Compression is Real
Started May 26, 2018 | Discussions
Great Bustard Forum Pro • Posts: 42,852
It is, but entirely due to position, not focal length.
6
JackM wrote:
The examples of "compression" (or, more appropriately, "perspective") below are due entirely to the position of the camera and positions of elements in the frame.  If one had used 100mm from the same position that the 400mm photo was taken from, the "compression" would have been the same, but the framing would have been 4x wider.
So, for sure, we can say that *for a given framing*, "compression" is a function of the focal length *for a given format*.
However, the problem with saying that "compression" is due to focal length without specifying both for a given framing and for a given format, is that people will incorrectly assume, for example, that a 50mm lens has a certain "compression" associated with it regardless of the sensor behind the lens (this same mistake is made with DOF as well).  And, to be clear, no, a 50mm lens on APS-C does not have the same "compression" as a 50mm lens on FF unless both photos are taken of the same scene from the same position, in which case they'll have a rather different framing.
In the end, it's much more simple to explain "compression" as the effect of perspective, and effect which is determined *entirely* by where the camera is located for a given scene, and the the framing is determined by the [equivalent] focal length for a given perspective.
100mm
164mm
271mm
312mm
400mm
Any questions?
Not a one.  You?
(unknown member) Senior Member • Posts: 2,498
Re: It is, but entirely due to position, not focal length.
True dat...
J.
Tom_N Forum Pro • Posts: 15,265
Re: Compression is Real
5
JackM wrote:
Wheatfield7 wrote:
JackM wrote
Any questions?
Did you figure this out on your own or did someone help you?
It’s my rebuttal to a number of recent pedantic articles and posts.
It's a flawed "rebuttal".
A lot of people claim that the focal length of the lens determines perspective, that a wide angle lens exaggerates features and a telephoto one compresses them.
That isn't so.  It is the camera-subject distance(s) that determine perspective.  Lens focal length just aids or hinders framing.
The error in the OP's argument is that his photos, taken with very different focal lengths, exhibit almost identical subject sizes and framings.  This implies that he changed the camera-subject distance(s) for every shot.  And it was that change in distances that produced the (perspective) "compression" in the more telephoto shots.
Nice try, but no cigar.
confused circle Senior Member • Posts: 1,932
Not only is it real, it is effectively created by the lenses you can access. Unless people feel like throwing away resolution and cropping like hell for no practical reason. Oh no, it's the distance! Guess what's going to dominate your distance choices. You aren't moving mountains, trees, buildings and the like. You aren't telling that group of players to repostion themselves for your convenience. You probably aren't soldering on a different sized image sensor in your body. So guess what, the lens you've slapped on is your biggest determining factor. And guess what you're going to do when that lens doesn't work consistently for your shooting. You're going to buy another focal length. Less likely that you will toss all your gear of the given sensor format just so you can get a totally new set to typically stand in a different spot for those shots you were having issues with.
 confused circle's gear list:confused circle's gear list
Sony a7R II Sony FE 28-70mm F3.5-5.6 OSS Sony FE 50mm F1.8 Sony FE 85mm F1.8 +5 more
kiwi2
kiwi2 Veteran Member • Posts: 4,115
Tom_N wrote:
JackM wrote:
Wheatfield7 wrote:
JackM wrote
Any questions?
Nope, the OP has a valid point.
You need the longer focal length at the further distance. Otherwise the shot won't work relative to the frame.
 kiwi2's gear list:kiwi2's gear list
Fujifilm X-T2 Fujifilm X-T100 Samyang 8mm F2.8 UMC Fisheye Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R +4 more
kiwi2
Exactly
Exactly.
Maintaining the foreground subject size in the frame (the baseball team in this case) with different focal lengths requires a change of distance.
