A quick focal length comparison
Started May 19, 2018 | Photos
io_bg
io_bg Senior Member • Posts: 1,548
9
)This morning's sunrise was very bland so I decided to do a quick focal length comparison with my humble selection of lenses. Hopefully they could be of use for someone. This test is totally unscientific, some pictures appear to be slightly crooked but I decided not to fix cause it would require some cropping afterwards. Raw files converted in ACR with the default settings except manual white balance and film simulation (Provia). The Fuji lenses in the set (16-50 II, 27 and 60) have their correction profile automatically applied while I manually applied the lens profile for the Samyang/Rokinon 12mm f/2. All pics shot at f/8, ISO 200, 1.5 sec.
12mm (Samyang 12mm f/2)
16mm (Fuji XC 16-50 OIS II)
23mm (Fuji XC 16-50 OIS II)
27mm (Fuji XF 27mm f/2.8)
34mm (was trying to get it exactly at 35; Fuji XC 16-50 OIS II)
50mm (Fuji XC 16-50 OIS II)
60mm (Fuji XF 60mm f/2.4 macro)
Honestly, I was surprised how large the difference is between 50 and 60mm but also 23 and 27. Next time I'll try to find a subject while I change the perspective and try to frame it identically for each focal length.
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
Comment & critique:
Emile15 Senior Member • Posts: 1,769
Re: A quick focal length comparison
Did you use a tripod?
 Emile15's gear list:Emile15's gear list
Fujifilm X100T Fujifilm X-T4 Canon EOS R5 Canon EOS R7 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +12 more
Sal18 Veteran Member • Posts: 5,296
Thank you! This was very revealing.
Sal
Rod McD Veteran Member • Posts: 8,589
Hi io,
Thx.  I guess I'm surprised by the difference between the 50mm of your zoom and the 60mm too.  I wonder if the 50mm of the zoom is accurate or whether the 50/2 would show the same FOV.....?  I've always thought that they'd be a bit closer.
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
io_bg
OP io_bg Senior Member • Posts: 1,548
I did. I shouldn't have skipped also using my remote since the shot from the 60 came out blurry.
Sal
You're welcome!
Rod McD wrote:
Hi io,
Cheers, Rod
I wouldn't be surprised if the zoom doesn't really reach 50mm since advertised focal lengths are usually approximations. Still, I'm more than happy with its performance, especially for the $90 I paid for it. I have only briefly tested the 50 in a camera store but haven't done any comparisons.
TEAS Contributing Member • Posts: 954
Very interesting
 TEAS's gear list:TEAS's gear list
Fujifilm X100F Fujifilm X-T20 Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 60mm F2.4 R Macro +17 more
oscarvdvelde Senior Member • Posts: 1,421
Because of the symmetry and repeating patterns, the subject is not showing too well how dramatic the differences are.
 oscarvdvelde's gear list:oscarvdvelde's gear list
Fujifilm X-T3 Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR Samyang 50mm F1.2 +4 more
