FUJIFILM X-T2 CAMERA SETTINGS FILE DISPLAY
Started Jun 28, 2018 | Discussions
Scuba Maldives Junior Member • Posts: 43
Re: v1.03 Update HERE !!!
Here is the latest prog, just the basics as progress is slow, remember I am a 'hacker' not a programmer so bear with me on this. Any help from a Java programmer would be appreciated.
https://www.dropbox.com/s/goxldebnjdaoq0z/GFX100s_2.0.jar?dl=0
Ian.
 Scuba Maldives's gear list:Scuba Maldives's gear list
Olympus OM-D E-M5 Olympus OM-D E-M10 II Fujifilm GFX 100S Olympus M.Zuiko Digital ED 75mm F1.8 Fujifilm GF 32-64mm F4 +1 more
glospete New Member • Posts: 9
Re: v1.05 Update HERE !!!
Hi Macro
As I am about to upgrade from X-T2 to X-T5 I wondered if your excellent "camera settings" works with later models including the X-T5?
Macro
OP Macro Senior Member • Posts: 2,758
glospete wrote:
Hi Macro
Only works with X-T2.  Unfortunately, file formats are different for each model.
 Macro's gear list:Macro's gear list
Panasonic Lumix DMC-FZ100 Canon PowerShot G5 X Sony RX10 IV Fujifilm X-T1 Fujifilm X-T2 +6 more
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Macro wrote:
glospete wrote:
Hi Macro
Have you looked at any of the more recent cameras? I've decoded most of the custom setting data for the X-H2S but there doesn't seem to be any consistent pattern (beyond trial and error) in figuring this stuff out.
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
Macro
Greybeard2017 wrote:
Macro wrote:
glospete wrote:
Hi Macro
Unfortunately, I have not found similarities between models.  Change a setting, search for a bit change, add to the spreadsheet.  Cheers
Greybeard2017
Macro wrote:
glospete wrote:
Hi Macro
Thanks - yes that was the technique I was using - why can’t they make it easy - some sort of xml or something - I don’t see the need for obfuscation