Big Stick Regular Member • Posts: 411
dwalby wrote:
JackM wrote:
400mm
Any questions?
are the skies really that beige color, or is that a "compression artifact"
Those are the famed Canon colors.
ajs jones New Member • Posts: 4
Compression is simply caused by moving the camera away  (=changing the perspective) - you simply choose to use a longer lens to record it  If you like the effect, you first choose a perspective (camera position) that alters the apparent relationship of the sizes of the objects in the scene to achieve the effect and THEN you choose a long lens.  If you use a shorter lens but a smaller sensor you will record exactly the same "compression" from the same place - same compression from a different lens, so it can;t be caused by the lens
PhozoKozmos
PhozoKozmos Senior Member • Posts: 1,389
Zero Compression: 100% Perspective
JackM wrote:
100mm
164mm
271mm
312mm
400mm
Any questions?
As smaller (foreground) subjects recede farther away than relatively much larger (background) subjects ...
the larger background subjects start to return to a more correct scale as the smaller foreground subjects
or
the smaller foreground subjects start to diminish to a more correct scale as the larger background subjects
this is why the moon at the horizon only looks large next to much smaller tiny real city skyline buildings farther away, than the moon held next to thumbsized toy cityscape snowglobe held up close to ones eyes
the moon doesn't change size, but only the perspective of small subjects seen up close or large subjects seen farther away
if one took a pic of your baseball team far away enough, they all look human sized in front of background buildings (church) = humans are tinier than buildings
  • _____=^=___
. = people, next to building
  • anyone can hold up the tiny eye of a needle close enough to fit the moon in the distance ... it's just a matter of perspective
pzk
phos.zoe.kosmos (light.life.world)
phos-kosmos (light of the world)
phos-zoe (light of life)
photo-graph-them-all!
 PhozoKozmos's gear list:PhozoKozmos's gear list
Canon PowerShot SX50 HS Canon EOS 5D Mark II Canon EF 24mm f/1.4L II USM Canon TS-E 24mm f/3.5L II Venus Laowa 12mm F2.8 Zero-D
Max Iso
Max Iso Senior Member • Posts: 7,147
JackM wrote:
Wheatfield7 wrote:
JackM wrote
Any questions?
You have been put on Jeff Bezos' naughty list.
"Step forward and meet a new sunrise, A coward is shivering inside
Today I'll be a friend of mine, Who swallows suffering with smile
I drew a different reality, With unconditional loyalty
Ego hardly can be piqued, 'Cause I'm selfless
Scale armour blaze, Virgin innocence
One being brings life, Another runs for death
No promises I ever give, Don't rely on me and I won't deceive
The beginning or the end you can't tell
When I wave my fin and shake my tail
I grew in different normality, With unblamable morality
Hooks and nets are there for me, But I'm skittish
Neptune's child shivering inside, Drowns in the liquid gold
Cherished his life to the underworld, Meet me flashing when winter cries
Pisces swimming through the river, All their life against the stream
Searching for a hook to catch on and see their sun beam
Then suffocate in painful tortures, On cutting tables of callous men
Under a knife of handsome butchers, Emeralds are ripped away..."
- Pisces
 Max Iso's gear list:Max Iso's gear list
Olympus E-M1 Panasonic Lumix DC-G9 Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +6 more
Distance is often determined by other factors, so distance is not the base cause for the perspective in a photo, it is what restricts your distance options that does it. The practical concern is where you physically can position the camera. In many cases, it is the lens forcing that. Other times it is the physical world of walls, streets, fences, etc. I really have right around zero luxury of choice when shooting something like candid 'street.' I can choose a lens, but I can't generally do much about my distance. If I can change distance, it's maybe just enough to get the framing for the lens I have on. So my distance is set by the lens and the time I have to frame and take a shot before the moment passes. Which is often next to none at all. I will, if able, step forward or back depending on what the lens makes me do, because I'm moving my feet before I'm digging for another lens (if I even have one). Which means the lens and the existence of a scene I want to capture is dictating my distance/compression, because I don't have time to let anything else influence the choice of distance.
Mike CH Veteran Member • Posts: 9,631
Perspective is real
JackM wrote:
100mm
164mm
271mm
312mm
400mm
Any questions?
What exactly are you trying to show?
Your images show very nicely that perspective changes as you move, and that by changing focal length, you can maintain framing of your foreground subject.
Regards, Mike
Wait and see...
I hardly ever speak for anybody but myself. In the cases where I do mean to speak generally the statements are likely to be marked as such.
