Incredible sharpness
Started Jun 21, 2018 | User reviews
YipMich New Member • Posts: 5
This is a very sharp lens and balances the camera body very well.  I have been using it on an NX1 for the past couple of weeks and I am getting incredibly sharp photos. The NX1 and this lens seem to be a perfect match in terms of sharpness, portability and comfort. I wish I knew this years ago before I spent thousands on lenses and bodies.
 YipMich's gear list:YipMich's gear list
Samsung NX1 Canon EF-M 22mm f/2 STM
Samsung NX 20-50mm F3.5-5.6 ED
Zoom lens • Samsung NX • EX-S2050NB
Announced: Sep 14, 2010
YipMich's score
5.0
Average community score
5.0
Samsung NX 20-50mm F3.5-5.6 ED Samsung NX1
Hienc Junior Member • Posts: 32
Re: Incredible sharpness
any sample images?
Veducci Senior Member • Posts: 1,359
It`s quite a decent lens but IMO the 20-50 range isn't really optimal with regards to being wide enough , and it also lacks OIS. I think it was the original NX kit lens.
NX bodies with this lens on Ebay are always are a harder sell and bring much less than the same body selling with the much better 16-50 OIS kit lens.
Unfortunately most earlier bodies came with the non stabilized 20-50 lens.
The 18-55 OIS was a much better option.
That all said , any of those  NX bodies that came with that bottom feeder 20-50 lens lens can be had now for less than $200 and can produce rather good images that hold up well even against newer equipment of most any brand.
My NX300 came with the very good 18-55 OIS lens but I sold off that lens too in favor of  the wider 16-50 OIS lens.
 Veducci's gear list:Veducci's gear list
Fujifilm FinePix F40fd Panasonic Lumix DMC-G3 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +3 more
thatfour Junior Member • Posts: 38
the lens i assume will be more durable than the ones with ois, a good compact lightweight & sharper(should be)  without the stabilization mechanism. good one when on gimbal
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
The same can be said...
...for many of the various "kit" lenses on the market from different brands.  I've used (still use) zoom kit lenses that give the big boys a run for their money, and short of having a constant F2 or F2.8, they hold up quite well in the optical clarity department.
Another excellent kit lens (for Samsung) is their 16-50 F3.5-5.6 IS Power Zoom lens.  One variable that typically plagues kit lenses are the copy-to-copy variations that occur in optical qualities.  If you get a good copy (which you apparently did with your 20-50), then you'll be smiling from ear to ear.  Of course, if you get a bad copy, then you'll be cursing it on the forums - it's a given.
I've never tried the 20-50 (felt it just wasn't wide enough for my tastes).  I have a copy of the 18-55 F3.5-5.6 III IS - but it is not a good copy at all (lot's of fuzziness in the edges).  But I have 3 copies of the 16-50 PZ lens - and all of them (miraculously) are superb copies and they've netted me outstanding results.
Sincerely,
Bernd ("Ben") Herrmann
Fuquay Varina, North Carolina USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
Kisaha Senior Member • Posts: 2,300
Re: The same can be said...
I did have a few PZ lenses in my time and I randomly kept the 1 I still own. I couldn't really tell if any of those was better than the others.
Ben Herrmann
The best way to discern...
...if you have a good, or just so-so, or horrible lens copy is to blow up the photo to 100% on your screen.  Now move to the left of the screen (preferably in an area that is supposed to have detail like trees, foliage, grass, etc - in the case of scenics).  Now cursor from left to right in the frame and look for the detail.
All lenses just about have excellent center portions of the screen and reality dictates that most lenses will have a little sharpness drop off at the edges (not all though).  You know you have a good copy if the sharpness pretty much holds up across the frame.
Unfortunately, many folks tend to evaluate a lens by initially just looking at a photo as a whole.  If it looks nice - well, then they assume it's a good lens - and who am I to argue with that.  But as time goes on and your sense of critical evaluation advances, you then notice sharpness (or lack thereof) in different parts of the frame.
But there are other variables involved that could fool someone into thinking that their lens may not be a good copy.  For example if you are shooting on a windy day and the branches, bushes, and grass are moving somewhat - the end result may appear as if things are soft, which they obviously are not.
Sincerely,
OP YipMich New Member • Posts: 5
I've had no luck at all with the 16-50mm "S" lens regardless of which body I put it on.. NX30, NX1000, NX1.   It also throws the balance of the camera off with its massive weight. It fails most times to focus accurately and I find the resolution low quaility. I was disappointed and considered selling off all of my samsung equipment.
Have you seen Fujifilm XE3? that with the 23mm 2.0 lens looks so good for going everywhere. That's a good replacement for the nx500. don't say that you're going to Sony
Anyway you S lens may have issue with the OIS that affect the sharpness. The after sales service is already dead anyway.
Veducci is referring to the 16-50 PZ KIT lens, nit the S lens.
The 16-50 S lens is one of the better zoom lenses I, and a lot other people - including the specialists in this site that awarded the 2015 best lens award- that I have ever used, and one of the main reasons a lot of us staying in the system.
It is an ideal combo with the NX1, obviously is a pro grade lens, and doesn't fit small bodies, but it is the only one starting from 2f, and stabilized (the Fuji isn't, Canon M has no pro lenses).
I seriously, and others that I have heard or read of, consider it as sharp as the 18-35 Sigma that everyone lovea so much, while it goes from 2-2.5f on a wider scale than the Sigma (24mm vs 28mm in full frame equiv. which is huge for me) and of course a lot more tele (but it is 2.8 after 35m, still it goes up there and transformed to a portrait lens at near 77mm full frame equiv.).
Samsung still officially services NX cameras, there are plenty of people doing it, even the last few weeks. Even in my country that have abandoned the camera market since the NX300 (final released NX camera here) and even for older bodies.
I am not going to sony yet. I own a sony and it is a fine camera.. it really is.  But my love of photography is enhanced by the samsung gear and its unique personality.  I think samsung was way ahead of the mainstream manufacturers back in 15 when they gave up.  I would try FUJI, and when I shot film, it was the best film to shoot with.
walter marshall Contributing Member • Posts: 924
I agree with you on the 20- 50 sharpness, all my Samsung lenses are very sharp, I did a job yesterday taking images of a friends art work, NX2000 using the 20 - 50, I have other cameras but decided to use the Samsung, small and light, would focus well, I used the wired remote, I knew the results would be good and show the colours in the paintings accurately.
Bazzer
 walter marshall's gear list:walter marshall's gear list
Panasonic Lumix DMC-LX3 Sony Cyber-shot DSC-R1 Panasonic Lumix DMC-FZ300 Nikon D300 Leica M9 +1 more
hezy11 Junior Member • Posts: 27
This is my own experience with this lens on my NX 500.
I keep it very carefully protected (Due to the fact Samsung shamefully abandoned us :-()in my studio solely for my art work at about 30mm f8 - which looks the sharpest results.
Haim
http://lorberboim.com
http://artnot4sale.com
 hezy11's gear list:hezy11's gear list
Samsung NX500
Turbguy1
Turbguy1 Senior Member • Posts: 1,467
I have two NX1000's arranged for synchronized stereophotography.  Both came with this kit lens.  I was impressed with both lenses IQ from the get-go.  Quite an accomplishment for a "kit lens" IMO.
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
wired remote eh??   tell me more please
I think there’s a wired remote made by JJC
