40-150 2.8 on EM1- Mk2 Stuck on Manual Focus (MF)
Started Jun 2, 2018 | Discussions
abe4652 Veteran Member • Posts: 3,147
I haven't used the 40-150 in a little while, and the EM1 works fine, focusing AF, with other lenses.
But when I put on the 40-150, it doesn't autofocus and the front panel keeps showing MF.
What could be causing this?
Olympus 40-150mm F2.8 Pro Olympus E-M1
robonrome
robonrome Senior Member • Posts: 2,334
Re: 40-150 2.8 on EM1- Mk2 Stuck on Manual Focus (MF)
is the manual clutch engaged?
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
Derp1 Junior Member • Posts: 46
Well if it is the focus ring clutch being engaged you are going to feel a bit dumb :).
OP abe4652 Veteran Member • Posts: 3,147
Yes, it was.
I'm an idiot. I hadn't used it in a while, and was used to seeing an AF/MF switch on a Panasonic. Once I moved the clutch, yes it worked.
Thanks!
robonrome
8
Yes, it was.
Thanks!
we have all been there
jthommo101 Contributing Member • Posts: 574
Yes, it was.
Thanks!
Indeed we have!
 jthommo101's gear list:jthommo101's gear list
Fujifilm FinePix F10 Zoom Pentax *ist DS Pentax K20D Panasonic Lumix DMC-GM1 Olympus E-M1 II +21 more
Thomas Kachadurian
Thomas Kachadurian Veteran Member • Posts: 3,733
Yes, it was.
Thanks!
Not an idiot. I do it all the time during weddings. The ring gets moved and in the heat of the moment I forget why it won't focus. Since I only use back button focus I never need an mf switch. On all my canon and Panasonic lenses the switch is taped down on AF. You can't do that with the 40-150. It the only thing that keeps it from being perfect.
Tom
www.kachadurian.com
Call me crazy. I happen to like photos of cats.
 Thomas Kachadurian's gear list:Thomas Kachadurian's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
Space the final frontier Senior Member • Posts: 1,229
I made that mistake fairly frequently; I posted a thread here. Now I have disabled it in the menu.
 Space the final frontier's gear list:Space the final frontier's gear list
Olympus E-M1 II Olympus E-M1 III Olympus Zuiko Digital 35mm 1:3.5 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Sigma 70mm F2.8 EX DG Macro +14 more
