Any remote control for K-S1 ?
Started May 24, 2018 | Discussions
JahnG
JahnG Veteran Member • Posts: 3,473
Anybody knowing for sure about (IR ?) remote controls that can be used for the K-S1 , and possibly also for Kr.
A local camera shop is selling Hähnel HRC 280 Pro, described to be usable both for Pentax and Canon, but among supported Pentax models for this device,  K-S1 or Kr are not mentioned. Any further info about this?
The same shop is also selling remote control O-RC1, but for this is neither marked K-S1 (or Kr) as supported Pentax models. Any info?
I noted in the net that there is some device named "Pentax Remote Control F", but I have not found this locally, so it need to be ordered from abroad, and I would like to buy locally from the camera shop.
JahnG
 JahnG's gear list:JahnG's gear list
Canon PowerShot A650 IS Panasonic ZS100 Pentax K100D Super Pentax K-r Pentax K-S1
Holger Bargen Veteran Member • Posts: 4,911
Re: Any remote control for K-S1 ?
You can use any remote control that is made for Pentax cameras for K-S1.
The Pentax IR remote control should work.
I use this very simple IR control for Pentax:
https://www.amazon.com/Foto-Tech-Wireless-Shutter-Release/dp/B00GVHJ5LG/ref=sr_1_7?ie=UTF8&qid=1527195030&sr=8-7&keywords=remote+control+Pentax&dpID=31-Faeh3VML&preST=_SY300_QL70_&dpSrc=srch
I don't have exactly the same brand - there are a lot of products available with almost the same design. Make sure that ours is for Pentax. I also use them at my job. Once I bought one of these items and it did not work. I exchanged the battery and it worked fine - mabe it was a little too long in the store ...
Best regards
Holger
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
JahnG
OP JahnG Veteran Member • Posts: 3,473
Best regards
Holger
Thanks Holger.
So I today went to the camera shop and bought the O-RC1 remote control. I just tested it on my K-S1 and it works !!
It did both autofocus and then release the shutter, exactly as pushing the shutter key. I assume that if I change the AF/MF switch of the camera into MF, then it will only release the shutter, and thus I can do a suitable pre-focus. Anyway, during the weekend I will go out and make tests with the camera on a tripod.
Jahn
