Old manual focus lenses for NX500
Started Jul 8, 2018 | Discussions
Nate8833
Nate8833 Contributing Member • Posts: 557
Hello,
I just picked up an NX500, and I took it out and a few lenses out for a test run. The 16mm pancake is a pretty poor performer, but the 30mm pancake and 45mm f1.8 looked good. I did seem to see some shutter shock with the 30mm, but I'll have to keep testing to confirm.
Anyway, what I was really blown away by was the performance of my old Nikon 55mm f3.5. Even focused to infinity it was the best performing lens. So of course now I'm thinking... Anyone have recommendations for manual focus lenses (Nikon or otherwise) in the wide to normal range that you have seen outperform Samsung's own lens lineup? I have no problem manual focusing so I'd love to pick up some fun, sharp lenses on the cheap.
Thanks!
Nathan
 Nate8833's gear list:Nate8833's gear list
Samsung NX500 Leica SL (Typ 601) Sigma sd Quattro Sigma fp L Samsung NX 30mm F2 Pancake +8 more
Samsung NX5 Samsung NX500
kypfer Contributing Member • Posts: 985
Re: Old manual focus lenses for NX500
I bought my economically-priced second-hand NX5 purely as a platform for my old Russian rangefinder lenses. The Orion-15 28mm is beautifully compact, albeit slow, at f/6 maximum aperture, the Jupiter-8 50mm f/2 and the Jupiter-9 85mm f/2 are all bitingly sharp and none of the various Tessar-derived Industars will disappoint.
I use several Fujinon 42mm-screw mount lenses and am always pleased with the results.
I acquired  most of my old lenses long before there was a collector market for them. Everyone wanted bayonet-mount autofocus zooms 20-30 years ago, screw-mount primes were almost given away! Times have changed and prices have sky-rocketed, for some examples.
Good luck, and enjoy
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Nate8833
OP Nate8833 Contributing Member • Posts: 557
Thanks for the reply!  I'll have to look into the Jupiter lenses.  I actually just found several Minolta lenses that I already have a MFT adapter for, so I'll test them out on my OMD EM-10ii and get an adapter for NX if any are worthy.
norman shearer Senior Member • Posts: 1,418
Nate8833 wrote:
Hello,
The 16mm pancake is my most used lens - damn fine performer for street. AF not great but I zone focus anyway..
Personally I'd go easy on adapting legacy glass for NX500 - it's not nearly as practical as it would be on a camera with an EVF and APS-C crop means the lenses will not perform as they were designed ie; for FF. Focus magnify in centre only is also a pain. If you are only using lenses you already own then and I guess lenses that will give you greater than 200mm will broaden NX500 use-age but big/heavy glass is not the best match for NX500.
Most of my legacy lenses sat in the cupboard until I got a Sony A7R2. I did initially use them on m43 and APS-C but found OEM lenses and AF worked better.
 norman shearer's gear list:norman shearer's gear list
Samsung EX2F Nikon Coolpix A Sony RX1R Canon EOS 5D Canon EOS 5D Mark II +10 more
Paul Peterson in ATL
Paul Peterson in ATL New Member • Posts: 20
 Paul Peterson in ATL's gear list:Paul Peterson in ATL's gear list
Sony a7R III Sony FE 85mm F1.8 Samyang AF 18mm F2.8 FE Tamron 70-180mm F2.8 Di III VXD +1 more
vanc New Member • Posts: 2
I also get shutter shock on the NX500, it's really such a shame. Forget the lack of EVF, the lack of microphone input ports, this is the camera's fatal flaw. Just as with the OG A7R, it's ridiculous that I can't comfortably take photos slower than 1/160.
I really like the Canon FL 50 1.4, it's pretty cheap online. Example photos: https://imgur.com/a/6X1Jj, https://www.instagram.com/p/BlrYDOWh4xA/?taken-by=justinkchau
alex_virt Veteran Member • Posts: 3,044
I can highly recommend:
1. Mamiya 645 lenses. You can't get anything wide, but if you're looking for good telephoto lenses, look no further. I used 80/1.9, 150/3.5 and 300/5.6, all have fantastic sharpness and clarity. Had to use two adapters: M645 to EOS and EOS to NX.
2. Canon FD 50/1.4, sold it after buying NX 45mm.
3. Pentax Super Takumar 50/1.4, old 8-element non-radioactive version. It is pricey but has unique rendering and wonderful colours.
4. Pentax-A 35-105mm/3.5 zoom – I've just bought it and used only on Pentax cameras, but am tempted to try on my NX30. It is very sharp in the centre with some blur on the edges and produces amazing colours. Best flower lens I've ever had!
Nate8833
Just an update, I have an OM 200mm f4 on the way!  We'll see how that goes.
sixfootzero
sixfootzero Contributing Member • Posts: 674
Here's a Flickr album of my manual lenses on an NX100.
https://flic.kr/s/aHsjD68BJo
I got into Minolta by chance, but it was a fortunate thing as they make great lenses.  Their MD lenses are the most modern, with good coatings, etc.  They have also been optimized for small size and light weight, with most lenses using a 49mm filter thread vs 55mm on the older MC lenses.
Their 50mm f/2 is cheap/plentiful, but a fantastic performer.  Same for the 45mm f/2.  28mm f/2.8 is good, but not perfect wide open.  (Still good tho...)  135mm f/2.8 & f3.5 and 200mm f/4 are all cheap and great!
I use cheap Ebay adapters, but have occasionally had to return one for tight/loose fit.
 sixfootzero's gear list:sixfootzero's gear list
Samsung NX100 Fujifilm X-E1 Fujifilm X-H1 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED +4 more
dprup New Member • Posts: 1
No text.
