How to take front element off 55-250 STM?
Started Jun 23, 2018 | Questions
saxyomega90125
saxyomega90125 Junior Member • Posts: 40
Well, I hike with this lens routinely and use it A LOT, so I'm not surprised, but it finally happened:
The sharp white speck above and to the left of the glob of flares, is a big dust particle in my trusty lens.
I've been inside several lenses before including my 55-250 IS MkI when I had it, all without incident, so I'm sure I'll be fine doing this one, but I like to watch a video first and I don't see any videos on taking this one apart. Same as the old ones, or do I need to know anything?
 saxyomega90125's gear list:saxyomega90125's gear list
Canon EOS 80D Canon EF 300mm f/4.0L IS USM Sigma 30mm F1.4 DC HSM Art Zeiss Milvus 100mm F2 Tamron 10-24mm F3.5-4.5 (B023)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: How to take front element off 55-250 STM?
saxyomega90125 wrote:
... do I need to know anything?
Things to know:
  • That spec is tiny and inconsequential. It has absolutely 0.000000000 effect on your pictures or the lens's resale value. Forget it.
  • Unless you have access to an ISO clean room, you'll introduce more dust and other contaminants than you can remove by opening it.
  • Once opened it'll be even less dust resistant.
  • You may (or may not) be able to put the front group back in the exact same alignment/spacing, so you may (or may not) affect the lens's performance.
IMHO, YMMV.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
saxyomega90125
OP saxyomega90125 Junior Member • Posts: 40
This is not the first piece of dust in there, just the first to create a problem. It is visible in some 250mm shots, depending on background, at f/7.1. Almost all by f/13.
That said, you had no way of knowing that.
That has not been the case with any photo lens or telescope I've opened in the past. I don't open them up without a good reason, and while I'm sure my space doesn't meet ISO spec, there's a saying my father has: "I don't do crappy work."
Why?
'Collimation' is the word. While this would be an issue if I were to tear it down to individual elements, the groups are collimated almost entirely using their own housings - even in the most expensive L lenses AFAIK.
