Buying a Samsung NX300 - 18-55mm or 20-50mm lens
Started Jun 30, 2018 | Questions
Manzur Fahim
Manzur Fahim Veteran Member • Posts: 3,882
Hello everyone,
Hope you are well.
I am thinking of getting a NX300 and I was wondering which lens I should go with? I am buying it used from Amazon and the brown one comes with a 20-50mm lens, and the black one comes with the 18-55mm lens. I do not mind with either focal length, so I was wondering if you can help me decide which lens to go for.
Many thanks and have a great day.
 Manzur Fahim's gear list:Manzur Fahim's gear list
Fujifilm GFX 100S Fujifilm GF 110mm F2 Fujifilm GF 23mm F4 Sigma 105mm F1.4 DG HSM Art Sigma DP2 Merrill +4 more
Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 20-50mm F3.5-5.6 ED Samsung NX300
kypfer Contributing Member • Posts: 985
Re: Buying a Samsung NX300 - 18-55mm or 20-50mm lens
Funnily enough I researched this info a little earlier today, purely out of interest, and came to the conclusion that they both have their advantages!
The 18-55mm has OIS (Optical Image Stabilisation) ... quite useful, but is physically bigger than the 20-50mm, which has iFn, if that feature is compatible with your (potential) camera.
On-line comparisons suggest both lenses give similar results and have similar minimum focus distances. The 20-50mm uses 40.5mm filters whereas the 18-55mm uses 58mm, which may be of consideration if you already have a circular polariser in either size.
My 18-55mm came with a lens hood, I don't know about the 20-50mm, but I use a hood almost always, so is a point of concern for me.
I'm thinking I could probably use both. I have an 18-55mm and it's very good, but I sometimes think it'd be nice if the assembly wasn't quite so bulky.
Hope this all helps
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Manzur Fahim
OP Manzur Fahim Veteran Member • Posts: 3,882
Thank you very much. I'm leaning towards the NX300, NX1 seems to be very difficult to get one at this moment. Do you know image quality wise which lens has the advantage?
Manzur Fahim wrote:
... Do you know image quality wise which lens has the advantage?
As I said : "On-line comparisons suggest both lenses give similar results ..."
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
The brown one is gorgeous when you see it in person...
...however, IMO, the 18-55 is the better lens. But then that opens up the reality that kit lenses tend to have copy-to-copy variations in optical qualities. The 18 MM wide end of the 18-55 is equivalent to a 27-28 MM wide angle field of view and it has IS in the lens. The 20 MM wide end of things on the 20-50 gives you even a less angled view, and it does NOT have IS in that particular lens.
If you wind up with the brown version and the 20-50 lens, PM me and if you're in the market, I can sell you a new (was part of a kit - never used) 18-55 III with a metal lens mount - for only $95 shipped. I know that statement sounds like an opportunistic one - but at least you wind up with both lenses. It's a good copy also (had to test it on the NX300 when I first got mine).  It's just sitting in the box (NX300 box) and right now I have the 16-50 PZ and some primes that I use with the NX300.  So it's yours (or anyone else for that matter) if you (they) want it.
Sincerely,
Bernd ("Ben") Herrmann
Fuquay Varina, North Carolina USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
flip 21
flip 21 Senior Member • Posts: 1,439
Manzur Fahim wrote:
Hello everyone,
Hope you are well.
Buy the 18-55 if you do video. it's a much better lens, with OIS, and fast AF, but... comparing to the 20-50 it is a monster in size... it turns the camera less compact... if you can, buy the camera with the 16-50 PZ. It is the best of both worlds, and has motorized zoom...
TillmanB
TillmanB Contributing Member • Posts: 501
Manzur Fahim wrote:
Hello everyone,
Hope you are well.
I never used the 20-50mm, but for me the deal breaker was the lack of IS compared to the 18-55mm.  The former is a bit smaller, but for me the slightly larger size was worth it because IS allowed for smoother videos and shooting in low light where slower shutter speeds became necessary was much more forgiving.
