Common mistakes for Sony/mirrorless newbies?
Started 8 months ago | Questions
Peech New Member • Posts: 13
7
Hi, a few months ago I bought my A9 and switched to mirrorless after shooting SLR/DSLRs for more than 20 years. Still getting used to how this works.
I just realized that the reason I've been having trouble with AF in low-light (I shoot a lot in restaurants at dinner time) was that I chose to have the setting effect ON in LiveView. As I tend to shoot food at f/5.6 even with f/2.8 lenses, this meant that I was losing a lot of light while focusing as the lens is stopped down - something that doesn't happen in DSLRs. I've now corrected that issue.
So it got me thinking: are there other common mistakes people make when first switching to mirrorless, which aren't issues when shooting DSLRs?
Many thanks in advance for your help and advice.
 Peech's gear list:Peech's gear list
Canon EOS 7D Canon EOS 6D Sony a9 Canon EF 15mm f/2.8 Fisheye Canon EF 24mm f/1.4L II USM +8 more
Sony a9
Zefah Regular Member • Posts: 301
Re: Common mistakes for Sony/mirrorless newbies?
Not really a mistake, but it's good to know how the Sony autofocus system works and what its limitations are. Here's a nice video on the subject.
https://www.youtube.com/watch?v=cqfj6bao5XQ
 Zefah's gear list:Zefah's gear list
Sony RX100 V Fujifilm X100F Sony a9 Sony FE 35mm F1.4 Sony FE 35mm F2.8 +8 more
Beatsy
Beatsy Contributing Member • Posts: 512
12
Thinking Sony mirrorless will only backup your DSLR - not become your primary camera. A mistake that very quickly self-corrects
 Beatsy's gear list:Beatsy's gear list
Sony a7R II Sony a9 Canon MP-E 65mm f/2.5 1-5x Macro Sony Carl Zeiss Planar T* 50mm F1.4 ZA SSM Carl Zeiss Apo Sonnar T* 2/135 +13 more
EcoR1 Regular Member • Posts: 120
9
It seems to be a very common misconception , that adapted lenses behave as good or almost as good as native lenses in all AF situations. They do not. When investing to mirrorless system you should understand that in the end native lenses are what you want. MF-lenses are a different story though.
Rol Lei Nut Veteran Member • Posts: 4,046
11
It seems to be a very common misconception , that native lenses are the only way to go...
vpilot
vpilot Regular Member • Posts: 436
Not reading the manual (well, that might be an issue when shooting DSLR too).
vpilot
 vpilot's gear list:vpilot's gear list
Sony RX100 II Sony a7R II Sony a6300 Sony a7 III Sony E PZ 18-105mm F4 G OSS +10 more
noggin2k1
noggin2k1 Senior Member • Posts: 2,278
9
The biggest mistake I see Sony users making is baiting Canon & Nikon users on these forums.
 noggin2k1's gear list:noggin2k1's gear list
Sony a9 Fujifilm X-T3 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Zeiss Batis 85mm F1.8 +6 more
tommiejeep Veteran Member • Posts: 6,338
All depends on what you shoot.  My DSLR has another DSLR  for second camera and my Sony a7rii has a a7iii as second camera.  Different uses
Anticipate the Light and wing it when you get it wrong but always have fun
Tom
http://images.nikonians.org/galleries/showgallery.php/cat/500/ppuser/165169
Dennis from Florida
Dennis from Florida Regular Member • Posts: 269
....into thinking that some day in the near future, Canon and Nikon will also have a similar or better technology.
 Dennis from Florida's gear list:Dennis from Florida's gear list
Sony a7R III Sony 70-300mm F4.5-5.6 G SSM Sony FE 85mm F1.8 Sony FE 12-24mm F4 Sony FE 24-105mm F4 +3 more
KwhyChang Veteran Member • Posts: 5,952
Finding the Perfect Lens By Trying Multiple Copies
22
People trying out 5 copies of lenses to find the perfect copy think this will somehow improve their photography.
Dave
noggin2k1
8
I'm hoping that comment is meant as a joke, because that sort of attitude is the problem with these forums.
All manufacturers create kit capable of taking world class pictures, it just so happens that for us Sony users, Sony make the stuff that best meets our individual needs. It's cringeworthy when I see the "there's no point even taking a picture if you're not using Sony" sort of comments.
MisterHairy Senior Member • Posts: 2,269
Thinking that Sony now has a comprehensive lens selection.
Thinking that Sony will improve features through firmware updates.
