What is Happening to My Lens?
Started Jun 20, 2018 | Discussions
Andy01 Veteran Member • Posts: 5,191
Re: What is Happening to My Lens?
AiryDiscus wrote:
Andy01 wrote:
Alcohol maybe, but acetone NEVER !
Acetone is a VERY strong solvent - it is nail varnish remover. Designed to dissolve things. Used to soften resin etc.
Sorry, but only a complete fool would even consider acetone to clean a lens, unless they wanted to create a paperweight.
Colin
So is the largest manufacture of stock optics in the world a complete fool?
https://www.edmundoptics.com/resources/application-notes/optics/cleaning-optics/
Using acetone to clean lenses is ubiquitous within the optics industry.
An important point to stress is that you should NEVER clean plastic optics or optics in plastic housings with Acetone because it will damage the plastic.""
How many camera lenses do you own that don't have any plastic around the lens ?
I stand by my statement. Anyone who uses acetone (bearing in mind that most people would buy it from the hardware store, so definitely not "reagent grade" - whatever that is) to clean a camera lens is foolish.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
(unknown member) Senior Member • Posts: 2,180
Colin
Colin
Then every camera repair shop in the nation is foolish, both operated by the manufactures and third party.
ed rader Veteran Member • Posts: 9,068
yep happened to me too....
coating is soft on 24-70L II.  almost  $500 to replace.  don't start a thread asking if you should use a protective filter or else you'll awaken the AFJ ;^)
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
you are wrong....
ask roger at lensrentals how tough the coating is
groupoid Regular Member • Posts: 198
Lensauthority (outlet for lenstentals) is selling a front element for $50.
Might be worth a shot, but needs some research/risks.
https://www.lensauthority.com/products/canon-24-70mm-f-2-8l-ii-usm-front-lens-element-yg2-3004-010
 groupoid's gear list:groupoid's gear list
Sony a7R III Canon EOS M50 Canon EF 200mm f/2.8L II USM Canon EF-M 22mm f/2 STM Samyang 12mm F2.0 NCS CS +2 more
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
EF 24-70mm lens coating - known issues / examples...
7
zackdezon wrote:
After using Pancro and a microfiber cleaning cloth on this lens that got a little sunscreen on it, this streaky, hazy area has appeared and it doesn't want to go away. My fear is that I've somehow stripped the coating. Anyone familiar with this? I've taken a few test shots with it and everything seems sharp so far. Haven't noticed any haze over the images, either.
Sunscreen on a coated lens...
Sunscreen typically contains zinc oxide nanoparticles and titanium oxide nanoparticles. These are more abrasive than some toothpastes although they reflect UV light exceptionally well. They are considered so abrasive that skin testing was done on humans and (sadly) animals to determine how irritating the compounds were. The vapor-deposited coating on your front end element is so thin that it is quite easily rubbed off with simply pressure and a "lens cloth"... so applying sunscreen and then trying to wipe it all off carefully would certainly have resulted in a loss of coating. It might not have happened to other lenses but this lens has a long history of delicate coatings...
This appears to be a well documented issue...
The bad news is that you are not the first person this has happened to. When I first saw your post I assumed that you still had residue on your lens but I revisited the thread and noticed that the coating appears to have genuinely been altered. I read your original post and then spent a few days reviewing other opinions here and elsewhere online before seeking out numerous examples of similar problems from other users. It would appear that this lens is one of several which can lose their external optical coatings with little or no effort. The coating seems to break down and flake off quite easily in some instances. Adding a powerful solvent (sunscreen sometimes contains solvents and penetrative oils) and rubbing at the optical coatings can indeed strip this lens by weakening the bond between the optics surface and the coating. It's resolvable by replacing the outer element at considerable cost. So your solution will be to replace the outer element. Unfortunately, lens elements are no longer inexpensive to replace and the cost has risen considerably over the last decade to the point where people who positively hate using a protective filter will now do so. Another alternative will be to simply continue to use the lens although you may (or may not) notice lower contrast and a "foggy" appearance in some images, especially where the coating is missing or where the transition exists between the coated and uncoated lens.
The specific problem with this lens is that delamination appears to occur very quickly and somewhat easily. I understand that it's quite easy to lift the coating with oils and especially concentrated citrus oils. Sunscreen (as noted above) contains penetrative oils to aid in the spreading over skin and to retain it when immersed in water. Other methods of damaging the coating include applying window cleaner fluids and solvents of any kind. Using lens cleaning fluid designed for optics SHOULD not be a problem although in this instance, with this lens, it may be. Acetate is used as a paint thinner. It is sometimes referred to as a paint-stripper and with good reason. Using acetate for cleaning a lens in place of isopropol (which is normally quite commonly used for this purpose) would almost guarantee the lifting of a non-baked coating. Canon like to claim that their nano-coatings are baked but this particular lens seems to shed its coating under a variety of non-abusive conditions. I think Canon need to address it.
Filters for future lens use...
