Does anyone have both the E-P5 and the EM10 II?
Started May 19, 2018 | Discussions
biggles266 Senior Member • Posts: 1,305
I had the E-P5, and sold it to fund the EM10 II. The E-P5 was a very good camera but I like the design of the EM10 II better since I didn't like the look of the E-P5 with the EVF on. Also the E-P5 had dials issues.
However sometimes I get a nagging feeling that my Jpg photos with the EM10 II don't seem quite as contrasty and nice as the ones from the E-P5. I can't be sure, and can't test it myself since I don't have both cameras. I can't imagine that Olympus would have changed anything in their Jpg engine between these two models, but I'd like to know for sure, just so I can settle the matter and know if I'm imagining things. It seems like when doing editing I have to increase the contrast more often on the EM10 II files to get them to look nice, than I did with the E-P5. I use the same in camera Jpg settings as before.
If anyone happens to have both these cameras, and feels like taking a comparison shot of the same scene (perhaps an outdoor scene, in soft not harsh light, using the Natural profile), and seeing if the two cameras take the same quality Jpg when using the same settings, that would be appreciated.
If someone reading this doesn't have both these cameras, but has more than one Olympus camera, then it might be an interesting topic to post on this site - showing a comparison Jpg from more than one Olympus camera, so people can judge the quality difference between different models. e.g. if someone said "here is a Jpg from an EM5 vs the same Jpg from an EM1, etc.", that would be interesting, and I haven't seen it done before on this forum.
 biggles266's gear list:biggles266's gear list
Canon EOS 6D Canon EOS M50 Canon EF 85mm F1.8 USM Sigma 50mm F1.4 EX DG HSM Canon EF 70-300mm f/4-5.6 IS USM +7 more
Olympus E-M1 Olympus OM-D E-M10 II Olympus PEN E-P5
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: Does anyone have both the E-P5 and the EM10 II?
Any jpeg differences may be the improvements/changes in the TruePic chip going from V5 in the E-P5 to V6 in the E-M10 Mk2.
Anyway, life is way nicer using raw files plus DxO and Prime noise reduction. A nice improvement on the camera jpegs whatever body is involved.
Regards..... Guy
PoohBill
PoohBill Regular Member • Posts: 363
Do you see this over Oly’s own RAW processing?
Bill
 PoohBill's gear list:PoohBill's gear list
Olympus 12-40mm F2.8 Pro Olympus E-M5 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +2 more
Guy Parsons
Yes.
The trouble with OV3 is that it does exactly (well, very close) to what the camera does to make jpegs. That includes noise reduction that helps reduce fine detail and edge halos from sharpening, even when you try to set both to minimum or off.
In some eye-watering pixel peeping efforts with side-by-side testing I also found that DxO delivers better edge to edge detail as their lab created body+lens profiles appear to work better than just the canned lens data coming from the lens into the exif data.
So the DxO basic profile plus added user adjusts to create a new custom profile and all seems well.
Plus DxO makes use of the edge pixels that the camera jpeg ignores, so a bit of extra width in the image can be found.
Using the Prime noise reduction on any ISO also seems to help resolve very fine detail a little better, but that is also in eye-watering pixel peeping land.
The default Olympus jpeg output has always been a bit too red, just watch the colour of any grey concrete or bitumen roadway or the "brilliance" of any red postbox or red car in the scene. That needs to be toned down a little, and it seems to me that DxO does much the same, so I had to also wind back the redness a bit.
Regards...... Guy
Guy Parsons
Example
Was crunching a few images taken today and here is a classic case of what sort of detail that DxO gets out of an image. Have a look at the screen grab at full size.
On the left is my out of camera LN Natural jpeg with contrast, saturation and sharpness all at -1. Middle is the DxO+Prime version. Right is the OV3 effort Vivid with contrast, saturation and sharpness all at 0 setting. the 3 images at 200%
Industrial stuff inside an old abandoned dockyard.
DxO certainly works better for me than the camera or OV3.
Regards...... Guy
essH Contributing Member • Posts: 886
I have an E-M10 II and an E-P5 - I have not done a back-to-back test of the same subject, but my instinct would be that the jpeg output of the M10 is sharper and more contrasty. If I get suitable conditions over the next few days, I will have a go at setting up a test.
