Just bought a Nikon D3400 - what settings should I begin with?
Started 8 months ago | Discussions
Cheaptoad Forum Member • Posts: 67
I'm just starting out after many years.  Someone suggested to start use (A)uto and someone else suggested (P)rogram.
Nikon D3400
FingerPainter Senior Member • Posts: 6,986
Re: Just bought a Nikon D3400 - what settings should I begin with?
There is no one best mode dial setting for all beginners.
Use AUTO if you don't want to think and are happy to let the camera make the choices. Or use it to let the camera make the choices, and then take note of what choices it made and try to figure out why it made them. In Auto mode you are restricted from changing many of the camera's settings yourself.
Use Scene modes instead of Auto to indicate to the camera the type of scene you are shooting. This means the camera doesn't have to make an educated guess about the type of scene there is.
Use the Guide mode, for a guided way of learning to use various controls and perform various actions.
Use P, A or S mode to allow you to have greater control over settings, but still have the camera choose the image lightness. If you want to use P, A or S modes, then take advantage of the fact that you have a digital cameras. Do this by enabling Auto ISO. In P, A or S modes, you are letting the camera decide how light or dark your image will be, though you can adjust that lightness by changing the "Exposure Compensation" setting. in these modes there is almost never a need for you to change the ISO setting yourself if you can get the camera to do so for you as needed. Since you are trusting the camera to set lightness, and ISO is essentially a lightness control, it usually makes sense to leave the ISO setting to the camera. Setting the ISO value yourself just amounts to putting needless constraints on the camera's choices. You may find that a lot of people who learned on film cameras will not understand this. They are used to setting the ISO value first. With film that was pretty much essential. With digital cameras, it is often counter-productive to set ISO first.
If you do not enable Auto ISO, P, A and S modes mostly do the same thing. You point the camera at a scene and half-depress the shutter release. The camera uses its light meter to set a target image lightness, and sets one or both of the aperture and shutter in order to get the target lightness for the ISO setting you chose. If you turn the command dial, the camera will adjust both the aperture and the shutter speed. The adjustment to the two will be by reciprocal amounts, so the image lightness remains unchanged. If the camera is no longer able to get the desired lightness after you turn the command dial, it will Display "Lo" or "Hi" in the viewfinder. To change the image lightness, turn the command dial while pressing the Exposure Compensation button.
The main difference between P, A or S modes when Auto ISO is not enabled is how the camera chooses which aperture and shutter settings to use to get the target image lightness. In S mode, the came uses whatever shutter setting you last used in S Mode, and changes the aperture to whatever value is necessary in order to get the target lightness. If it is unable to get the target lightness with the aperture wide open, the cameras displays "Lo" in the viewfinder. In A mode the camera uses whatever aperture value you last set and adjusts the shutter speed. If it is unable to get the target lightness at the slowest available shutter speed, the cameras displays "Lo" in the viewfinder. In P mode the camera might change either or both of the aperture and shutter to get the desired lightness. If it is unable to get the target lightness with the aperture wide open, and at the slowest available shutter speed, the cameras displays "Lo" in the viewfinder.
When Auto ISO is enabled, the camera acts similarly, except that if the camera encounters a situation where it would have displayed "Lo" had Auto ISO not been enabled, it will attempt to achieve the target lightness by raising the ISO setting.
KLH475 Contributing Member • Posts: 874
Greetings, I highly recommend getting one of these books and work your way through it with your new camera
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Dstripbooks&field-keywords=Nikon+D3400
Check out all these tutorials on youtube.
https://www.youtube.com/results?search_query=Nikon+D3400+tutorial
Particularly check out Tony Northrup's one hour tutorial
https://www.youtube.com/watch?v=dJGjTUICOnc
If you click on Show More under his video you'll find a detailed list of what he covers and can review at will
Enjoy your camera!
