canon 17-40L on canon sl2 or on sony A6300 with metabones adapter
Started May 30, 2018 | Discussions
kayaker156 Forum Member • Posts: 75
currently using a t2i and want to upgrade. going nuts researching. unable to find any sony lens comparable to the 17-40L. this canon lens is the only one that i use.
finding all kinds of stories about metabones. some good some bad.
the dpreview of the sl2 describes it as an entry level camera for the casual photographer. I consider myself a serious amateur, not a pro.
need help. thanks.
ThrillaMozilla Veteran Member • Posts: 7,681
Re: canon 17-40L on canon sl2 or on sony A6300 with metabones adapter
"Entry level" cameras are fabulous, and I haven't heard anything bad about the SL2. More $$ gets you mostly bigger size and weight, and more sophisticated focusing.  For that you can try the T7i, 77D, or 80D.  Many more $$$$ gets you a bigger sensor. You could help us if you tell us what "advanced" features you think you need.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
photosen Veteran Member • Posts: 6,226
need help. thanks.
The 17-40 is an ultra wide angle lens when used on full frame cameras... On APS-C it's no longer ultra wide angle, so you get the worst of UWA (mushy corners) at focal lengths much better covered by other lenses, starting with the 17-55 2.8, but also the 18-55, 18-135 and whatever third parties offer.
If you wanted an UWA on APS-C, the 10-18 and 10-22 make more sense.
Sony probably covers these focal lengths, but not at the same price, even without considering the price of the adapter.
The best bokeh goes unnoticed, grasshopper.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm F2.0 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +3 more
No you don't.  The corners are cut off.
OP kayaker156 Forum Member • Posts: 75
thanks for replying Thrilla.  it's a done deal-am now the proud owner of an sl2.  i see now that i really wanted to hang on to my 17-40.  love that lens .  the sl2 allows me to do that.   doubt if i'll even use 1/2 the bangs and whistles that it has.
just really wanted to go smaller, light and upgrade camera.  all accomplished with the sl2.
couple of people put sony in my ear and that's what caused me to go nuts.
MikeJ9116 Veteran Member • Posts: 6,958
A lot of serious photographers use the SL2 as a second camera and/or backup body. I use one to compliment the 6D I own and is fills this roll wonderfully. The IQ is identical between the 80D, 77D, T7i and SL2. Just pick the camera that meets your needs regarding features versus price. I picked the SL2 mainly for its small size and have found it to greatly exceed my expectations. If you don't need 45 AF points or a deep shot buffer then then their isn't much reason to choose the 77D or T7i over the SL2 unless body size is important. The 80D brings a few things like micro focus adjustment, large battery capacity and a few firmware tweaks but doesn't deliver any better IQ than the SL2.
Also, if you plan to use Canon lenses then I recommend sticking with a Canon body.  The A6300 is a good camera but it lacks things like touch screen ability, swivel screen and some other features that make me eliminate it as a camera I would consider buying.
I replied before I read this post.  With the money you saved buying the SL2, consider picking up the EF-S 55-250mm STM zoom.  Make sure it is the STM version.  Or maybe the Creator's Kit from Canon that has the EF-S 10-18mm ultra wide angle lens and the EF 50mm STM prime lens.  Either choice would be a great compliment to the EF 17-40mm lens you currently use.
clark321 Contributing Member • Posts: 502
I could live with most of the negatives of the A6300 but the price of the lenses makes expensive to buy. Generally the lenses are  twice the price of equivalent canon lens.
 clark321's gear list:clark321's gear list
Canon EOS 6D A3000 Sony a6500 Canon EOS Rebel T7i Canon EF 135mm F2L USM +4 more
RedFox88 Forum Pro • Posts: 30,738
....and features, controls,  performance , options. You get what you pay for!
The SL2 is the best value camera in Canon's APS-C line... including the EOS M cameras.  Once AF (MFA with the 80D), shot buffer and size (some consider this a liability) is considered, what compelling reason is there to buy anything other than the SL2?  Are these "improvements" worth paying twice the price of the 80D?  You infer the SL2 is a cheap, low feature camera when it is far from this.
Selene Senior Member • Posts: 1,308
Not only is the Sl2 a good value camera, it is also quite small. I wasn't expecting much from the camera. I got it as a relatively inexpensive camera to use in my kayak and on pontoon and other small boats. I really don't want a lot of fancy features, just a simple camera that is capable of producing sharp photographs in not very good conditions.  It has worked well for that (the Sl1 I had also worked very well for that purpose).  I have full frame cameras for other kinds of photography I do, but I wouldn't hesitate for a minute to recommend the Sl2 as a good basic camera, especially with the 18-135 lens, although I mostly use it with the 70-300 II USM Nano.  It is a great light combination (as is the camera with the 17-40 lens).
Snapperhead216
Snapperhead216 Regular Member • Posts: 265
I just sold my A7 II and 2 lenses because I couldn’t afford to build the lens system with Sony. The Canon 10-18 and 50 1.8 for $450 got the to make the move. This is $1350 with Sony (on sale).
 Snapperhead216's gear list:Snapperhead216's gear list
Canon EOS R7 Canon EF 17-40mm f/4.0L USM Sigma 105mm F2.8 EX DG OS HSM Canon EF 40mm f/2.8 STM Sigma 150-600mm F5-6.3 | C +2 more
keeponkeepingon Senior Member • Posts: 1,588
I'm a T2i owner tempted by the SL2 (and M50).
Now that you own the SL2 how do you feel it's an upgrade to the T2i?
Better "live view" a smidgen smaller is there anything else that stands out?
Thanks!
 keeponkeepingon's gear list:keeponkeepingon's gear list
Canon EOS 5D Canon EOS 550D Canon EOS M Sony a6000 Sony a5100 +1 more
stratobill Senior Member • Posts: 2,081
I have been using and loving the SL2 even though I have a full 6D rig.
The 17-40 should be fine on the SL2, I have been using the 16-35 F4L on it and it is an awesome combination though limited somewhat in reach.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
I was going to say the same, the 16-35F4L Is amazing on the SL2, blows away the kit lens completely. YMMV.
Not to mention that you can find the Canon lenses refurbed or used, many more of them around,
Thanks!
I have the SL2, had the t2i, as well as the 6D.
I would say that the sensor is the main improvement, around a stop better in noise, plus better more manageable noise quality. More megapixels for better resolution.
The live view is great for shooting from the touchscreen, you'll use it more than you think.
Thanks!
Oh I forgot the touchscreen.   Yes I know I'll use that a lot!
I have an EOS-M and I love canon's touch screen implementation with touch to AF and touch to snap the picture. And on image preview you have pinch to zoom in/out which going between the camera and a smartphone just feels natural.
One thing that is holding me back is that they dropped the feature where you can take a picture while taking a video.  Totally happy snap hanging out with the kids non-pro feature as you'd get a hickcup in the video but I loved being able to get a video and still at the same time using just the one camera. Canon and Sony have both dropped the feature from all their current cameras so the only option is Panasonic  but I'm still not convinced I'd find the smaller sensor acceptable.  Having 4K almost makes up for the lack of the feature but for that I'd have to wait for the SL-3......
