Fuji dropped the ball big time on JPEGS? Locked
Started May 20, 2018 | Questions
This thread is locked.
DarnGoodPhotos Forum Pro • Posts: 11,881
Re: Fuji dropped the ball big time on JPEGS?
Without getting too pedantic, but there is a massive tone difference between "Fuji dropped the ball?" and "Did Fuji drop the ball?" For what it's worth, I shoot Astia as my default Film Sim because Provia is too bluish IMO; a big difference from Provia on my X-Pro1 and X-E1. Shadows +3 isn't helping you at all.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
HP1999 Veteran Member • Posts: 4,316
set no internal changes to shadow and highlights and all that mess
manually set DR to 100%
Use the correct metering pattern (generally speaking)
Do not let camera pick AF points if that is even an option
Use standard Provia, Astia or ProNeg Low I think but to compare
Use flash if you needed, even a $6000 Nikon D5 is not magical.  There is still crafting the image.  It is very easy to do one and one without flash.  If you are dead set against it bracketing exposure is always good.
Shoot RAW and JPEG that RAW file can save the day
The Davinator
The Davinator Forum Pro • Posts: 24,707
But if the OP does that, then he won't have any need to complain....where is the fun in that?
Doug MacMillan Veteran Member • Posts: 3,695
X Raw Studio
If the XH1 is supported download it and shoot some raw + jpeg. Save some test images to your computer, then use it to process them.  You get to see the effect of the different film sims and settings. You can then make  some recipes and save them as your favorites.  See if you can dial in your jpegs that way.
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
Let the good times roll...
Batdude
OP Batdude Veteran Member • Posts: 6,544
I did drop the ball. My apologies.
fcracer wrote:
Seems rather counterintuitive to say Fuji has dropped the ball on jpeg when you’ve gone and modified the standard jpeg settings. Perhaps you’ve dropped the ball?
A +3 shadow setting will darken the shadows creating a harsher appearance to the image. For portraits, Fuji recommends pro neg high for outdoors and pro neg standard for indoors.
That +3 shadow tone setting alone was the reason for such unpleasant looking skin tones.  I didn't reshoot the same subjects because is not possible but I tris it on my kids in Provia Standard with shadow tone +3 and at -2 and the difference is humongous.
I would like to ask the MOD to please change the tittle because it was my own user error since I had no idea that shadow tone setting had such impact on the photo output.
Again, my bad and I apologize if the tittle offended you.
Try following Fuji’s advice and see if the image is still not to your liking. I’d also humbly suggest taking into consideration titles for your future posts. Imagine being a colour engineer at Fujifilm and seeing your headline.
Personal photo blog: www.fcracer.com
Instagram: fcracer
Flickr: fcracer
 Batdude's gear list:Batdude's gear list
Fujifilm X10 Nikon D4 Fujifilm X-E1 Fujifilm X-T1 Fujifilm GFX 50S +12 more
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
Re: I did drop the ball. My apologies.
Umm, sorry but no.  That would require my editing every single post which contains your title.  I'm afraid you're sort of stuck with it.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
DogShot Contributing Member • Posts: 694
Batdude wrote:
What has happened to Fuji JPEGS?
I'm pretty happy with them. Here's one from today using the X-T20 and 50-140mm f2.8 - SOOC using Astia and color +1.
Contrast that with SOOC jpeg from a Nikon (D3 with 70-200mm f2.8) in portrait picture mode.
On my computer the Fuji jpeg is hard to beat using the raw file, whereas the Nikon requires work on the raw file to get rid of the green.
Acrill
Acrill Veteran Member • Posts: 3,166
Hi Jerry,
Any chance we can just lock the thread?
Cheers
 Acrill's gear list:Acrill's gear list
Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
Jerry-astro
Yes, but...
Acrill wrote:
Hi Jerry,
Cheers
Sure, that's easily done, however, in this case, I'd probably need to get the OP (Batdude) to request it, since there's no real violation of forum rules here.
Your call, 'dude.
Jerry-Astro
Ed B
Ed B Forum Pro • Posts: 12,575
I will agree that once a person starts adjusting the shadows and highlights they're changing the Fuji in-camera JPEG processing algorithms and shouldn't blame Fuji for the out of camera result.
I've owned a Fuji since about a month after the X-E1 was introduced and although I agree Pro neg standard is one of the film simulations recommended for portraits, Provia is also recommended.
Have to admit I've never heard that pro neg high is recommended for outdoor portraits and pro neg standard is recommended for indoors.  Must have missed that.
I use Provia for all portraits but that's just a personal choice and because I post process every image I intend to keep my choice may not be as important as it would be for a person who didn't post process their images.
I know this is a touchy subject and many people will disagree with me but as much as I like Fuji I do think their JPEG processing has suffered, over the years, and skin tones just don't look quite as good as they did with the original X-Trans processor (X-Pro1/X-E1).
That's not to say the newer cameras aren't "better" but I do think the JPEG engine isn't quite as good.
Instagram: fcracer
Flickr: fcracer
Ed B
Batdude wrote:
TEAS wrote:
I agree ---- I seems that this is another case of user error - and blaming the camera.
I'm responding to your two previous posts above and in my explanation I very clearly said: "Did I do something really wrong with my XH1 settings??" so why on earth would I have to "admit" to you that I screwed up? And I "blamed" the camera? You make no sense bro.
Again, you just want to play this childish "hurt my feelings" game because of some dumb tittle that you didn't like.
If you already read above I asked Jerry if he would change it and he said no to just leave it the way it is. I didn't and don't have a single problem in "correcting" the tittle.
In the end I don't have to admit anything to you, this ain't court.
I agree with you.
Too many kids and immature people here who get their feelings hurt about almost anything.
I do think your settings may have been the problem with your images but I don't think there was anything particularly wrong with your post.
Just the same, it's the Internet and no matter what you post or how you say it, someone is going pick apart your every comment and try to make you look like you're an idiot.
Batdude
Re: Yes, but...
Jerry-astro wrote:
Acrill wrote:
Hi Jerry,
Cheers
Your call, 'dude.
Hi guys,
I respect everyone's opinions and since the tittle couldn't be changed and this was my error I say go for it.
Thanks.
Ed B
Re: Toward settings in the camera
Batdude wrote:
celestialemissary wrote:
Charles2 wrote:
Is this better? Lightened shadows, shifted white balance slightly warmer and tint toward green away from magenta - all things that can be set in the camera.
See original size
It's still bad.
I agree. Their skin tones simply do not look like that in real life and it still look unpleasant. Maybe by me setting it to +3 shadow tone and Provia Standard simply destroyed the photo from the begining?
I did import the photo in LR and also tried adjusting the warmth and WB and other color sliders, and It just didn't come out right. For the kind of tan skin tone the girls have something went very wrong, either those setting or as other people already said, using Provia Standard. They were under a very nice amount of shade and was expecting much better results. The skin tones here look very plasticky and fake and plain unpleasant. I might as well shoot RAW from the very beginning because it makes no sense to spend so much time with jpegs like this trying to fix them. Unpleasant stuff like this is exactly what I was getting with the old Nikon D7000 years ago.
I will try something else another day before my family leaves, they are only visiting for a few more days
Okay, if people are making adjustment.
I'm sitting here on a small laptop so may not be getting a good rendition of this image but decided to lighten the shadows and turn the color down just a bit.
Doesn't look all that bad to me.
Jerry-astro
Locked as requested
Batdude wrote:
Jerry-astro wrote:
Acrill wrote:
Hi Jerry,
Cheers
Your call, 'dude.
Hi guys,
Thanks.
Thread locked per OP request.
Jerry-Astro