Thinking that Sony has a competent software engineering team for their cameras.
Really beautiful photograph!
 MisterHairy's gear list:MisterHairy's gear list
Fujifilm X100F Sony a7R III Sony a7 III Sony FE 35mm F2.8 Sony FE 55mm F1.8 +7 more
Lightshow
Lightshow Veteran Member • Posts: 6,733
If you're shooting in controlled light, then Setting Effect On isn't really needed once you set and lock your exposure, whereas if the lighting is changing or you are varying the exposure it is far more useful to judge exposure with it on, though you could substitute it with the histogram if you don't have enough light for AF.
A Manual Focus Junky...
One photographers junk lens is an artists favorite tool.
http://www.flickr.com/photos/lightshow-photography/
[My Lens list](http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow)
####Where's my FF NEX-7 ?????
Firmware request:
-A button map for toggling the EVF & LCD
-Still waiting for the minimum shutter speed with auto ISO for my NEX-7 and A7r. I know it will never happen.
-Customize the display screen layout, I'd love to have both Histogram and level at the same time.
-More peaking options, being able to set peaking sensitivity and a threshold level.
-An RGB overlay on the histogram https://c1.staticflickr.com/1/602/20236258313_c604dd9522_n.jpg
-An option to return the focus assist zoom to one button press
-An option to return to how the NEX-7 handled playback, ie. center button to zoom, then you could use the control dial to zoom in and out, then center button to exit the zoom mode.
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Leica Elmarit-M 24mm f/2.8 ASPH Leica APO-Summicron-M 90mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar +20 more
Hank Radt Contributing Member • Posts: 856
vpilot
Agree. But would add that worth getting a good guide (I've used Friedman for my a6300 and a7R2, others like Busch) to really take advantage of all the capabilities.
 Hank Radt's gear list:Hank Radt's gear list
Sony a7R II Sony a6300 Sony E 10-18mm F4 OSS Sony 2.0x Teleconverter Sony 1.4x Teleconverter +8 more
What lenses are you missing: http://briansmith.com/sony-a7-a7r-a7s-lens-guide/ ?
Good quality tilt/swing and shift lenses for professional landscape and product photography.
Sony is now great for many things but these are branches of paid work which are accustomed to having those movements available and the benefits are very real.
Third Party lens makers are doing an amazing job of propping up the Sony brand but I guess that they don’t see Sony as having enough of a foothold in those markets to warrant the development of a range of movements lenses. A pity because the cameras are eminently well suited to product and fine landscape photography.
[yes, yes, I do realise that these have traditionally been the realms of medium format (and larger) but there is enough of a 35mm segment to support CaNikon maintaining T/S product lines.]
By the way, I did actually say “Thinking that Sony now has a comprehensive lens selection” and the vast majority of the lenses on the very cool link are third party. You will find that off-brand lens ownership in professional use is low.
Now, I do realise and accept that I am the only one who is mentioning professional use and the OP’s question did not imply this in the slightest so I do agree that I am subverting the question slightly. Only slightly though.
vpilot
Friedman is a genius.
vpilot
WalterJ1959 Regular Member • Posts: 407
I need to shoot video in Slog2 or Slog3 but I have no idea why or how and I have not read anything on Picture Profiles. Gamma Curves or Color Space. Please Help!
Profiles http://helpguide.sony.net/di/pp/v1/en/contents/TP0000909109.html
General help
http://www.xdcam-user.com/camera-setup/a7-a7s-a7r-and-other-a7-series-cameras/
How can I uncompress Log to rec 709?
https://www.sonycreativesoftware.com/download/catalystbrowse
 WalterJ1959's gear list:WalterJ1959's gear list
Sony a7R III Canon EF 135mm F2L USM Canon EF 70-200mm F2.8L IS II USM Sony E 50mm F1.8 OSS Sigma 35mm F1.4 DG HSM Art +4 more
Arizona Sunset
Arizona Sunset Senior Member • Posts: 3,795
Mistakes that I made alone the way:
  • Tricking the camera to autofocus effectively on horizontal contrast points. Hint: they all like vertical, contrasty lines.
  • Not customizing the Fn menu and C buttons to your needs.
  • Not using the custom shooting mode presets.
  • Recording in SLOG when I am searching for minutes of spare time each day.  Color grading takes time.
  • Waiting five years for a native 35mm f2 AF.
 Arizona Sunset's gear list:Arizona Sunset's gear list
Canon G7 X II Sony RX1R II Sony RX100 VI Apple iPhone 7 Plus