Ken
 KLH475's gear list:KLH475's gear list
Nikon D3300 Nikon D7200 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +6 more
Chuck Yadmark
Chuck Yadmark Veteran Member • Posts: 4,395
Auto is the best setting until you can understand for yourself why you would choose otherwise
Ann Arbor, MI USA
www.sportsshooter.com/cyadmark
 Chuck Yadmark's gear list:Chuck Yadmark's gear list
Nikon D4 Nikon Df Nikon D4S Nikon D750 Nikkor AF-S 300mm f/4E PF ED VR +16 more
Bobthearch
Bobthearch Veteran Member • Posts: 6,544
Here's how I use the D3300 (and D5000, and D7200):
* Shoot RAW, Standard Picture Control (you can change all Picture Controls later using the free Nikon software, no reason to worry about it in the field.
*  White Balance on Auto.  Nikon is very good about selecting the proper WB for each shot.  And again, you change it easily later with free Nikon software.
*  Active-D Lighting, Auto or Off.  Again, you can change it later in the desktop software.  There was a recent discussion in which it was stated the camera may adjust the exposure depending on the ADL setting, so maybe it's better off?
* Generally leave ISO on base.  100 or 200 depending the camera model, and change only if necessary for low light.
* Aperture Preferred Mode.
The trick is, how you wish to set up the Autofocus.  There are so many options that largely depend on what you're specifically shooting.
Personal non-commercial websites with no ads or tracking:
Local photography: http://ratonphotos.com/
Travel and photography: http://placesandpics.com/
Special-interest photos: http://ghosttowns.placesandpics.com/
 Bobthearch's gear list:Bobthearch's gear list
Nikon D7100 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR +2 more
Chuck Yadmark
The fact that OP has to ask means OP likely has little to no idea what these things are which will cause problems
Will cause all sorts of problems and another thread
Might lead to unnecessarily blurred photos in low light if/when you forget to change settings
Can lead to blown out photos in very bright light
Edit: I know that these things can be a very good idea if OP knows what they are doing, or someday if they are willing, wanting, able to learn this stuff.  Still if I were a beginner I'd rather just jump in and start shooting without learning the other stuff yet.
Ann Arbor, MI USA
inlawbiker Senior Member • Posts: 1,708
I would use the scene modes and play close attention to what the camera is doing in a scene.
If you use full Auto mode the camera will take a best guess and what you're trying to do, by matching the scene to its internal database of presets. Often it will guess wrong. If you pick a scene mode, say Sports or Landscape, it gives the camera a pretty good hint at what you want to do.
Then you can glance at the settings and see what the camera is doing, and in the future you can duplicate that sort of thing yourself. For example switching from Sports to Landscape you might notice the aperture go from wide-open f/3.5 to f/11. There's a reason!
Greg.
 inlawbiker's gear list:inlawbiker's gear list
Nikon D700 Olympus OM-D E-M10 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Panasonic 12-35mm F2.8 +3 more
Bobthearch
So many of the camera settings are devoted to various Picture Control items, which also take up a good chunk of the manual. Sharpening, contrast, saturation... all part of the Picture Control system.
You can skip all of that in the field by shooting raw and using the Nikon software.  Learning the Picture Control functions via the desktop software is more efficient because you can see the effects applied in real-time on the image and computer monitor.
It shouldn't.  The shutter speed is displayed right on the camera back and in the viewfinder regardless of the shooting mode.
Yes, depending on the metering.  Which is also incredibly more complicated and advanced than in film SLRs.  It's just something to learn.
Ann Arbor, MI USA
No right or wrong, just explaining how I shoot, and how I set up my first DSLR to get out and shooting quickly.  My ten-year-old kid has a D3300, and he had no trouble learning the basics with these methods either.
The more 'beginner' that someone is, the more they will benefit from shooting raw.
