Example of fitting a Peak Design Capture v3 to thick backpack strap
Started Jun 6, 2018 | Discussions
noirdesir Forum Pro • Posts: 13,748
Backpack strap is about 65 x 16 mm, while the width between the two lugs on the Capture clip is only 56 mm. You can fit it in by simply squeezing the strap along its width. I've used the Allen key screws because they are a bit longer. As you can see further below, they are long enough such that they can be screwed in far enough such that their end is flush with the bottom of the Capture clip.
Nikon 1 V3
Merowech New Member • Posts: 23
Re: Example of fitting a Peak Design Capture v3 to thick backpack strap
Thank you!
