GRIP for E-P5?
Started Jun 2, 2018 | Discussions
riveredger Veteran Member • Posts: 3,860
GRIP for E-P5?
Can anyone recommend a grip for the E-P5?  I am not looking for a wooden or bamboo one, though.
Olympus PEN E-P5
wolfychi Senior Member • Posts: 1,158
Re: GRIP for E-P5?
There aren't many grips available for the E-P5, I use one of this.
e-p5 grip
It does add some extra weight and size to the camera, but otherwise work quite well, you can find one on Ebay easily, about $20
OP riveredger Veteran Member • Posts: 3,860
Re: GRIP for E-P5?
Thanks...do you have access to the battery compartment?
Re: GRIP for E-P5?
yes, the battery door can be opened, although need to have finger nail because the space is quite tight.
dougjgreen1 Veteran Member • Posts: 4,068
Re: GRIP for E-P5?
e-p5 grip
After extensive searching, that was the only one I found other than the aforementioned wood and bamboo grip.   But it's quite hard to find available, though.   And when I did, I passed on it because of the added weight.
 dougjgreen1's gear list:dougjgreen1's gear list
Olympus Stylus XZ-10 Nikon 1 V2 Olympus PEN E-P5 Olympus E-M1 Olympus E-PL7 +17 more
PoohBill
PoohBill Regular Member • Posts: 363
Re: GRIP for E-P5?
RRS made a lovely set for the P3 but this was the only one I was ever able to find for the P5. I have it mounted on the body carrying the 75-300 whenever I need the tripod. It has some rough edges, but works as advertised and was ridiculously cheap compared to what RRS charges.
Let us know if you find something finer.
Bill
 PoohBill's gear list:PoohBill's gear list
Olympus 12-40mm F2.8 Pro Olympus E-M5 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +2 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
No GRIP for E-P5
Just an alternative view, but I have never found the need for a grip on my E-P5, even with the 75-300mm or my usual 12-40/2.8.
Maybe it's my habit of using screen only and using a home-made wrist strap that makes normal holding more comfortable. The right hand only lightly holds the camera and the left hand balances the weight of body plus lens.
Plus of course I like to keep the whole package as small as possible.
Regards..... Guy
Re: No GRIP for E-P5
Regards..... Guy
Yeah, I DO like keeping the EP5 small, so I am waffling on actually buying one of the ebay grips.  I may just get a half case for some added grip.
jackkurtz Veteran Member • Posts: 4,724
Re: GRIP for E-P5?
I made my own out of Sugru, but I don't have the E-P5 anymore. I always thought these grips looked good. They do have access to the battery compartment.
https://www.amazon.com/J-B-Camera-Designs-Wood-Olympus/dp/B0149Q0Z8W/ref=sr_1_2?ie=UTF8&qid=1527991288&sr=8-2&keywords=E-P5+grip&dpID=51McgnId5ZL&preST=_SX300_QL70_&dpSrc=srch
 jackkurtz's gear list:jackkurtz's gear list
Fujifilm X-Pro3 Fujifilm X-T4 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS XF 90mm Fujifilm XF 35mm F2 R WR +3 more
