Prime vs.zoom price
DrFzs Regular Member • Posts: 116
Prime vs.zoom price
Why is prime lens more expensive than zoom?
In prime lenses there are less moving parts than in zoom.
Cheers
DrFZs
 DrFzs's gear list:DrFzs's gear list
Sony a99 II Sony DT 11-18mm F4.5-5.6 Sony 70-300mm F4.5-5.6 G SSM Sony 70-400mm F4-5.6 G SSM II Sony 24-70mm F2.8 II +9 more
Labe
MOD Labe Veteran Member • Posts: 9,164
Re: Prime vs.zoom price
its not that cut and dried though . Take the 35mm f1.8, 50mm f1.8 and 85mm f2.8 . you can all three of those primes new for less than the price of zoom lens covering similar focal length and apertures.
 Labe's gear list:Labe's gear list
Fujifilm FinePix IS-1 Fujifilm X-S1 Sony Alpha NEX-3 Sony a6000 Sony a5000 +4 more
tqlla Veteran Member • Posts: 4,791
Cheers
DrFZs
You are probably looking at different tiers of Quality.  IE the 24-70mm Zoom is $2k new.
 tqlla's gear list:tqlla's gear list
Sony RX1R II Sony Alpha DSLR-A850 Sony Alpha a99 Sony a99 II Sony 16mm F2.8 Fisheye +10 more
sybersitizen Forum Pro • Posts: 11,925
Which lenses are you talking about?
A good prime lens (most are fairly good) should cost more than a poor zoom lens (some are fairly poor). Conversely, a good zoom lens can easily cost more than a good prime lens.
There are also other variables involved.
Moving parts don't contribute much to cost. A 50/1.4 lens can be much more expensive than a 50/1.8 lens with a similar number of moving parts.
MediaArchivist
MediaArchivist Veteran Member • Posts: 4,876
Not so!
The Sony 70-200mm f/2.8 G SSM II (zoom lens) is about $3000, but the Sony 85mm f/2.8 SAM is less than $300!
Want a roXplosion!?
 MediaArchivist's gear list:MediaArchivist's gear list
Sony a99 II Sony 24mm F2 SSM Carl Zeiss Distagon T* Sony 135mm F2.8 (T4.5) STF Sigma 35mm F1.4 DG HSM Art Sony Carl Zeiss Planar T* 50mm F1.4 ZA SSM +22 more
Lensmate
Lensmate Veteran Member • Posts: 3,135
Cheers
DrFZs
One example [of many reasons] here:
https://www.youtube.com/watch?v=ovxtgj4SsiI
-Martin P
https://www.flickr.com/photos/photosauraus_rex/
OP DrFzs Regular Member • Posts: 116
The question was wrong. I was talking about high quality zoom and prime. The price also depends on the size of the lens. (Thank you Martin).
Thank you for reading and replying.
AkashRana
AkashRana Regular Member • Posts: 251
Though it's not true for all the lenses(as there are cheap primes), I believe it's partially due to the components and materials used those expensive lenses which give them excellent image quality besides being sturdier and fast silent focusing, etc. The other bit which I believe is to push these lenses as pro grade by marking them up high which gives a way higher perception about them then what they actually do. Its more to do with psychologically tuning the brain to believe that these are the only lenses which can do miracles.
 AkashRana's gear list:AkashRana's gear list
Sony SLT-A68 Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004) Sony DT 16-50mm F2.8 SSM Sony DT 11-18mm F4.5-5.6 Sony DT 35mm F1.8 SAM +8 more
toughluck Veteran Member • Posts: 3,217
Which ones specifically?
 toughluck's gear list:toughluck's gear list
Sony a99 II Sony 85mm F1.4 ZA Carl Zeiss Planar T* Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-300mm F4.5-5.6 G SSM +5 more
ActionPhotoPassion Contributing Member • Posts: 987
Are you talking of primes of the caliber of:
* Minolta 100/2 ?
* Minolta 35/2 ?
Those primes quite keep their value by time and for a very good reason
 ActionPhotoPassion's gear list:ActionPhotoPassion's gear list
Konica Minolta Maxxum 7D Sony SLT-A58 Sony a77 II Sony a99 II Sony 28-75mm F2.8 SAM +15 more
I think the OP means new lenses, not used ones. Otherwise he wouldn't have mentioned moving parts, and more complex manufacturing, none of which apply to used lenses.
Jeadm Senior Member • Posts: 1,848
There are many considerations beyond what has been made: Economy of scale for a particular product, what else is out there to compete with a particular model, pricing what the market will bear rather than how inexpensive a product can be sold for ...
 Jeadm's gear list:Jeadm's gear list
Sony a77 II Sony DT 35mm F1.8 SAM Tokina AT-X Pro 11-16mm f/2.8 DX Sony 85mm F2.8 SAM Sony DT 18-135mm F3.5-5.6 SAM +15 more
There are millions of used lenses that involve 'more complex manufacturing' and 'moving parts'.
The OP has given us no information on what he's actually talking about, so he's basically wasting our time.
tbcass
tbcass Forum Pro • Posts: 40,258
They aren't always. The opposite is often true. For example the Sigma 24-70 f2.8 ART lens is $1200 while the Sigma 50mm f1.4 ART is selling at $850. I can site many other similar examples. Maybe you should be more specific about which lenses you are comparing. My impression is that between lenses of equivalent quality and focal range the primes are usually cheaper.
You are probably thinking about the very fast primes which are optically better than primes. A good example is comparing a 150-600mm zoom which is f6.3 at 600mm vs a 600mm prime which is f4. That 600mm f4 has massive glass elements and is heavier than the 150-600.
Tom
Look at the picture, not the pixels
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony RX10 IV Sony a99 II Sony DT 35mm F1.8 SAM Tamron SP AF 90mm F/2.8 Di Macro +10 more
Evildogofdoom
Evildogofdoom Senior Member • Posts: 2,116
Complicated isn’t the issue, glass is. Expensive primes have expensive glass. The fluorite lens elements in modern fast supertelephotos are made from crystals that can take up to a year to grow to the size of the front elements of a 300mm f2.8 or 500m f4 lens. A150-600mm zoom uses much cheaper lens elements and will have much larger production runs, allowing further economies of scale.
 Evildogofdoom's gear list:Evildogofdoom's gear list
Sony RX100 II Sony a99 II Sigma 150mm F2.8 EX DG OS Macro HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony Alpha a99 +15 more
Thank you for your answers.
I didn't know that the 150-600 containes far cheaper pieces than the 300 and 500 lenses.
Cheers:
Dr. FZs
