Ever see this? Glitch in GH4 file.
Started Jun 22, 2018 | Discussions
Roger Monroe Regular Member • Posts: 401
Jpeg from GH4 RW2 file
I shot a 700 image time lapse, at least two of the images suffered this fate. The two glitched shots were a few hundred apart from each other. Time lapse interval was 1 frame per second fwiw. The line is in nearly the exact same position in the file give of take 10 pixels. The line is in the raw file. Is it a card write error? Sensor error/ failure?
If anyone has insight on the issue, I'm all ears.
A blog for those making films of their family life: familyfilmmaker.net
Panasonic Lumix DMC-GH4
amipal
amipal Senior Member • Posts: 1,275
Re: Ever see this? Glitch in GH4 file.
I've seen that on both my GH3 and GH4. Incredibly rare though, and I couldn't tell you what conditions they were under when it happened.
It's almost as if a single line wasn't written to the file.
Paul
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
OP Roger Monroe Regular Member • Posts: 401
Thanks for responding ;-). I'm starting to wonder if it's the sensor failing to keep up. That said, it was shot at a slow frame rate which I wouldn't think would be a problem. I scratch my head.
JosephScha Veteran Member • Posts: 7,249
Last time I saw something like that it was because a laser beam had passed though the lens but but the damage to the sensor was permanent.  Don't take your camera into a disco with laser beams sweeping around.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
