FUJIFILM X-T2 CAMERA SETTINGS FILE DISPLAY
Started Jun 28, 2018 | Discussions
Macro
Macro Senior Member • Posts: 2,758
17
Fujifilm X-T2 Camera Settings File Display
Have you ever wanted to verify your X-T2 menu settings without wearing out your camera buttons and your eyes?
Have you ever wondered which menu settings are stored in those .DAT files you have saved?
Wouldn't it be nice to view these .DAT file settings in a nice readable format?
To help answer these questions, I have created a small Java program named Fujifilm X-T2 Camera Settings File Display. The file format is .jar which is platform independent. I have tested this on both Windows (mostly) and Mac (briefly), but it should run on most any platform.
Requirements:
  • X-T2 settings backup .DAT file(s) saved using PC AutoSave or X Acquire
If you are not familiar with how Camera Settings Backup/Restore works, please visit the Fujifilm website for info about X Acquire...
FUJIFILM X Acquire - Features & Users Guide
How it works:
  • Run program
  • Select .DAT file
  • HTML file is saved
  • Open HTML file in browser
Downloads below...
DROPBOX LINK to run file Fujifilm_X-T2_Camera_Settings_File_Display_v1.00.jar
DROPBOX LINK to sample HTML output file
Comments, suggestions, and bug reports are all welcome!
Cheers
Macro
Below is a partial screenshot of the output file...
 Macro's gear list:Macro's gear list
Panasonic Lumix DMC-FZ100 Canon PowerShot G5 X Sony RX10 IV Fujifilm X-T1 Fujifilm X-T2 +6 more
Fujifilm X-T2
Macro
OP Macro Senior Member • Posts: 2,758
v1.01 Update
v1.01 Update
  • Corrected format and alignment bugs
  • For all selected values (bold type), added mouse-over tooltips displaying all possible values for each menu item selection
Sample tooltip displays below:
DROPBOX LINK to run file Fujifilm_X-T2_Camera_Settings_File_Display_v1.01.jar
Cheers
Macro
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
Re: v1.01 Update
Very interesting and a great idea! I will give it a whirl and report back. Thank you for your efforts.
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
Everaert Regular Member • Posts: 132
Re: FUJIFILM X-T2 CAMERA SETTINGS FILE DISPLAY
This is extremely useful Macro.
WAY easier than scrolling through menu's and remembering (or writing down) what is in each custom setting, Auto ISO setting, etc.
Thank you for coding & sharing this!
Michel
 Everaert's gear list:Everaert's gear list
Fujifilm X-T4
Macro
v1.02 Update
v1.02 Update
  • Added SET UP menus
Sample partial display below:
DROPBOX LINK to run file Fujifilm_X-T2_Camera_Settings_File_Display_v1.02.jar
Cheers
Macro
Truman Prevatt
Truman Prevatt Forum Pro • Posts: 14,596
Requirements:
How it works:
  • Run program
  • Select .DAT file
Downloads below...
Cheers
Macro
Macro,
Tried it with my X-H1 saved setup hoping the H1 and T2 would be similar enough.  No cigar. Got an error that the file was not the correct size.  Oh well, can blame me for trying ;-(
Truman
www.pbase.com/tprevatt
 Truman Prevatt's gear list:Truman Prevatt's gear list
Leica Q2 Monochrom Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 +12 more
Macro
Truman Prevatt wrote:
Macro,
Thanks for trying and reporting back. If you can upload a sample H1 .DAT file to dropbox, I'll see if the format is similar.
Truman Prevatt
Macro,
https://www.dropbox.com/s/7fgtchybuuj2snu/test.zip?dl=0
There are two in the above zip file.
Truman
Truman Prevatt
Macro,
I forgot to say that when I tried ver 1 it gave me the error message about wrong file length. I then tired your second version and it gave me an error message that is was an X-H1 not an X-T2.
Truman
Macro
Macro,
Thanks for the files.  Unfortunately, the X-H1 format is very different from the X-T2.  Many of the same fields exist, but they are scattered about in different locations.  The same goes for X-T1 DAT files.  It appears that commonality is not on the list of requirements when designing these files formats for different models.
