Question on E-M1 AF peformance
Started May 24, 2018 | Discussions
THKPIC Regular Member • Posts: 400
Hello,
I'm getting back into M43 and am looking for a sensible solution for my AF needs. I sold my E-P5 (bad idea) and am just now picking up glass again. I've read up on the AF for the E-M1 and users seem to equate it with the capabilities of the original Sony a6000. Can anyone confirm if it has a noticeable increase in hit rate over...say...the E-P5. if not I might just wait for the E-M1 II to come down in price a bit more.
 THKPIC's gear list:THKPIC's gear list
Olympus PEN E-P5 Sony a7 II Nikon D7500
Olympus E-M1 Olympus PEN E-P5 Sony a6000
Skeeterbytes Forum Pro • Posts: 23,186
Re: Question on E-M1 AF peformance
THKPIC wrote:
Hello,
Versus an E-P5 it's chalk and cheese, the E-M1 is much better, especially with Pro lenses. I've shot lots of sports and other action with it and while it takes time and experimentation to master, it's a very competent camera even if five years old.
Rick
(unknown member) Veteran Member • Posts: 7,274
It is little difficult to say if you get like a 90% focus rate with E-P5 for a cycling kids toward you, that how much better you want to get "much better"?
Like a scenario, you have a kids cycling toward you at 50 m range back and worth so you start at 50m range and stop at about 5m range as 40mm is too narrow at then.  If you get with E-P5 and its 5 FPS for C-AF about 30 frames from what 4 frames is slightly out of focus at closest range, then how much it really is better to have like only 2 frames out of focus or just 1 slightly out of focus?
But that is hardest test really for any C-AF system as the subject is coming directly toward and closure speed ratio increases quickly. The other challenge for C-AF prediction capabilities is target that speed varies so it accelerate, decelerate and can even stop.
Some E-M1 samples with Pro tele lenses.
Rick
OP THKPIC Regular Member • Posts: 400
My keeper rate has to have been below 30 percent. It was hot garbage to be honest. I've tried all manner of settings even in good lighting. I didn't know there was that much of a difference with the E-M1. Hmm, I may have to give it a whirl then. That was my only complaint with the E-P5.