 Mike CH's gear list:Mike CH's gear list
Canon G7 X II Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 16-35mm F2.8L II USM Canon EF 100mm F2.8L Macro IS USM +14 more
sybersitizen Forum Pro • Posts: 12,508
Re: Perspective
6
Distance is often determined by other factors, so distance is not the base cause for the perspective in a photo ...
Yes it is.
No it isn't.
What you're doing is misusing the term perspective. If you maintain the same physical relationship between the camera and subject and just change lenses, you are not changing perspective at all. Perspective remains the same. Every one of these images depicts the same perspective because the relationship between the camera and subject remains the same:
The magnification changes, and the framing changes, but the perspective doesn't change.
The two of you might find some common ground on the meaning of the word compression, but you can't get there by attempting to change the meaning of the word perspective.
Yes it is.
No, it isn't. A photograph is the end result of many decisions. It is usually the case that the distance is determined by another factor. Which means the perspective is then determined by that factor as well. You wish to speak as if distance can be selected at will, thereby creating whatever perspective one wishes in the photo. That is fantasy for most photos taken. The perspective is determined by what the photographer is able/allowed to do. There are countless situations in which the perspective will be determined by the fact that the photographer probably didn't want to die by trying to stand in a spot that would provide a different perspective. Self preservation determined the distance. Self preservation then constrained the perspective. It is wholly useless to ignore the fact that distance is not something one can choose at will at all times.
Re: Perspective
5
Yes it is.
No, it isn't.
Yes it is.
You are just repeatedly misusing the term perspective.
A more intuitive synonym for perspective is point of view. A camera exists in a position in space (usually relative to a reference point on planet Earth). It's also oriented toward some other point where the subject is. The only way in which you can change the point of view or perspective is to move the camera to a different point in space (up, down, left, right, forward, or back) and/or change its orientation toward a different point.
If instead you maintain the same physical relationship between the camera and subject and just change lenses, you are not changing point of view or perspective at all. They remain the same. Every one of these images depicts the same perspective because the relationship between the camera and subject remains the same:
Yes it is.
Perspective is a function of the camera-subject distance(s).  As far as physics and optics are concerned, it doesn't matter whether you have full freedom to pick those distances.  A camera will not deliver the same perspective at 12 inches as at 1200 feet just because its user wants to pretend that changing focal lengths changes perspective.
The definition of perspective does not say that you can always choose any distance.  But by the same token, you don't get to redefine what affects perspective, just because some distances (and therefore some perspectives) might have been unavailable to you.
This will explain your confusion...
Gerry Winterbourne Forum Pro • Posts: 15,457
ajs jones wrote:
Compression is simply caused by moving the camera away ...
You have this the wrong way round. Perspective is the way the relative sizes of things depends on their distance from a viewpoint, and only on that. For any given viewpoint perspective is always the same and depends only on that viewpoint.
A photographer may want to frame his picture in a particular way and therefore choose a particular viewpoint. But the perspective from that viewpoint is determined entirely by the viewpoint itself. It is predetermined by the spatial relationship between the viewpoint and the scene.
To put it another way: in a location there is an infinite number of perspectives; each of those is determined by viewpoint; a photographer can choose one of those viewpoints and that is his choice; but once the choice is made perspective depends on the viewpoint.
Gerry
___________________________________________
First camera 1953, first Pentax 1985, first DSLR 2006
gerry.winterbourne@ntlworld.com
fatdeeman Regular Member • Posts: 213
kiwi2 wrote:
Tom_N wrote:
JackM wrote:
Wheatfield7 wrote:
JackM wrote
Any questions?
But that means his priority is the framing and the perspective is just a consequence. All the OP has done is confirm the article is correct and confirm his own misunderstanding.
 fatdeeman's gear list:fatdeeman's gear list
Canon PowerShot G3 Canon IXUS 310 HS Panasonic Lumix DMC-G1 Sony Alpha NEX-5N Sony a6000 +21 more
Art Jacks Senior Member • Posts: 2,959
My examples prepared for my wife’s photography class.
No introductions, no explanations, no justifications, all I ask is that you give each image a little of your time.