Good catch on the second version not producing errors on file size.  I had disabled file size checking for testing and forgot to enable it again prior to release.
Truman Prevatt
Macro,
What would be nice is if Acquire generated a common file like XML
Truman
FotoChrister New Member • Posts: 7
I have downloaded the zip-file, but cannot find any .exe file to run.
I only see a .class file, MF-file and a picture file.
Help please.
Macro
Help please.
For the latest version, please download from the dropbox link in my post above titled "v1.02 Update".
There is no .exe file to run. Do not unzip or unpack anything.
The downloaded file should be named:
This is a Java "jar" file which is platform independent. It should run under Windows, Mac, Linux, etc.
  1. Download and save the file to the location of your choice (works anywhere)
  2. Double-click on the downloaded .jar file to run it
  3. File selection dialog appears
  4. Select an X-T2 ".DAT" file
  5. Click "Open"
  6. "Success" dialog appears showing where the resulting ".html" file was saved
  7. Click OK to close dialog
  8. Open the resulting ".html" file in any browser
Let me know if you have further questions.
Comments, suggestions, and bug reports are always welcome!
Cheers
Macro
Thank you very much for you help. I was able to proceed one step forward but got this error message when trying to open my backup file:
"Fujifilm_X-T2.DAT = 3869 bytes. Proper file size = 5660 bytes."
My backupfile was created in december 2017. Does your program not support DAT-files created with older firmware?
Macro
Thanks for your feedback.  To my knowledge, the firmware version doesn't matter.  Any newer version that generates a .DAT file should work.
One other user reported 3868 bytes. That file appears to be missing only the 7 CUSTOM SETTINGS at the end of the file.
I would like to...
1.  determine why some .DAT files are smaller
2.  determine why the 7 CUSTOM SETTINGS are sometimes missing
3.  update my code to accept the smaller files, but not display the missing CUSTOM SETTINGS.  (this will read your smaller file)
Have you ever changed any of the 7 CUSTOM SETTINGS defaults?  If not, please change a couple of settings in 2-3 of the 7 CUSTOM SETTINGS.  Save a new .DAT file, then check the file size.  "Normal" size is 5660 bytes.
Thanks!
Macro
Yes I had changed all 7 custom settings in the file that is 5660 bytes.
I did a test now where I changed 2 custom settings with the newest firmware and that generated a DAT file with the size 5660 bytes. I was able to restore this file without error, as expected.
Would you like me to test some more, let me know.
Macro
Please double check that your smaller file from 2017 is 3869 bytes... and not 3868?
When you saved the smaller 2017 file, had you changed any Custom Settings from the defaults at that time?
File size from 2017 file as showed in Windows Explorer:
Size: 3,77 kb (3 868 bytes)
Size on disk: 4,00 kb (4 096 bytes)
And yes, when I performed backup in 2017, I had changed several of the custom settings.
Macro
That's good.  A size of 3868 bytes agrees with the other users smaller file.  I have already updated the code to accept those files.  I'll post a new version here soon.
Are you using a newer version of Fujifilm X Acquire now than you were in 2017?  Perhaps older versions did not pull the CUSTOM SETTING info from the camera.
Macro
v1.03 Update HERE !!!
*** My original top post above cannot be edited. As a result, new update releases will continue to be posted further down in this thread ***
Please refer to my top post in this thread for more details about this program.
FUJIFILM X-T2 CAMERA SETTINGS DAT FILE DISPLAY
v1.03 Update
Updates include:
  • Added MOVIE SETTING data
  • Reads smaller 3868 byte DAT files which are missing CUSTOM SETTING data
  • Corrected RAW RECORDING bug
  • Corrected small layout bugs
  • Added missing tooltips
DROPBOX LINK to run file: Fujifilm_X-T2_Camera_Settings_File_Display_v1.03.jar
DROPBOX LINK to sample HTML output file: test1.html
Comments, suggestions, and bug reports always welcome!
Cheers
Macro
Below is a FULL screenshot of the sample HTML output file test1.html (download above). Click image below for FULL size display.
(Actual HTML file must be displayed in a browser to view the dynamic tooltips feature)
FUJIFILM X-T2 CAMERA SETTINGS DAT FILE DISPLAY - v1.03
