The new Panasonic Lumix G X Vario 35-100mm F2.8 II jitters like the old one?
Started Jun 27, 2018 | Questions
Matthias79 Regular Member • Posts: 217
Hi there!
I own the Panasonic Lumix G X Vario 35-100mm F2.8 OIS (from 2012), which has a pretty annoying jitter, when shooting video. Even with a firmware update this could not be fixed.
Does the new incarnation of that lens (from 2017) have the same problem?
I am shooting with a GH4...
Thanks so much!
Panasonic 35-100mm F2.8 II Panasonic Lumix G X Vario 35-100mm F2.8 OIS
amtberg Veteran Member • Posts: 6,217
Re: The new Panasonic Lumix G X Vario 35-100mm F2.8 II jitters like the old one?
Matthias79 wrote:
Hi there!
Thanks so much!
I don't know the answer to your question.  For me the jitter problem with the mark 1 was "fixed" when I went to a G85 and now G9.  IBIS eliminates it.
OP Matthias79 Regular Member • Posts: 217
Hi there, thanks for your reply! What I read on the internets the "Panasonic Lumix G X Vario 35-100mm F2.8 I" does perform better with the GH5, which has stablilization in the camera. But it's still not perfect.
Still, I'd very much like to know if the new lens fixes the jitter.
witzgall Contributing Member • Posts: 519
Did Panasonic ever state that they made a change to the focusing of that lens that would make "Jitters" go away? I always thought that the camera told the lens what to do, and that the lens just did what it was told.
Said another way, it is the camera introducing the jitters, never the lens, as far as I can tell. I have a GH3 and a G9, I'll test the two with the original 35-100 sometime soon and see if I can report back my findings.
Chris
Cambridge, MD
 witzgall's gear list:witzgall's gear list
Panasonic Lumix DC-G9
larsbc Forum Pro • Posts: 18,282
Matthias79 wrote:
Hi there!
Thanks so much!
Did you update the camera's *AND* the lens's firmware? I'm pretty sure Panasonic fixed that for the GH4 and GH5 (but not the GX7, much to my disappointment). Also, there is absolutely no video jitter with my G85 and my ver 1 35-100/2.8; where as my GX7 still has video jitter with that same lens.
The jitter is being caused by the OIS unit.
Thanks for the replies!
I have both the Panasonic Lumix G X Vario 35-100mm F2.8 OIS and the Panasonic Lumix G X Vario 12-35mm F2.8 ASPH Power OIS. Both lenses and my GH4 run with the newest firmware. In case of the 12-35mm the firmware update did fix the jitter pretty much completely. In case of the 35-100mm the firmware update reduced the problem a bit, but not much.
So, I think it's a problem in the lens, and I'm wondering if Panasonic fixed it with the Panasonic Lumix G X Vario 35-100mm F2.8 II Power OIS.
gteague
gteague Veteran Member • Posts: 3,005
zero jitter here with gh5 and newest 35-100/2.8 both body and lens fully updated.
/guy
"Before you take that shot, ask yourself: What Would HCB do?" ~/s
 gteague's gear list:gteague's gear list
Leica Q2 Leica CL Panasonic S1 Panasonic S Pro 70-200mm F4 OIS Panasonic Lumix S Pro 16-35mm F4
_vlad Veteran Member • Posts: 3,213
/guy
The same with old 35-100 and GH5/GX80.
Vlad
 _vlad's gear list:_vlad's gear list
Panasonic Lumix DMC-GX85 Panasonic GH5 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH +6 more
Sounds like instead of looking for a good replacement for my lens, I should get the GH5 ; )
I´m pretty sure you want be disappointed - GH5 is gem
Vlad