I was once a licensed Canon dealer years ago and I did not come across any examples of coatings wearing off except where sand and abrasives were involved. My own lenses have quality UV filters on all of them for safety reasons since I shoot in a variety of conditions and many of the modern multi-coated filters today (specifically higher-end modern filter options) allow up to 99% of light transmission with anti reflection properties (to reduce internal reflection). I'd encourage you to consider something like this with your future lenses. I'm using the Hoya models on my lenses.
Possible causes...
It's possible that these new metallic coatings are applied to a porous surface when first annealed to the lens optics. The coatings serve several purposes but if a metallic/ Magnesium is used (and I believe many coatings from Canon are indeed Magnesium fluoride), the contraction and expansion of the coatings against the glass optics may create micro-fissures which then initializes the delamination process. This will occur with temperature changes between hot and cold environments where the materials expand and contract. Obviously the process is not ideal when applied to this particular lens. Using anything other than a soft, dry microfiber cloth at this point is simply going to lift the fragmented surface coating and I suspect that this is what's happening here.
Some examples of similar problems to your own were easy to find online. Many are fairly recent and imply that the problem is a relatively new one. The first example seemed to be your own images until I compared them more carefully. It certainly looks the same.
I thought this was the OP's lens.
Almost a spitting image of the original photograph from the OP (above).
My own experiences with Sunscreen...
I once avoided using sunscreen when shooting on a beach for what I thought would be three hours (that became four) one summer in 47.7C (114F) heat during summer ... because I knew how destructive the compounds in sunscreen would be to the camera I was using and the L-lenses I was carrying.... I foolishly assumed that a baseball cap with T-shirt and jeans would be enough. I had sunglasses on. But this exposure resulted in 2nd degree burns to my face and arms. The doctors warned me that if the burns progressed or were any worse, they'd have had to consider skin grafts to my face.
From my experience as a prospector in the Australian bush, sunscreen has properties that can strip the reflective coatings from sunglasses and cause damage to the soft rubber eye-piece of cameras. I've also been aware that it can discolor some plastics and cause damage to rubber (eg focus rings and zoom rings). The only solution is to try and source a less "corrosive" (for lack of a better term) sunscreens when shooting outdoors. We need to protect our skin and we need to protect our lenses.
Some relevant online posts relating to this lens below.
It's surprising how many people have been vocal about this problem online and considering how important this lens is to wedding and commercial photographers it's a concern that these coatings are so fragile. You don't need a lecture from anyone here and your mishap is not your fault.
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
BlueRay2 Forum Pro • Posts: 14,816
Re: EF 24-70mm lens coating - known issues / examples...
that is one great documentation of this issue and should be kept for reference! thanks for your work and sharing it with us!
RCicala
RCicala Contributing Member • Posts: 820
AiryDiscus wrote:
Colin
Colin
Then I am foolish. We don't use it at full strength, but 5% to 10% markedly improves cleaning effectiveness. I am, however, taken aback to think that people are  using so much cleaning solution they're getting it on the plastic around the glass.
RCicala
Re: you are wrong....
If you are talking about Canon 24-70 f2.8 Mk II coatings, they are very fragile. That lens, by itself, changed our 10 year policy of not using protective filters after we replaced well over 200 front elements at $225 per.
saxyomega90125
saxyomega90125 Junior Member • Posts: 40
Agreed. If this lens has its own page, that post should be pinned to it IMHO.
 saxyomega90125's gear list:saxyomega90125's gear list
Canon EOS 80D Canon EF 300mm f/4.0L IS USM Sigma 30mm F1.4 DC HSM Art Zeiss Milvus 100mm F2 Tamron 10-24mm F3.5-4.5 (B023)
(unknown member) Senior Member • Posts: 1,388
RCicala wrote:
AiryDiscus wrote:
Colin
Colin
That is what people use to remove fingernail polish.
What the heck is on that lens that you would need something as strong as acetone to clean it ?
Colin
Colin
My truck windshield has almost 80,000 miles on it and I have never needed anything stronger than Windex to clean it
The only time I saw acetone being used on cameras was to clean hard to clean camcorder VCR heads..
https://www.bhphotovideo.com/explora/photography/tips-and-solutions/how-clean-your-lens-and-filters
stevedavidsonphotography wrote:
RCicala wrote:
AiryDiscus wrote:
Colin
Colin
it boggles the mind--sticky tar maybe?
RCicala wrote:
AiryDiscus wrote:
Colin
Colin
I sure am going to not let sun screen get on my lenses !  Wow !
Armando J. Rodriguez, Jr. Senior Member • Posts: 1,169
Thanks for your post, Marco Nero (N.T.)
'Heavens declare the glory of God,' and I hope my pictures will too.
https://www.flickr.com/photos/arodri3/
 Armando J. Rodriguez, Jr.'s gear list:Armando J. Rodriguez, Jr.'s gear list
Canon EOS-1D X Canon 6D Mark II Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +4 more
