Pro 12-40/40-150+TC replacement with 12-100+what?
Started Jun 11, 2018 | Discussions
wsedf New Member • Posts: 16
I have currently the 12-40/40-150+TC pro lenses with E-M1.1. I'm thinking about the replacement with 12-100. Plus something for supertele range and a fast prime(s).
I see the next options for tele:
1: Oly 75-300 II - not too fast
2: Pana 100-300 II - which IS is better, the IS of lens or the IBIS of E-M1.1? Better F-value.
3: 4/3 Oly 70-300 + MMF-3
4: 4/3 Oly 50-200 SWD + MMF-3 (+ EC14/EC20)
What do you think, which has the best IQ together with sufficient AF-speed on E-M1.1?
The main purpose (only as hobby): landscapes, my twins - running kids and some wildlife occasionally.
I search something to replace the 100-210 range from 40-150 Pro+TC, if it's possible, not loose too much IQ, however a longer tele would be nice.
 wsedf's gear list:wsedf's gear list
Olympus E-M1 Olympus OM-D E-M1X Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital 35mm 1:3.5 Macro Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
Geekapoo
Geekapoo Senior Member • Posts: 2,831
Re: Pro 12-40/40-150+TC replacement with 12-100+what?
7
Why would you want to get rid of lens that are easily among the best for m43 cameras to buy inferior lens??? The 40-150 f2.8 is spectacular,  as is the 12-40 f2.8.
 Geekapoo's gear list:Geekapoo's gear list
Sony RX10 IV Fujifilm X-E3 Sony a7R IV Sony a9 II Sony 35mm F1.4 G +15 more
mazzuccato
mazzuccato Senior Member • Posts: 2,730
I have the 12-100 but I never tried 12-40 and 40-150. But I had the panasonic 12-35 and I should say that the 12-100 is as good as the panasonic premium lens. It is actually extremely good in all its focal range and as one lens solution is extremely convenient. Now, considering that you still want a double (or triple lens kit) I’d stick with your lenses, unless you need more reach. In this case adding the oly 50-200 + tc to the 12-40 would have the best iq for the price. If you can spent more, you cold wait for the new panaleica 50-200 + tc.
Stefano
 mazzuccato's gear list:mazzuccato's gear list
Sony RX100 Panasonic Lumix DMC-GF1 Olympus PEN E-P5 Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH +8 more
epozar
epozar Senior Member • Posts: 1,969
You need one more body. Lenses you have are optimal.
 epozar's gear list:epozar's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix DC-G9 OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +10 more
Toni Genes
Toni Genes Regular Member • Posts: 323
I think Panasonic 100-400mm is also a good choice to consider - focuses fast, it is long and F/6.3 at the end is OK.
50-200MM swd + EC-14 will focus very fine on E-M1, is good also for fast action.
50-200mm SWD + EC-20 will also focus fine on E-M1. For fast action (fast birds in flight) you might need to zoom out to get a faster speed.
50-200MM swd alone is fast enough for swallows in flight.
Of course, mft lenses are optimized for mft bodies and will focus faster than the old 4/3 lenses. So my vote will go for Panasonic 100-400mm.
 Toni Genes's gear list:Toni Genes's gear list
OM-1 Olympus M.Zuiko 300mm F4 IS Pro
gary0319
gary0319 Forum Pro • Posts: 10,540
I have the Oly 12-100 and the PanLeica 100-400. Great two lens combo, but kind of $pendy. I have an Oly 25 1.8 for low light museums, etc.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
ijm5012 Senior Member • Posts: 1,889
So you're saying that the 12-100 is inferior?
Do you happen to know how the OP uses his lenses, what type of photogray they're in to, etc? Or are you just making that statement baselessly?
 ijm5012's gear list:ijm5012's gear list
Nikon D500 Nikon Z6 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 300mm f/2.8G ED-IF VR Nikon AF-S Nikkor 85mm F1.4G +6 more
gary0319
I don’t find my 12-100 to be inferior to my 12-40, at all. In fact, I have found my 12-40 to be sharpest when stopped down to f/4, and my 12-100 to be sharp through the whole focal range at f/4.
If anything, the 12-100, with dual IS is superior to the 12-40 in all respects, except size and weight.
Geekapoo
My limit experience (reading reviews) is that the 12-100 is inferior vs the 12-40. More important,  if already owning the 12-40 and 40-150, why jettison those lenses for the 12-100? With the TE, the OP has 12-210mm m43 coverage with two of the best m43 lenses!
10
Ah, ok. So no hands-on experience with the lens then?
I can say that as an owner of the 12-100 (and prior owner of the 12-40 & 40-150), the 12-100 gives up nothing optically to the f/2.8 PRO zooms.
As for why someone would want to sell the 12-40 & 40-150 for the 12-100? I did it because the 12-100 is a better all-in-one landscape lens. I can carry one lens instead of two, saving weight and space in my bag, without giving up anything optically. It was extremely rare that I shot anything landscape-wise wider than f/4, with the majority of my shots being between f/4-f/8.
I'm not certain what lens reviews you read, but if you look at LensTip (12-100 , 12-40 , 40-150 ), but the 12-100 is better than the 12-40 at 12mm, and about the same at 25mm (and that is with both lenses at f/4, so the 12-40 should be better since it's stopped down a full stop). The 40-150 is a bit better at 100mm than the 12-100 when shot at f/4, but by f/5.6 they're on equal footing.
