DIY Design, GorillaPod Hybrid/Arca baseplate
Started Jun 1, 2018 | Discussions
zapwizard Forum Member • Posts: 61
Howdy Folks,
Problem:
I use two different tripods, as well as a Peak Design camera strap. Each of these three things all use the same mounting point on the camera.
Solution:
Design my own base plate which combines the features of all my current baseplates into a single component. No more swapping out baseplates, just tripods.
I 3D printed a prototype, and then onces I was satisfied I ordered it in a stronger solid nylon from Shapeways.
 zapwizard's gear list:zapwizard's gear list
Panasonic Lumix DMC-GX8 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic 20mm F1.7 II Samyang 12mm F2.0 NCS CS +1 more
Urfin Regular Member • Posts: 106
Re: DIY Design, GorillaPod Hybrid/Arca baseplate
FWIW I've bought an Arca clamp, mounted it on the GorillaPod and use Arca Swiss baseplate on the camera. Your way is much cooler though!
 Urfin's gear list:Urfin's gear list
Canon EOS 5D Sony a7 III Canon EF 85mm F1.8 USM Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm F4L USM +3 more
S_V Regular Member • Posts: 107
Which one is yours?  The red and black one?
 S_V's gear list:S_V's gear list
Canon EOS 7D Canon EOS M3 Canon EOS 80D Canon EF 24-70mm f/2.8L USM Canon EF 70-200mm F4L USM +9 more
OP zapwizard Forum Member • Posts: 61
The red one is mine. It has the angled sized to make it work with clamp style tripod heads.
