MY CAMERA'S POP UP FLASH IS NOT SYNC WITH THE SHUTTER
Started Jun 3, 2018 | Discussions
KATIA1981 New Member • Posts: 6
I HAVE A CANON DSLR 760D
THE CAMERA'S FLASH IT FLASHES BUT THE PHOTO IS STILL DARK. I THINK THE FLASH IS NOT SYNC WITH MY CAMERA ANY MORE.I HAVE ALREADY RESET ALL MY FLASH SETTINGS AND THE PROBLEM PERSIST. IF I USE AN EXTERNAL FLASH ON MY CAMERA ITS OK
IS IT THIS POSSIBLE MY CAMERA'S FLASH NOT BE SYNC WITH THE SHUTTER ANY MORE? AND HOW CAN I FIX THIS PROBLEM? WHAT IT CAUSES THIS PROBLEM
Canon EOS Rebel T6s (EOS 760D / EOS 8000D)
Digirame Forum Pro • Posts: 41,858
Re: MY CAMERA'S POP UP FLASH IS NOT SYNC WITH THE SHUTTER
It's possible it's not working properly or you can adjust the in-camera flash.  See the internet for instructions if you don't know how to do that.  It's called flash compensation.  Also you can try increasing the ISO level and see if that helps.
R2D2 Forum Pro • Posts: 26,551
Welcome!
Can you post a sample for us (with EXIF intact).
TIA!
R2
rmexpress22 Senior Member • Posts: 2,304
My guess would be that your aperture is either very small or your subject is far, or a combination of both. It's possible that your flash can't provide enough power. But, yeah, post samples with exif intact.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
guinness2
guinness2 Veteran Member • Posts: 4,617
Is it like the flash is just helping to focus and switched off, otherwise ?
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
OP KATIA1981 New Member • Posts: 6
THE PROBLEM PERSIST AND WITH HIGH ISO. WHEN I PRESS MY CAMERAS BUTTON THE FLASH FLASHES AT WRONG TIME SO MY PHOTO IS UNDER EXPOSED. THE FLASH IS OUT OF SYNC WITH THE SHUTTER
EVENTHOUGH I AM VERY CLOSE TO MY SUBJECT THE PROBLEM PERSIST. THE FLASH FLASHES AT WRONG TIME. ITS NOT SYNC WITH MY SHUTTER. I WILL POST PHOTOS TONIGHT
IT FLASHES TO FOCUS AND THEN IT FLASHES AGAIN WHEN I PRESS THE BUTTON BUT THE PHOTO IS UNDEREXPOSED. THE FLASH DOESNT SYNCRONISED WITH THE SHUTTER
dwalby Veteran Member • Posts: 5,895
1. is the entire image illuminated  by the flash, or is only part of the frame illuminated?
2. what shutter speed, f-stop, and ISO setting do you have set, and how far away is your subject you're trying to illuminate?
Iron Mike
MOD Iron Mike Contributing Member • Posts: 540
Without seeing a sample photo, with EXIF, I'm just making guesses:
1) the most likely culprit from your descriptions is that you have the flash in wireless commander mode. The flash is firing to send a signal to an external unit, but with none present you end up with an underexposure.
2) The FEC may be dialled way down
3) Your aperture is too small to allow reasonable exposure with the onboard flash
4) Your subject is too far away to be well lit by the onboard flash.
Mike
MarshallG
MarshallG Veteran Member • Posts: 8,968
Try 1/60 second shutter speed. Or 1/30
Does it sync with slow shutter speeds?
A sync failure will appear as a dark, almost black band in your photo. It's very noticeable.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
Re: Try 1/60 second shutter speed. Or 1/30
I HAVE TRY DIFFERENT VALUES BUT THE RESAULT IS THE SAME! THE PHOTOS ARE ALWAYS VER UNDEREXPOSED! I HAVE TAKEN TODAY MY CAMERA FOR SERVICE.
Could you post a sample for us?
MarshallG
TURN OFF THE CAPS LOCK
5
Please!  We can read lower case just fine.
Thanks.
Re: TURN OFF THE CAPS LOCK
Thanks.
Heck I'd even take a sample (with the EXIF in CAPS!)
R2
Yeah, seriously. We're going to need a picture with exif in caps.
PeterSp New Member • Posts: 2
Hi
I had exactly the same issue after replacing the camera top cover assembly due to someone else having damaged the flash section. It seemed like the flash was out of sync with the shutter and then when it seemed to work okay, the image was underexposed. The issue was that the previous user of the camera had set the flash operation mode to "EasyWireless", once I had set it back to "NormalFiring", it works perfectly.
To get to the setting, turn the camera on, press the Flash button once to raise the flash, then press the Flash button again to get the Flash Control screen.  Then the first line has the settings for NormalFiring/EasyWireless/CustomWireless, just select NormalFiring.
Peter
Mark B.
Mark B. Forum Pro • Posts: 29,758
PeterSp wrote:
Hi
Peter
Welcome to the forum.  You've replied to a 2 year old thread in which the OP never came back to indicate whether any of the suggestions helped, and never posted any sample pics.  My guess is the OP is long gone.