My observations between the two cameras have been more about usability - I prefer using the viewfinder on the M10 as fitting the VF-4 to the E-P5 makes the latter more cumbersome to use and especially to store in my bag when not using it.  Granted the VF-4 gives me the option of an angled shot, but I have not found I need that very much.
Simon
 essH's gear list:essH's gear list
Pentax K-30 Olympus OM-D E-M10 II Pentax smc FA 77mm 1.8 Limited Olympus M.Zuiko Digital 45mm F1.8
Aberaeron Forum Pro • Posts: 10,184
Re: Example
Regards...... Guy
Why the universal -1 settings for the camera jpeg? Surely you would have got much closer to the DxO+Prime image if you had the camera set to take jpeg all set at +1
Guy Parsons
Why I use DxO+Prime.
The LNjpeg from the camera is only a reference thing so I have something to review in the camera. Being a bit "flat" and neutral, it responds well to further fiddling if wanting/needing to use the jpeg only for email or some quick unimportant purpose. More careful sharpening in FastStone Viewer or other edit programs definitely works better than the in-camera sharpening.
Apart from all that, when using DxO I simply get more detail out of the image, proven by the mesh in that old electric motor. No matter what I did with OV3 there's no way I could get that mesh detail that DxO managed without raising a sweat. Using Prime on all images (all ISO) does not remove detail at all, but improves it.
I am still experimenting but slowly "zooming in" on a nice default preset for DxO that suits a whole folder conversion, then go back to any "problem" results to further fiddle. Yesterday's day out seemed to give me the whole folder OK from DxO, no problem shots, exterior in sunlight to inside dimmish buildings at ISO 6400.
So DxO Photolab works for me and as I am stalled on the E-P5 and a few lenses then I am set for life. No worries if DxO goes belly up.
Regards..... Guy
OP biggles266 Senior Member • Posts: 1,305
Thanks that would be interesting.
I agree, the E-P5 was classy without the EVF, but very ugly with it, and awkward in a bag. The M10 II is a beautiful camera with its EVF, and had a more discreet profile for street shooting. I find it makes a difference to the overall enjoyment of a photographic session to use a beautiful tool. I never used the angled EVF either.
Simon
I have just done a quick test in less than ideal conditions - the sunlight was not 100% constant so although most of the settings were the same, the shutter speed varied slightly - probably because my viewpoint shifted slightly - sorry about that.
As you can see, I used the 17/1.8 lens on 3 bodies - E-M10 II, E-P5 and E-M5 II and the results are not quite what I expected and I don't feel reflect what I know of the M10. I hope I can repeat the test in slightly more controlled conditions and a better subject matter.
https://flic.kr/s/aHsmgeq1y1
Simon
Guy Parsons
Thank you. It's a start but truly the best way is to provide the raw files from your future experiments so we can either use OV3 to see what the camera would do, or use the raw converter of our choice to see what we would get out of the various cameras.
Regards.... Guy
Regards.... Guy
I understand your point, but I am responding to the OP's specific question about jpegs.
I already gave my unscientific view about E-M10 II versus E-P5 and I was disappointed by my somewhat rushed results in the garden.  I went through my past jpegs and could not find any direct comparisons between the cameras, and so far I have not saved RAW from the E-P5, which I acquired secondhand as a second body to my E-M10 II, on which I save RAW + Jpeg. I intend to redo my tests as my personal feeling is that this time the M10 came out worse than its siblings (which is not what I had noticed previously). If I remember, I will collect RAW from the Pen.
Straying from the original post somewhat, I know from your posts that you use E-P5s currently; that demonstrates the diversity of our community. I started out wanting to like the Pen, but the O-MD format seems to suit me better.  I had the chance recently of a weekend shooting with a Pen-F and an E-M5 II; to my surprise, I ended up preferring the M5 - but it was a marginal call, based as much on personal ergonomics as on results and some of my Pen-F shots are remarkable.
Simon
Hi, thanks. Yes, jpgs are all I'm interested in. The test will need to be on a tripod though, so the framing doesn't change at all, since that can easily affect exposure and contrast. Also you might want to use a simpler scene, not one with complex fauna, I think it will be easier to compare contrast with larger elements in the picture.