Unless you've had personal, hands-on experience with both lenses, I would refrain from saying which lens is better. I've owned all three, and am happy with the 12-100 as a landscape lens compared to the f/2.8 duo. It takes up less space in my bag, and weighs less, which is always an advantage when you're walking/hiking multiple miles a day.
OP wsedf New Member • Posts: 16
I know, if I use the 12-100 and not the holy pair (12-40/40-150), I will loose some IQ. This "some" as far as I read here and on others sites also, it not so terrible loss. The 12-100 is also a PRO lens. It gives you the possible best. The 2.8 vs. 4.0 at the end is equal to 1EV. So, it can be managed in case of shutter speed vs. ISO (without night scenes).
The DoF will be not so narrow, but for that and night shots, I will buy used 1,8 prime(s).
Big benefit will be for me the "one lens" set for general daylight scenes.
My OP was interested for longer tele range. Longer as 100 and keeping as much as possible in IQ (comparing with 40-150+TC) with a reasonable AF.  For that, the 50-200 SWD seems to me the winner and later EC14/20 is I find a low price piece.
Answers for current posts:
I know, the current lenses are the best. In the past, these were the best choice to cover from 24mm to 300. What I see, changes the lenses (especially, if my wife would take photos) not so convenient and capture the moments with my twins. The 40mm border is somehow a disturbing effect.
A second body is also a good option, but care two bodies means bigger package.
What I see from the reviews, the 12-100 in IQ is almost get the level of the two pro zooms. Not so good, but for a general usage is more than enough.
I used sometime the 40-150(and TC) at the longest range but not so often and in these cases, it was not enough long. Therefore I search an additional lens after 100 (but keep much IQ as possible).
Pana 100-400: too high price to use rarely.
As I see, the 50-200SWD (even with EC-xx) is today a friendly price.
So, I would not a three lens kit, but 2+1 different kit.
1: 12-100 + 1 prime (it"s fit to my smallest, one-day bag and allowed to take care the small kids also)
2: only prime(s) for night
+1: all together for big trips
Yes, the 100-400 is really nice and $. May be in the future, however the new fast primes are really attractive. The used 1.8 primes have a friendly price so. My wallet prefer these lens not the 1.2 primes and I think, a F1.8 would be more used as the 100-400@400. So, I search some cheaper solution for tele but not the cheapest.
Space the final frontier Senior Member • Posts: 1,229
I have 12-100 as well as 12-40; they serve different purposes imo. The 12-100 is my travel lens. Of the tele zooms in your list, I can endorse the 50-200 SWD with no reservation. I had the Oly 75-300 ii but found it lacking in sharpness. It is not a bad lens but clearly inferior to the 50-200 SWD. Paired with E-M1, AF is fast and secure. The downside is size and weight.
 Space the final frontier's gear list:Space the final frontier's gear list
Olympus E-M1 II Olympus E-M1 III Olympus Zuiko Digital 35mm 1:3.5 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Sigma 70mm F2.8 EX DG Macro +14 more
Henry Stamm Veteran Member • Posts: 3,553
I can't speak to the m4/3 options you have or are considering. However, I do own and use the 4/3 50-200swd lens a fair amount on my Em1.2. It focuses quickly and accurately. I also pair it with both TCs (1.4 & 2.0). I have used it for landscapes and also for sports, both with & without the TC. So if price is a major consideration and you don't mind the size & weight, it could be a very viable option for you.  I also own 4/3 75-300mm.  It's only real benefit over the 50-200 with TC1.4 is size & weight.  Optically, it's nowhere near as good.
 Henry Stamm's gear list:Henry Stamm's gear list
Olympus E-M1 II Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +8 more
Garry Schaefer Veteran Member • Posts: 3,349
I believe Henry meant the Oly 4/3 70-300.
Garry
 Garry Schaefer's gear list:Garry Schaefer's gear list
Panasonic Lumix DMC-G3 Olympus OM-D E-M10 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +8 more
Skeeterbytes Forum Pro • Posts: 23,182
Will note that a 4/3 tele such as the 50-200 plus adapter plus TC is pretty cumbersome (three mount pairs) and can produce disconnects. For anybody already owning the lenses adapting them to an E-M1 is a great option but adding them to an existing m4/3 kit one should be ready to accept limitations, including slower focus response compared to native lenses and much slower burst speeds, important for anybody considering action work.
From what you've outlined I'd swap the 12-40 with the 12-100 and keep the 40-150+MC14. If you want more reach than 210mm then you're looking at the 100-400 or 300 Pro, or the new Panny 200 to keep the quality and speed.
Good luck,
Rick
Colin Smith1 Senior Member • Posts: 1,104
Just buy an Olympus 1.4 converter and keep the 40-150 since it will use the converter.  Makes it a 116-420.  I use this combo all the time.  I sold my 12-40 and replaced it with the 12-100.  All is good!
Colin Smith
 Colin Smith1's gear list:Colin Smith1's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 85mm F2 Macro IS STM Canon RF 800mm F11 IS STM
Colin,
Why would you recommend the OP buy the TC, when he already stated he has the TC (it's even in the information you've quoted)?
CharlesB58 Veteran Member • Posts: 9,829
I recommend the 50-200 4/3 with adapter. I use the non-swd version and it's a stellar performer.
Photography is not about the thing photographed. It is about how that thing looks photographed. Quote by Garry Winogrand
http://eyeguessphotography.com
http://livegigshots.com
