not that hard.  It is also not a fly-by-wire lens, but a true MF lens, very precise and the throw is pretty short, making it a cinch to switch between distances when needed.
If this was an AF lens it would cost double the amount, crazy! It is certainly not twice as hard to use once you get the hang of it.
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Fujifilm XC 35mm F2 Venus Laowa 65mm F2.8 Macro +1 more
rashid7
rashid7 Veteran Member • Posts: 7,011
David... these are very different options.  Based on owning the 14 and Olympus 12, I would say the 14 is primarily all about being tiny.  It is a good lens.  The pricey Oly is even better (not perfect) and small!
I am a huge fan of the Samyang/Rokikon (u realize they are same?) fisheye made specifically for m4/3.  It gives (by far) your widest angle, perfect for capturing a WIDE scope of interiors.  When lenses are this wide, MFocus is easy... most everything can be kept in focus.  And focus peaking will confirm it.
The 12-32 is a marvelous diminutive all-arounder
u can hardly beat the value of Samyang lenses... just make sure your copy is OK.  Don't obsess over it (like so many here) but make sure it is "centered"
Keep it fun!
