EOS M10 switches itself off
Started Jun 5, 2018 | Discussions
DJSanjay
DJSanjay Regular Member • Posts: 121
My camera is acting weird and switching itself off when I attach and use an old FD lens (70-150 f/4.5) with the adapter. The last time this happened it emitter a series of beeping sounds and then switched off. This is weird because the camera is working fine with the kit lens and an FD 50mm lens with the same adapter. Do you guys have any idea what's happening and what I can do? Thanks in advance!
Canon EOS M10
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
Wasn't that FD lens made in 1979?
You are using a lens marketed in 1979 that was never designed for use on a digital camera.  Incompatible lenses will usually trigger several beeps from the camera before it powers itself down. I mounted my camera to a telescope with no contacts and it did the same.  I had to enable the menu setting that allows me to use the camera "without a lens attached". FD lenses also produce a slightly different focal length on Digital cameras and a lens with zoom (and moving parts) is likely to cause the camera distress when varying amounts o light hit the sensor without registering the aperture changes via the lens contacts.  The Prime lens ought to work better.
I assume you are using them with Manual Focus selected on your camera menu?  Since this lens is probably more than 20 years old, you might want to check the area that comes in contact with the camera's contacts where the mount is to see if it's producing a contact (though I'd doubt it).
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
DJSanjay
OP DJSanjay Regular Member • Posts: 121
Re: Wasn't that FD lens made in 1979?
Thanks for the suggestion! There shouldn't be any contact because the adapter prevents this. I already have the "release shutter without lens" option enable d. I'll try playing around with Av mode and see if that works, because shutting down happens in both manual and Tv modes. This is disappointing and makes me feel kind of stupid 😕
DJSanjay
I found the cause of the problem: the SD card bay want closed properly and the card wasn't fully slotted in! False alarm lol.
Marco Nero
false alarm!
That's good to hear.  I'm glad everything should work fine for you now.
Marco Nero.
tamaraw35 Contributing Member • Posts: 784
"...is likely to cause the camera distress when varying amounts o light hit the sensor without registering the aperture changes..."
I can assure you, no distress is caused. A lens is a lens and barring any further complications like protruding rear elements, anything with a flange distance longer than 18mm should be technically compatible with the ef-m mount. It doesn't matter when it was designed, all a lens does is gather light. Assuming the "release shutter without lens" menu item is ticked, it will work with anything and auto-meter exposure based off of the amount of light hitting the sensor, not an electronically communicated aperture value. Please do not spread mis-information!
Source: I have used my M10 with many adapted and quite old lenses (FD, ltm, F, etc.)
Edit: Also Prime lenses will not work better, just the same, and you do not need to set the camera menu to mf, simply focus the lens manually and take the photo.
