Should I return/replace my lens? EF-S 55-250mm sharpness/focus
Started Jun 7, 2018 | Questions
streetsnyc New Member • Posts: 11
Hi,
I'm concerned about the sharpness of my lens. Can you guys help me see if there's anything wrong with it?
Lens: Canon EF-S 55-250mm
Body: Canon Rebel T6i
I use autofocus on the center point, and I do believe that I use settings that are generally supposed to come out with sharp photos, such as an appropriate aperture + 1/FL, etc.
I'm still within the return period, and am wondering where the problem lies: lens, body, or perhaps it's just operator error? Or perhaps all of these images are acceptably sharp for this lens.
Many thanks in advance for your help
Focus point is on back of head, but hair seems to be not "tack-sharp." I submitted this to ShutterStock and it got rejected for out-of-focus.
Fur seems blurryish
 streetsnyc's gear list:streetsnyc's gear list
Canon EOS Rebel T6i Canon EF 50mm F1.8 II Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EF-S 24mm F2.8 STM
Canon EF-S 55-250mm f/4-5.6 IS STM Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
OP streetsnyc New Member • Posts: 11
Re: Should I return/replace my lens? EF-S 55-250mm sharpness/focus
Here's another shot I just took. Shot in JPG, so this file is directly uploaded as it was shot.
I don't know, it seems like things are just fuzzy compared to some other shots I've seen on the forum. Thoughts?
R2D2 Forum Pro • Posts: 26,551
ISO is out of control, with over-done processing (reduces detail). Lots of veiling glare, greatly reducing micro contrast.
There might be an underlying softness, but you'd have to test for that specifically.
Recommend the new 70-200/2.8 III.
Best of luck!
R2
BAK Forum Pro • Posts: 26,019
This part is operator error
WRONG -->> I use settings that are generally supposed to come out with sharp photos, such as an appropriate aperture + 1/FL, etc. <<
With a camera like yours, double (actually cut in half) the shutter speed. i.e. go to 1/250 instead of 1/125, and so on.
BAK
Cats are fuzzy. God made them that way.
Try to make some sharp pictures.
If you succeed doing that, you'll know the lens is fine. (It probably is.)
Start by finding a subject that is actually sharp. Magazine pages taped to a wall are frequently sharp.
The face of a wrist watch on an arm resting on a chair are often sharp.
Use a high shutter speed and a tripod, and sharp, not diffused, light.
Use a moderate ISO
Try several apertures. Try several focal lengths.
And after you capture the image using digital science, use the sharpening controls to make it even sharper.
BAK
Steve Balcombe Forum Pro • Posts: 15,582
Yep.
And the girl has probably walked out of the plane of focus!
photonius Veteran Member • Posts: 6,895
streetsnyc wrote:
Hi,
Fur seems blurryish
as mentioned by others, the cat shots with ISO 4000 or 3200 show lots of processing artefacts, that's not the lens.
start off with something static and flat, using live view and a tripod to check if the lens is sharp, 100 ISO.
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
Zeee Forum Pro • Posts: 25,641
Nope. For what this lens costs it does a very good job.
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
Autofocus performance?
Thanks everyone for the suggestions and help!
By using live view and taking a photo of an analog wrist watch, I think that I've determined that the lens can definitely create sharp images. What do you think? I know it's not ideal as my space is not well-lit and I had to shine a flashlight to even see anything...
Manual focus
Auto focus
So, given that, I believe that it is not my equipment that is defective, and that it's just me that needs improvement
Any general tips for capturing sharp images when it comes to shooting street portraits of people or animals in motion? For instance, I'm never sure if I should use AI Servo or One Shot. It's hard to do a controlled test of this, for obvious reasons
Speaking of which, would the autofocus system of my camera be another issue? Because I believe that I achieved the sharpest image (using the watch as a test) by manually focusing. The difference is barely noticeable except when viewed at 100%, but it made me wonder if there's anything I can do to optimize AF accuracy? For instance, I use an AmazonBasics UV filter.
Jura S Senior Member • Posts: 1,980
Re: Autofocus performance?
What mode of focus acquisition do you use?
jvc1 Senior Member • Posts: 2,202
7
Get a hood and get rid of the UV filter. Cheap filters will degrade image quality.
I keep some of my favorite pictures here,
https://www.flickr.com/photos/129958940@N03/
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
If you are going to use one get  B+W or something like that. It may cost as much as the lens.
Dave
Dave Veteran Member • Posts: 6,231
Good to see the watch is also working.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
I typically use One Shot autofocus, but have also experimented with AI Servo. I've read that AI Focus isn't reliable or is generally rubbish.
Good advice re cheap filters and hoods. I'll replace my filter with a better one. As for the hood, I'm not sure which to buy. Is there a specific form/shape I should look for? Or would a generic 58mm lens hood suffice?
You are going need to adapt to using AI Servo for anything moving. When the subject comes into focus in the viewfinder - fire away. Trust the process.
You might want to check on the AF-ON to help with AF.
Dave
A third-party hood will be fine, but get one that fits properly.
Thanks Dave. Would you you recommend a petal over a tube hood?
GregoryA
GregoryA Contributing Member • Posts: 602
If you have an ebay account, just search "canon 55-250 hood" and take your pick of the cheaper 3rd party offerings.
 GregoryA's gear list:GregoryA's gear list
Canon G3 X Canon G7 X II Canon EOS 6D Canon EOS 7D Mark II Canon EOS 5DS R +28 more
Thank you so much, I remember experimenting with back-button focus and, for whatever reason, forgot to get back into that practice. I think maybe I was doing street photography, using a 24mm lens and shooting from the hip using FlexiZone AF. But now that I have this telephoto zoom lens, I'll be far enough away to use the viewfinder.
I feel very fortunate to have so many people sharing their knowledge
Here's a tip
Go to Youtube and look up Joe McNally's tape Da Grip.
https://www.youtube.com/watch?v=EDsx3-FWfwk
Follow his instructions and your photos will be sharper.
Me?
I lean against things.
Hold your camera against your face, and lean the back of your head into a telephone pole.
Push the side of your camera against a power pole.
Rest the camera on the roof of your car. Turn the engine off.
Find a fence pole. Put the camera on top.
Make a stack of books. set the camera on top.
Set your camera off by using the self timer.
Pay attention to the wind. That's why tree leaves are not sharp.
Pick a place where your subject will be. Use high speed clickety-click, turning the camera on before the subject arrives at this spot, and turn it off after the people go past.
Etc.
BAK
