Samsung NX20 questions
Started Jun 18, 2018 | Questions
Com Post New Member • Posts: 10
I have a faulty NX300 that only works with manual lenses (I use a Minolta 50mm)
The NX300 gets great results in a test situation but its a pain to use in bright sun with no viewfinder and no AF.
I'm thinking about getting a used NX20, and my question is:
Does the NX20 have focus check that works with any lens?
My NX300 does but I've tried a NX10  and the focus check only works with Samsung lenses in MF mode.
Samsung NX20 Samsung NX300M
kypfer Contributing Member • Posts: 985
Re: Samsung NX20 questions
Can't confirm for the NX20, but I asked the same question about my NX5 a couple of weeks ago and managed to ascertain that pressing the "OK" button with a manual-focus lens+adaptor fitted caused the viewfinder image to magnify 2x, which makes life a lot more comfortable
I acquired my NX5 second-hand specifically with view to using it with my old Russian rangefinder lenses, which it does perfectly, within the limitation that some wide-angle lenses protrude too far into the camera to fit.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
OP Com Post New Member • Posts: 10
Thank you Kypfer, I have tried the OK button on a NX10 and it doesn't work, but on a NX300,NX100 & your NX5 it does!  As you say it makes a big difference in the use of old lenses.
Does anybody have a NX20 they can check on?  I just want to know if you can zoom in to focus check using the ok button.
wpstl Senior Member • Posts: 1,251
I can check later this evening.
"Sometimes I like to throw a grenade and run away."
 wpstl's gear list:wpstl's gear list
Samsung NX1 Sony a7R II Sony a7R III Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
It worked for me on my NX20 using a Nikon lens.
That is great thankyou. Strange that it doesnt work onthe NX10 when it works on every other NX camera checked so far!
I'll look out for a used NX20 body on ebay UK, I've seen a few go cheaply recently.
It might just be worth "double-double-double" checking the NX10 (again).
When I first tried this feature on my NX5 it didn't work, and I've still no idea why, but I suspect, in hindsight, that I may have invoked another "feature", unintentionally, with my big fingers and thumbs trying to find somewhere "safe" to hold the camera, thereby disabling the viewfinder magnification feature.
Good luck, whatever your solution