Wahrsager
Wahrsager Senior Member • Posts: 1,242
Nikon Learn & Explore
 Wahrsager's gear list:Wahrsager's gear list
Nikon D4S Nikon D500 Nikon D5 Nikon AF-S Nikkor 400mm f/2.8E FL ED VR Nikon AF-S DX Nikkor 16-80mm F2.8-4E ED VR +22 more
Jonsi
Jonsi Senior Member • Posts: 2,259
FYI... since no one has told you...
(A) is not auto... It is aperture-priority mode.
You need to set your own aperture for the rest to be automatic.  That could have screwed you up.
The green "auto" is the "auto" setting.
OP Cheaptoad Forum Member • Posts: 67
I see that now.  Most of the photos I just took are not as sharp as I would have liked.  Not enough Depth of Field.  Plus I used the camera's auto focus all day.  I think I have to stop doing that.
Chuck Yadmark
I doubt you're correct on either of those 2 things.   Most lenses that come with a D3400 are pretty small aperture cameras meaning plenty of DOF.  And a properly functioning D3400 autofocus is pretty good, at least center point in decent light.
Ann Arbor, MI USA
Bobthearch
That doesn't sound right to me either.
Someone can undoubtedly clear that up if you post a sample photo.
GlennW Senior Member • Posts: 2,282
The D3400 should have a guide mode to help you with setup, once the battery is charged & memory card formatted in camera.
Set Jpeg quality FINE, & use LARGE size. Some prefer AdobeRGB over regular RGB
You can use Raw mode later............
Set ISO from 100 (daylight) to an upper value for dim light.
If you start with green A Automatic mode the camera will do all the work. Guide mode may help you adjust settings for your needs.
I Shoot RAW
 GlennW's gear list:GlennW's gear list
Nikon D5300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +4 more
http://www.dpchallenge.com/forum.php?action=read&FORUM_THREAD_ID=1362053
I just posted a few pics there. I hope that's OK
Steve
Chuck Yadmark
I'm not sure what you think is wrong there.  The subject matter and composition involves things with VERY different distances from the camera.  You can't expect to get the whole frame in focus.
Ann Arbor, MI USA
I guess it's more with the ones I didn't post.
So, they aren't terrible?
jshen808
jshen808 Senior Member • Posts: 8,356
Steve
..Nice pictures with your D3400 camera..
..by the way, which lens(es) did you use to take these pictures(?)..
..Cheers..
Regards, John..
..down with naysayers!
[YI M1 camera, Olympus 17mm f/1.8 lens, firmware 3.0]
 jshen808's gear list:jshen808's gear list
Canon PowerShot SX60 HS Nikon Coolpix P900 Nikon Coolpix W300 Nikon Coolpix P1000 Canon PowerShot SX70
Thanx for the compliments John. Means a lot considering my first day back.
I just used the 2 lenses that came with the camera
*Nikon AF-P Nikkor 18-55 3.5 -5.6 VR (90 % of what I did)
*Nikon AF-P Nikkor 70-300 DX 1:4.5-6.3
Steve
Steve
..Cheers..
jshen808
..The camera's lens, can work similar to the human eyes..
..try this experiment..
..using one of your hand, hold the index finger in front of your face..
..now with both eyes, focus on the tip of your index finger..
..with the index finger in 'focus', what do you notice what happens to the background(?)..
..the answer is, the background becomes 'blurred'..
..after looking through the pictures you have posted on another site..
..had noticed the images were taken using various apertures, ranging from f/3.5 to f/9..
..for 'greater' depth of field, try experimenting taking pictures using f/11 to f/16..
..which means you may need to take pictures using Aperture Priority mode or Manual mode..
..another way to take pictures with a 'greater' depth of field..
..this is not a joke okay..
..is to maybe consider using m4/3 or 1" or 1/2.3" sensor cameras to take pictures, as these sensor cameras will produce images with a 'greater' depth of field..
..can even use a smart phone camera as well..
..cameras are just photographic 'tools'..
..each has their advantages, as well as disadvantages..
..just use the camera that will fit your 'needs'..
..Cheers..
Regards, John..
