Card or camera problem
Started May 21, 2018 | Discussions
puttin
puttin Veteran Member • Posts: 7,903
Taken with K1 II. I'm hoping it is a bad card but I still have time to send the camera back. Switched cards but not had time for more photos but one, it was ok
 puttin's gear list:puttin's gear list
Nikon Coolpix A Canon G9 X II Sony Alpha NEX-7 Sony a7 II Sony a7R II +21 more
Pentax K-1 II
puttin
OP puttin Veteran Member • Posts: 7,903
Re: Card or camera problem
Now that I remember the 2nd photo was ok when I looked at it on the camera lcd, don't remember about #1
MightyMike Forum Pro • Posts: 41,391
Could be a transfer to the computer problem too.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
puttin
I think you might be right since it showed up ok on the lcd.
Mike from Canada
You can always try a different USB port, copy instead of moving until you've got it figured out so you don't lose photos.
Mike from Canada
puttin
To bad I deleted the files from the card. If not I would try one of my card readers.
Mike from Canada
ozdean
ozdean Forum Pro • Posts: 28,110
If you can read it off the card in camera (Play)  it is not either of them that is the problem
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
Joseph Tainter Forum Pro • Posts: 11,494
So take some more photos.
Joe
Rahto Senior Member • Posts: 1,579
I had this same issue and it ended up being a bad card reader.
Bob
 Rahto's gear list:Rahto's gear list
Canon EOS D60 Pentax *ist DS Pentax K-7 Pentax K-3 Pentax K-3 II +62 more
puttin
I normally use the card reader in the computer, but if it happens again I will try an external card reader.
Joep van Steen
Joep van Steen Regular Member • Posts: 485
Just let me know if you want me to try fix these photo's (if they're JPEGs).
Edit: Oops, contains restart markers, my repair tool does not support those yet ...
Joep
puttin
It was only 2 and not important, but thanks anyway.
Joep van Steen
Okay. Due to my curious nature I had a go at it anyway..
Joep
ozdean
Well done Joep!
Joep van Steen
Thanks Dean!
I cheated a bit on this one, cut off lower 5% or so because there were alignment errors.
For the rest, basic method using free tools is:
Get JpegSnoop > Have it process the image and look for lines where it reports invalid markers. Copy the byte address and view in hex editor (I used HxD).
Basic rule is that FF is an important value in JPEGs, it means a marker follows. Next byte defines what marker, and if this is a nonsense value JPEG decoders will choke. That's why this image is cut off,  or grey for a large portion, the decoder is simply giving up.
Actual image data in a JPEG starts after FF DA. After that you should not see FF unless followed by 00.
Unless the image contains restart markers (FF Dx where x = 0 to 7).
So any FF followed by a value that's not 00 or FF Dx (where x = 0 to 7) I changed to FF 00.
In a basic JPEG (no restart markers) you will then get color and alignment errors that affect the rest of the image.
Advantage of restart markers is that corruption remains limited to area in between two restart markers. Which was the case with this JPEG and I simply clone-stamped that area using Paint.NET
So, for this one I only used free stuff and anyone can do it.
Joep
puttin
That's the worst one and I guess it shows not a camera problem but most likely a computer problem, thanks
Joep van Steen
Would it be okay for me to use this photo to compile a tutorial and a video maybe?
Joep
Joep van Steen
Yeah, in my experience these are what I call 'transfer/transport problems'. Somewhere at some point a couple of bits got flipped during writing, storing, transfer etc. of data.
If you take into account all the different protocols and hardware from taking an image to storing it on your hard drive it's a miracle that it works most of the time.
Joep
puttin
My dog Gracie said OK.
Joep van Steen
Great, thank your dog! I'll make sure to mention her!
Joep
