iA+not working on new zs70?
Started 4 months ago | Questions
new2zs
new2zs New Member • Posts: 2
Hi
I just purchased a new Lumix DC-ZS70-when I switch to iA+ the screen is dark-itworks fine in every other mode-any suggestions will be appreciated.
new2zs
Panasonic Lumix DC-ZS70 (Lumix DC-TZ90)
kkardster
kkardster Veteran Member • Posts: 9,079
Re: iA+not working on new zs70?
new2zs wrote:
Hi
The only suggestion I can offer is to not use iA+ mode...! Many here would recommend shooting in A mode wide open for the most part.
But what you're [not] seeing would make me think it's defective, unfortunately.
Bruce
You learn something new every time you press the shutter
 kkardster's gear list:kkardster's gear list
Panasonic Lumix DMC-LZ7 Panasonic Lumix DMC-FZ200 Panasonic ZS100 +5 more
LoveEm New Member • Posts: 2
Is the view moving across to the viewfinder? If so the the settings need to be tweaked to make it monitor only or monitor/viewfinder switching which will use the IR sensor by the viewfinder to quickly move across.
