Macro Lighting for Oly 60mm f2.8?
Started Jun 11, 2018 | Discussions
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
Re: Macro Lighting for Oly 60mm f2.8?
can someone explain to me what the difference in effect is between one like this and one which sits over the flash such as this one https://www.tomtop.com/p-d1265.html?currency=GBP&aid=bpagb1&mid=10000019969&utm_source=SEM&utm_medium=Bing+Ads&utm_campaign=TT_GB_PA_BMZ&utm_content=2917&utm_term=4575892518181875
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Peter 1745 Senior Member • Posts: 2,022
The link you point to is "reflector" which is a different thing to "diffuser". The reflective surface can be silver or white, the former giving harsher reflections than the latter. The product description incorrectly calls itself a "diffuser softbox", which it isn't.
Light is shone through diffusers but bounces off reflectors.
Diffusers tend to spread the light more than reflectors and also soften the light more.
Diffusers are also typically used nearer to the subject than a reflector which increases the relative size of the light source which softens the light even more. The rule of thumb when using a diffuser is that it should be no more than its diameter in distance from the subject.
Both diffusers and reflectors give a softer light than a bare flash and for many subjects it doesn't matter which you use.
With the reflector you linked to you get 2 components of lighting. The reflected light hits the subject directly (the reflector acting as a larger light source) and the light that misses the reflector and bounces arround the room giving indirect softer lighting. If used outdoors there is no bounce component.
With a diffuser you just get 1 component of lighting, a large soft light close to the subject.
Softboxes usually have internal refecting surfaces to spread the light out before it hits and passes through one or more diffusion panels giving more even lighting than a diffusion panel on its own.
Peter
'Keep taking the photos'
Trevor Carpenter
Thanks, my education continues
(unknown member) Veteran Member • Posts: 7,274
And to add there that with diffuser one can place a second just after first one to make it more softer, or add a different light shapers like grids to still avoid light spilling.
dontfret
dontfret Senior Member • Posts: 2,340
This a fancy version of the age-old 3x5 white index card (your UK equivalent size?) held with a ponytail elastic to the flash. aka Bounce Card.
Rich
Take many pictures - a few are keepers, the rest are are lessons.
 dontfret's gear list:dontfret's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-G5 Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +12 more
